Author Topic: What's your dream keyboard?  (Read 27630 times)
Offline Raddam
« on: Tue, 20 May 2014, 16:07:52 »
What's your dream keyboard? Or if you could make your own what would it have?
Offline Ozric
Re: What's your dream keyboard?
« Reply #1 on: Tue, 20 May 2014, 16:25:11 »
Industrial Grey Model M, probably TKL, with PBT doubleshot SA keycaps.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #2 on: Tue, 20 May 2014, 16:29:22 »
60%, MX greens, gunmetal FMJ case, with a nostalgia set
« Reply #3 on: Tue, 20 May 2014, 16:30:38 »
TKL layout Beamspring board in a thin bezel case, spherical thick ABS caps, USB connection.
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #4 on: Tue, 20 May 2014, 16:31:35 »
I swear we already had this thread before somewhere.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #5 on: Tue, 20 May 2014, 16:34:52 »
There have been a few similar ones, like "Favorite board + your dream board" and I'm sure there are some but they just died
« Reply #6 on: Tue, 20 May 2014, 16:40:22 »
TKL with linear-clicky switches that have low actuation force but high push-back force
Impossible and will never happen
Offline esoomenona
  • Gnillort?
« Reply #7 on: Tue, 20 May 2014, 16:43:38 »
TKL board. Linear switches. Speaker that makes clicking sound when switch is actuated. Low spring weight. Under the keyboard are little rods that are retracted. When the switch is actuated, the rod shoots up pushing the stem up with force then retracts quickly.
« Reply #8 on: Tue, 20 May 2014, 16:45:51 »
This incredibly unique keyboard that can be used as a gun..
Offline Novus
  • Mondai nothing~
« Reply #9 on: Tue, 20 May 2014, 16:47:56 »
Does it have a blade though?
Offline Defect
« Reply #10 on: Tue, 20 May 2014, 17:28:57 »
Gimme them magnets and honeywell sphericals.
In 60% form factor.
Offline derzemel
« Reply #11 on: Tue, 20 May 2014, 17:44:38 »
The closest keyboard to my dream one would be Duck Light Saver v2.0
And based on this one I made this preset which represents exactly what I consider to be the perfect keyboard. Also, it should have Cherry MXReds with white LED lights and the possibility to select which LEDs stay on or off
« Reply #12 on: Tue, 20 May 2014, 17:45:30 »
That's almost exactly what I was thinking, but with tiny screw-dials to adjust the return force. I'm a little creeped out how close you are though  :eek:
Offline Raddam
« Reply #13 on: Tue, 20 May 2014, 18:01:52 »
Sorry if we did already :rolleyes: I just think this is a really cool topic that I couldn't find on the thread. I don't doubt that there was another one though.
Offline Razor Lotus
« Reply #14 on: Tue, 20 May 2014, 18:07:05 »
A korean 60% with a nice metal case like hammer or something. Thick PBt keycaps and nice backlighting
« Reply #15 on: Tue, 20 May 2014, 18:11:19 »
60% + numpad hall effect USB keyboard with NKRO.
^ currently in the works, hope to be done soon.
« Reply #16 on: Tue, 20 May 2014, 18:16:15 »
And then I can have one too dorkvader?
Offline Pacifist
  • on hiatus
« Reply #17 on: Tue, 20 May 2014, 18:17:44 »
Apart from the typical "what keyboard should I get" "what switch is the best" and "is topre worth it" this question comes up periodically, each time in the form of a new thread
« Reply #18 on: Tue, 20 May 2014, 18:30:39 »
That's like almost every other thread lately.
« Reply #19 on: Tue, 20 May 2014, 19:20:24 »
I dream of a more ergonomic keyboard that is something in-between symmetric stagger and Kinesis contoured, and with keycaps in completely custom contoured shapes to form a bowl for each hand's fingers.
The shape would have the ergonomic benefits of the Kinesis without having to relearn too much from a regular typewriter keyboard, and without having to use the "correct" finger for each key all the time.
The keyboard is of course split in two halves, with adjustable tenting, inclination and position and angle of the thumb key clusters. Integrated pointing device, gesture recognition and spaceball-like camera control for 3D modelling and RTS games.
The switches are smooth and stable as Topre, with a force curve like lubed Cherry MX Clear but slightly sharper, more like clicky switches. The force is adjusted for each finger (like Topre Variable or Key Tronic ErgoForce). The key travel of normal keys after actuation is at least twice than normal so that you never bottom out. Thumb keys have lower key travel to a distinct bottom so they are easier to hold down.
You get tactile feedback and very low audial feedback only on the down-stroke when you have reached the actuation point and never otherwise. On the up-stroke, it is linear and dampened silent. (like a mix between Cream Alps and Buckling spring). Also because the switches are so stable, there is also no rattle.
Each key is also analogue after the tactile point, so that it can be used as an analogue gamepad for gaming or for other user-interface enhancing features.
Despite the longer key travel, a switch with keycap can be ~ 1/4" lower profile than Cherry MX. The users fingers will reach down into a bowl somewhat like on the Kinesis, but without the need for a high wrist rest.
If the Caps Lock key is not unmapped, it is latching so that you could feel with your finger when it is active. Like the Shift Lock on the Commodore 64, but unlike Cherry MX Lock/Alps Lock, it is also tactile and clicky so that you can feel when you have activated it. It can be pressed and released by software, with audial feedback.
Keycap texture is coarse like SP or Realforce, PBT plastic with E-ink legends. Instead of homing bar, there are two homing dots in the bar's location (like a split bar) on the D and K keys. The dots allow you to self-diagnose if you have Carpal Tunner Syndrome - if you don't feel the dots under your middle finger as being two distinct dots you should see a doctor.
« Last Edit: Tue, 20 May 2014, 19:29:52 by Findecanor »
Offline AntiPeasentry
« Reply #20 on: Tue, 20 May 2014, 19:54:33 »
Happy Hacking 2, Neon green cover. Neon Yellow WASD keycaps, backlit with green LEDS. rest of keycaps all lime.
Offline 0100010
  • Not Sure
« Reply #21 on: Tue, 20 May 2014, 20:02:08 »
« Last Edit: Fri, 06 June 2014, 16:53:56 by 0100010 »
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #22 on: Tue, 20 May 2014, 20:22:46 »
Ergo dox layout, dished slightly, Buckling springs, programmable, EL mat backlighting for a nice cool glow, CNC milled case from 316 stainless, brushed finish with either no clear coat or a matte finish clear.
« Reply #23 on: Tue, 20 May 2014, 20:40:52 »
Sounds like your next project board ;)
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #24 on: Tue, 20 May 2014, 20:43:42 »
GON Ns-87....
KMAC 2....
Offline Pacifist
  • on hiatus
« Reply #25 on: Tue, 20 May 2014, 20:44:42 »
mx mini, full alum case, nixdorfs, OG dyesubs all across AND in right profile throughout.
Pretty much impossible
Offline Melvang
« Reply #26 on: Tue, 20 May 2014, 21:00:40 »
Forgot to add, custom stems to accept MX caps.  So long as we are going that far, have special ones to use DCS profile caps in alternate layouts without weird profile issues.
But no spam ray i don't think this will be happening.  Though I don't see why it can't be done.  Aside from the special alternate layout option.  I wonder if mold costs would be the only thing preventing MX -> BS adapters
Offline OnTheBrink
  • Work Hard. Play Harder.
    • Wired In Store
« Reply #27 on: Tue, 20 May 2014, 21:26:25 »
A KMAC 2 or another really good custom with a black aluminum case, red or orange thick titanium plate, thick blank PBTs either black or some other variant with different color modifiers, bi-color BB v2 escape key that matches a CC wasd cluster (preferably blood splat or blank candy corns).
Offline CK Briefs
  • formerly calvins1
« Reply #28 on: Tue, 20 May 2014, 21:35:55 »
I think my orion constitutes as a dream board,no?
The only board better might be a 456gt and i don't really want one :P
Current Keyboards: Orion - 62g ergo clears;
A87 PS2AVR - 59g ergo clears; QFR - stock blues
Offline lightsout714
« Reply #29 on: Tue, 20 May 2014, 22:30:00 »
Original KMAC in grey/silver. w/a brand new OG Cherry set. w/modded clears.
Offline Dubsgalore
« Reply #30 on: Tue, 20 May 2014, 22:36:55 »
Brand new ESA-3000HASRO
Offline exitfire401
  • The Force is Re/\l
« Reply #31 on: Tue, 20 May 2014, 22:40:33 »
My dream board that exists, I already own (my fully customized race 2) my dream board that doesn't exist (without mods anyway) is a 55g hhkb.
« Reply #32 on: Tue, 20 May 2014, 22:45:03 »
RealForce 87U white 55g uniform in an aluminium case with yellow printed keycaps.
I already have the Drunken Skull for the Esc, now I just need the rest :p
Offline JPG
  • Model F is my new passion!
« Reply #33 on: Tue, 20 May 2014, 22:57:10 »
Space-unsaver model F with stainless steel (or titanium) case, all features from Soarer converter but built in the controller. This keyboard should be made to last 100 years.
Offline t2russo
« Reply #34 on: Tue, 20 May 2014, 23:23:37 »
Dream as in ideal parts?  Aluminum TKL with left-side sixpack and nav cluster.
Dream as in I probably won't ever get the chance to purchase one? 356L
Offline Oobly
« Reply #35 on: Wed, 21 May 2014, 01:53:46 »
Layout: 46% custom layout with staggered vertical columns and angled thumb clusters.
Switches: Trampoline and latex modded 62g worn-in and lubed ErgoClears.
Keycaps: Thick Cherry profile POM doubleshots (solid colour with milky white legends so backlighting diffuses nicely without showing through the rest of the cap).
Case: Custom CNC machined aluminium or single piece acrylic.
Cable: Long, braided MicroUSB to match the keycap colour.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline combataran
« Reply #36 on: Wed, 21 May 2014, 02:06:06 »
A 356CL kit.
Cherry G80-1000HFD | CM Storm Spawn | Keypuller.com - Key Caps News & Database
Offline davkol
  •  Post Editing Timeout
« Reply #37 on: Wed, 21 May 2014, 04:59:06 »
I suppose I'd be happy with the upcoming AcidFire's split Axios.
For now, it's the ErgoDox with
  • a compact case (I only wish I had the czarek's PVC one with a metal plate, instead of the litster's acrylic case from Massdrop);
  • 76 smooth vintage Cherry MX Black switches (I might replace the springs for 62g Korean ones and put stabilizers on the 2x keys eventually, 80key layout is another option);
  • thick Cherry PBT keycaps (PBT SA or Cherry POM would be nice too);
  • TMK firmware.
Offline frosty
  • jukebox hero
« Reply #38 on: Thu, 22 May 2014, 10:00:10 »
white filco body, phantom insides, rainbow pbts and a fancy cable.
cherry mx reds and super blacks on modifiers, all lubed. tkl.
Offline nickr
« Reply #39 on: Thu, 22 May 2014, 23:02:47 »
This layout where the Fn layer is nearly identical to the Poker II:
Offline Techhobbiest
« Reply #40 on: Thu, 22 May 2014, 23:45:50 »
The "legal keyboard" I posted about in the DIY section
Offline diqkiq
« Reply #41 on: Mon, 26 May 2014, 11:58:31 »
Where's the bayonet? Not combat ready!
Filco Majestouch TKL, Noppoo Choc Mini, Realforce 87 55g, Model M TKL, Ducky Shine 3 TKL, KC60, Planck.
« Reply #42 on: Mon, 26 May 2014, 13:26:17 »
Plate option #2: http://geekhack.org/index.php?topic=57948
Offline ComradeSniper
  • HHKB Pro
« Reply #43 on: Mon, 26 May 2014, 13:47:07 »
HHKB Pro 2 HG  :'(
Offline ShriekBob
« Reply #44 on: Mon, 26 May 2014, 14:40:32 »
Mine would be a tented ergodox with a wrist rest, maybe smaller thumb clusters, Green or Clear switches.
Luckily that's what I'm building.
Otherwise, an M-15.
« Reply #45 on: Mon, 26 May 2014, 14:43:56 »
GON NS87
Offline dante
« Reply #46 on: Mon, 26 May 2014, 14:50:28 »
Variable Topre Typeheaven
Offline Lain1911
  • God of the Wired
« Reply #47 on: Mon, 26 May 2014, 15:23:21 »
Offline Hypersphere
« Reply #48 on: Mon, 26 May 2014, 16:22:52 »
HHKB Pro 2 form factor and layout with IBM capacitive buckling spring switches (like those in the IBM Model F XT). This would be like the IBM "Kishsaver" but more compact.
Offline nickr
« Reply #49 on: Mon, 26 May 2014, 17:17:16 »
