Author Topic: Ducky Mini - We've received a sample!  (Read 22013 times)
Offline JoshMK
  • * Commercial Vendor
  • MechanicalKeyboards.com
« on: Fri, 23 May 2014, 13:19:30 »
Ducky sent us a Mini to test/use/sample and I must say, I LOVE it.
First and foremost, I am no expert in keyboards nor journalism. I'm just your average mechanical keyboard lover and these are my opinions and observations.
To be honest, I was a bit disappointed when I saw the production model online. I prefer the simpler look of the Mini v.1, Poker/Pure, etc. However, those feelings have been thrown out the window! In person this board is a thing of beauty and the aluminum surrounding looks great. They are what I'll call 4 layers for this situation:
Layer 1 (bottom) has the base of the board, feet, etc, and it's plastic. Level 2 and level 4 (top) are 3mm slabs of aluminum with a 9mm plastic (layer 3) piece sandwiched in between.
The overall dimensions : 12" W x 5" D x 1.25" H (305mm W x 127mm D x 31.75mm H)
Weight : 1lb, 10oz (730g)
The keys feel very sturdy and relatively quiet. There's no odd thud or audible spring noises. Hopefully they'll also release a "mini wrist rest", as the TKL wrist rest is 15" long.
The function layer is set up quite nicely. No matter what mode you're in (even LEDs completely off), when you press the Fn button, the function layer is illuminated. There's a secondary function layer with Fn+Alt that deals with the lighting.
Although I'm not the biggest fan of LED boards, this one's quite wonderful.
Mode 0 : LEDs off
Mode 1 : All LEDs on. You can adjust the color. This is a dual LED (blue/red split LED for each key) so you can have blue, red, or any combo of both.
Mode 2 : Wave left to right. Blend of blue, red, pink, purple, etc.
Mode 3 : Wave top to bottom. Blend of blue, red, pink, purple, etc.
Mode 4 : Breathing. Blue -> Red -> Pink -> Blue
Mode 5 : "Random"? A new LED mode that lights up keys at random with different colors.
Mode 6 : "Random V.2"? All LEDs are lit, but change color every second or so.
Mode 7 : Reactive. LED activated when key is pressed.
Mode 8 : Seems same as Mode 7?
Videos :
Mode 5 :
Mode 7/8 :
Mode 23 (0-11 sec / 12-21 sec) :
Please note... the LEDs are MUCH more vivid in person than on those vids.
There is some customization, however this may or not be the final production model, so I won't go into that quite yet.
Pricing will be very competitive with other 60% boards. We're currently expecting blue and red MX at the end of June with black/brown MX a little later.
And no, this sample won't be available for purchase.
If you have any comments, concern, or questions, just reply here! You can also email/PM me!
Josh McConnell
Josh@mechanicalkeyboards.com
615.266.1420 ext303
Offline dante
Re: Ducky Mini - We've received a sample!
« Reply #1 on: Mon, 26 May 2014, 11:38:48 »
Can you post a chart of all the keyboard short cuts? (ie: Arrow navigation, page up/down, etc...)
« Reply #2 on: Mon, 26 May 2014, 15:11:39 »
Wow - fantastic!  I SAID it was aluminium case! :p
Mode 5 lighting it too hypnotic - I can see myself activating it and just staring at it for hours (at work when things get quiet) :))
For reference, it seems the HHKB weighs around 530g (1 lb 3oz), so this would be noticeably heavier.
Does it seem to slide around much on the desk?
Edit: Also the bottom row seems to be 1.25x across the board - is the space bar 6.25x with standard stems?  I can't really see Ducky doing anything else, but doesn't hurt to ask.
« Last Edit: Mon, 26 May 2014, 15:13:37 by rowdy »
Offline Lain1911
  • God of the Wired
« Reply #3 on: Mon, 26 May 2014, 15:16:29 »
I'm interested!
Offline dante
« Reply #4 on: Mon, 26 May 2014, 15:44:08 »
One other question in addition to my quoted one : Can the left/right alt be switched with FN?
Offline yuiop
« Reply #5 on: Mon, 26 May 2014, 16:47:05 »
Looks fantastic.  I don't mind the extra bulkiness for 60% board.
I just hope it doesn't cost too much.
Will this have a plate?
Offline Zombly
  • Zombie Enthusiast
« Reply #6 on: Tue, 27 May 2014, 09:35:32 »
Looks stunning, might be interested depending on price. :O
In the process of my custom Zombie board
[WTB MX Zombro's]
Offline joneslee85
  • HHKB Scrub JP
  • Professional Rubyist programmer!
    • Ruby Journal
« Reply #7 on: Tue, 27 May 2014, 09:38:07 »
Nice keyboard, can you write about your exp with mouse movement keys?
TOO MANY KEYBOARDS THAT I COULD NOT COUNT! BUT I AM STILL USING MY MODEL F77
Offline Latin00032
« Reply #8 on: Tue, 27 May 2014, 12:46:24 »
Will this be plate mounted? If so, is the plate mounted into the case sides or is it supported by the switches?
« Reply #9 on: Tue, 27 May 2014, 12:50:40 »
Has ducky ever produced a board that wasn't plate mounted?
Offline dante
« Reply #10 on: Tue, 27 May 2014, 12:55:15 »
Some might argue the XM Alps boards weren't really plate mounted :D
Offline gcb
« Reply #11 on: Tue, 27 May 2014, 13:07:06 »
> mode 7/8
> some thing very wrong happens
...looks down to see the key you didn't expect you had typed just fade out, mockingly
the breathing/disco floor modes would be awesome if they could be tied to scroll lock light or something, so you could set it via software...   receive IM... keyboard lights up with motion... That would be awesome. and minimally useful...
« Last Edit: Tue, 27 May 2014, 13:13:25 by gcb »
« Reply #12 on: Tue, 27 May 2014, 13:57:09 »
Sample won't be for sale because you'll never let it go! :p
I'm really diggin' that board, if only I wasn't an hhkb fanboy!
Offline JoshMK
« Reply #13 on: Tue, 27 May 2014, 16:35:09 »
I can and I will. Give me a day or so to catch up from the 3-day weekend.
Mode 5 is spectacular. I'm not a huge fan of LED boards, but this mode is something else.
This is no doubt a heavy board. Excellent weapon if needed.
It actually doesn't slide well at all. It has 4 rectangular rubber feet that are mighty soft and stick well to my wooden desk.
Yes, the SB is 6.25x
Ehhh... "silly"? I don't understand the use as I'm much quicker and more accurate with the mouse that's 6" away from the board. However, I suppose people were interested in the function or Ducky wouldn't have included it.
Cost will be below similar 60% boards.
And yes, it's plate mount.
Josh McConnell
615.266.1420 ext303
Offline Mercury7
« Reply #14 on: Tue, 27 May 2014, 20:07:37 »
Any word on the possibility of clears?
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #15 on: Tue, 27 May 2014, 22:24:46 »
YES having the option of Clears should make this keyboard one of those MUST HAVE's here on Geekhack  :thumb: .  Please make this happen officially before it's finally released.
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Moderator
  • The 00verseer of Vault 77
    • Mechanical Keyboards
« Reply #16 on: Wed, 28 May 2014, 13:00:22 »
AKA: Topre Posterboy?
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
« Reply #17 on: Wed, 28 May 2014, 13:08:47 »
I wish!
Offline file_id
« Reply #18 on: Wed, 28 May 2014, 15:07:24 »
will there be availability for preorders?
DS3 White YOTS (Blue)|Poker 2 (Blue,Clear)|QFR Rapid-i TKL (Brown,Blue)|QFR Rapid TKL (Blue,Red,Brown)|KBP V60 (Blue,Clear,Matias Click)|Code TKL Clear|Filco MJ2 TKL (Blue)|Filco MJ2 Ninja Beige TKL (Brown)|Novatouch
Offline JoshMK
« Reply #19 on: Wed, 28 May 2014, 15:42:07 »
Yes, of course! However, the current ETA is "June-July". Stay tuned  :thumb:
Josh McConnell
615.266.1420 ext303
Offline dante
« Reply #20 on: Wed, 28 May 2014, 20:21:18 »
As always, people aren't made out of money but having a few bucks thrown on top of the price is better than not having the option at all..
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #21 on: Thu, 29 May 2014, 13:32:58 »
I'd love to see a take apart of this keyboard. Or better yet, take it apart myself.  :p
Offline ideus
  • Björkö.
« Reply #22 on: Thu, 29 May 2014, 13:38:27 »
Is it just me, or it looks like a Poker in a fancy case?
Offline mashby
    • Mashby
« Reply #23 on: Thu, 29 May 2014, 13:39:40 »
That's one of the reasons I want to take it apart.  :p
Offline badloop
« Reply #24 on: Thu, 29 May 2014, 15:22:13 »
I'm surprised Mashby hasn't done this already, but I am so tempted to just drive to mechanicalkeyboards.com's office and try this thing out.  I'm guessing I wouldn't make it past security....  :))
PBT FTW
Offline Latin00032
« Reply #25 on: Thu, 29 May 2014, 15:30:43 »
That's why I asked about the plate mounting.
I was hopping it was going to be  plate mounted similar to other Korean type boards where the plate is supported by the case and not by other switches.
Offline bahamot
    • bistropolis - dine with style
« Reply #26 on: Wed, 04 June 2014, 03:20:09 »
Is it possible to fit the mini into poker custom case?
Edit: nevermind, it isn't compatible.
« Last Edit: Wed, 04 June 2014, 03:53:45 by bahamot »
Offline blithen
« Reply #27 on: Wed, 04 June 2014, 03:28:23 »
Ho' man. My want is so much...I need this board... Need. :|
Offline file_id
« Reply #28 on: Wed, 04 June 2014, 23:17:54 »
Any confirmation on whether this is plate mounted or PCB?
Offline 00zeRO
  • * Moderator
« Reply #29 on: Wed, 04 June 2014, 23:20:17 »
I am fairly certain it is plate mounted since all currently produced Duckys are plate mounted. I will check tomorrow, when I go in to work... :thumb:
Offline blithen
« Reply #30 on: Mon, 09 June 2014, 01:56:45 »
Any eta?
Offline qwack
« Reply #31 on: Mon, 09 June 2014, 07:40:49 »
Really interesting. Is the LED intensity adjustable, and if so, on how many levels ?
Also, you say that the price will be more or less the same as comparable 60% boards, so can we expect it to be priced about the same as a Pure Pro, or is it in a different league entirely ?
Pure Pro w/MX Red - [review]
Offline file_id
« Reply #32 on: Sat, 21 June 2014, 05:03:52 »
Timeframe for these still in June?
Offline sacratoy
    • Twitch
« Reply #33 on: Sun, 20 July 2014, 16:09:24 »
It looks like PC Case Gear has them up for pre-order with an estimated arrival date of August 29th 2014. http://www.pccasegear.com/index.php?main_page=product_info&cPath=113_1361&products_id=28247&zenid=0ea1b4639714f8a2b05304297a157e60
Any new news from y'all? I'd prefer to order from you guys.
« Last Edit: Sun, 20 July 2014, 16:17:38 by sacratoy »
Poker II
Offline JoshMK
« Reply #34 on: Sun, 20 July 2014, 17:14:42 »
We've had our up for pre-order for a week or longer now.
Assuming you want a blue MC / gray case : http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=952
Josh McConnell
615.266.1420 ext303
« Reply #35 on: Sun, 20 July 2014, 17:20:33 »
Both you and PCCG have only MX blue and MX red - do you know if Ducky Mini will be available with MX black or green?
Offline JoshMK
« Reply #36 on: Sun, 20 July 2014, 20:26:39 »
All Ducky told us was blue/red were all that will be available at this time due to a shortage of black and brown. I don't know if those will be released later, or not at all. Same with any other switch types.
Josh McConnell
615.266.1420 ext303
Offline sacratoy
    • Twitch
« Reply #37 on: Sun, 20 July 2014, 20:26:56 »
I'm a dumb. Thanks for the link, Josh.
Poker II
« Reply #38 on: Sun, 20 July 2014, 20:31:51 »
I guess each switch goes through their shortage period.
Thanks for the update! :)
Offline dante
« Reply #39 on: Sun, 20 July 2014, 20:36:38 »
Is the listed depth of 1.25" correct?  On Ducky's website it states that they lowered the switches down as far as they would go yet by the specification on MK the depth is the same as all other boards they sell.
Offline cmadrid
« Reply #40 on: Sun, 20 July 2014, 21:29:14 »
Cherry needs to MAKE MOAR SWITCHES :(
