Author Topic: "any" key  (Read 10141 times)
Offline blackbox
"any" key
« on: Sat, 24 May 2014, 06:42:23 »
Does anyone now if there are a keycap that has "any" printed on it? Someone could maybe put in on shapeways if it dosent.
The LAN table!
Re: "any" key
« Reply #1 on: Sat, 24 May 2014, 06:49:56 »
I'm pretty sure SP/PMK used to have one, but I can't see it on their new site.
Looks like WASD can do one for you.
Edit: sorry, forgot the link: http://www.wasdkeyboards.com/index.php/products/printed-keycap-singles/custom-text-cherry-mx-keycaps.html#ad-image-0
« Last Edit: Sat, 24 May 2014, 06:55:13 by rowdy »
Offline Tarzan
  • formerly known as Greystoke
Re: "any" key
« Reply #2 on: Sat, 24 May 2014, 06:54:39 »
I think there's been a couple of group buys that had an "Any Key" keycap.  Maybe 7bit's Round3?  I had one myself, but I gave it away.
Check out the classifieds?
Offline blackbox
Re: "any" key
« Reply #3 on: Sat, 24 May 2014, 07:16:18 »
Nice! Thanks for the info!
The LAN table!
Re: "any" key
« Reply #4 on: Sat, 24 May 2014, 07:28:40 »
Imsto sells these
Offline Mr.Tumor
Re: "any" key
« Reply #5 on: Sat, 24 May 2014, 07:45:53 »
Ducky zero dk2108s  OMG
Re: "any" key
« Reply #6 on: Sat, 24 May 2014, 08:10:15 »
- Bill Roberts 2026-06-17
Offline Pacifist
  • on hiatus
Re: "any" key
« Reply #7 on: Sat, 24 May 2014, 21:16:14 »
key is sort of implied...but any key could be anything
Re: "any" key
« Reply #8 on: Sat, 24 May 2014, 21:20:28 »
How about a **** key.  I may make one of those at some point.
Offline Pacifist
  • on hiatus
Re: "any" key
« Reply #9 on: Sat, 24 May 2014, 21:22:20 »
wasn't that already made?
http://geekhack.org/index.php?topic=57104.msg1294882#msg1294882
« Last Edit: Sat, 24 May 2014, 21:24:16 by Pacifist »
Re: "any" key
« Reply #10 on: Sat, 24 May 2014, 21:27:09 »
Well, I did make a key crap, then someone else made the less cleverly named crap cap, but no one has done a **** key.  It was something I've been thinking about doing as a joke.
Re: "any" key
« Reply #11 on: Sat, 24 May 2014, 21:40:58 »
SP has an Oh **** key.
Offline Grendel
Re: "any" key
« Reply #12 on: Sun, 25 May 2014, 02:56:58 »
Owned by the profanity filter.. ;D
- I'm game !
Offline blackbox
Re: "any" key
« Reply #13 on: Sun, 25 May 2014, 04:40:42 »
Seems like none of the suggestions has a key that just says "ANY" as fohat.digs mentioned.
The LAN table!
Re: "any" key
« Reply #14 on: Sun, 25 May 2014, 04:48:17 »
WASD can make one for you with any custom text.
Only if you have it turned on :p
