Author Topic: Steelseries 7G  (Read 2192 times)
Offline AmitB
Steelseries 7G
« on: Fri, 30 May 2014, 15:56:52 »
hey guys so today I've noticed that my l[ el ] button doesn't work.
I've tried to open up the keyboard and didn't manage.
probably i've put too much pressure on the soldering iron and it broke...
so my question is how the hell do I open up the plastic surface of the keyboard?I got all 4 screws out and still it's hard as rock,can't move it inch
is it possible to fix? the switch broke as well so I need new switch, black one.
http://www.wasdkeyboards.com/index.php/products/keyboard-parts/cherry-mx-black-keyswitch-mx1a-11nn-linear.html#ad-image-0
this one is fine?
Thanks guys ;]
Offline blackbox
Re: Steelseries 7G
« Reply #1 on: Fri, 30 May 2014, 18:39:41 »
the one you linked is fine. Check the case for any plastic taps that might hold the case together (look at how coolermaster has designed their keyboards). I think this thread should be moved to keyboards.
The LAN table!
Offline AmitB
Re: Steelseries 7G
« Reply #2 on: Sat, 31 May 2014, 00:50:14 »
Thanks a lot! i've disassembled it  and the ironing is really easy.
Offline blackbox
Re: Steelseries 7G
« Reply #3 on: Sat, 31 May 2014, 03:45:56 »
Np
The LAN table!
