Author Topic: NEW: OTG Cables @ PEXON PCs  (Read 95549 times)
Offline pexon
  • * Moderator
  • El Jefe of Sleeving
    • Pexon PCs
« on: Sun, 01 June 2014, 13:25:07 »
Hi dudes and dudettes, added a new product this afternoon, OTG cables. As ever, lots of options, lengths and colours to choose from!
Take a look here:- http://pexonpcs.co.uk/products/otg-cables
« Last Edit: Mon, 01 December 2014, 12:47:49 by pexon »
Offline blackbox
Re: NEW: OTG Cables @ PEXON PCs
« Reply #1 on: Wed, 26 November 2014, 11:36:25 »
Nice! That's my next otg cable
The LAN table!
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #2 on: Wed, 26 November 2014, 11:43:23 »
OTG Cables are so much fun. Been using my HHKB with one on my HTC One for a while now
Offline Lubed Up Slug
« Reply #3 on: Sun, 30 November 2014, 19:24:11 »
When buying an OTG cable is it just the female USB A to male USB micro (mini? I can never remember which is which) or is the male USB A to male USB mini included? Because on your site two cables are pictured.
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #4 on: Sun, 30 November 2014, 23:22:25 »
Take a look here:- http://pexonpcs.co.uk/OTG
Hey Pexon, just wanted to give you a heads up that this link brings me to a 404.
GON NerD TKL DTA Edition
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #5 on: Mon, 01 December 2014, 12:47:34 »
« Reply #6 on: Thu, 29 January 2015, 19:38:15 »
Can you make a short micro-mini USB cable with all 5 pins connected at both ends?  I'd like to use my tablet with a JD40 while it's charging but it needs a resistor between pins 4 and 5 to charge, then shorted for data.  If all 5 pins were available in the keyboard it will be easy to add a switch in there but all the cables I've chopped up only have 4 wires.  It's a good excuse to get a nice pretty cable too :D
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #7 on: Fri, 30 January 2015, 04:00:32 »
I can do that sure! Do you have a value for the resistor? I wasn't sure that you could use the cable to charge AND use the keyboard with it though on OTG?
« Reply #8 on: Fri, 30 January 2015, 16:00:52 »
Apprently 100kohm will do but according to the spec it should be 125kohm.  I'm quite happy to experiment, a fully wired cable will be enough to do so :)
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #9 on: Fri, 30 January 2015, 16:57:09 »
Are you sure dude? I could leave the connector off on the host side if needs be so you can have a play?
« Reply #10 on: Fri, 30 January 2015, 18:16:06 »
The host end needs to look good while the keyboard already has a 5 pin connector and space for the resistor and switch, so unless you know of any reason why the OTG connection needs to be right near the host this seems like the way to go.  At worst I end up with a slightly thicker than normal cable but it should still work like any other as nothing is expecting the extra connection, if I'm understanding it right (OTG didn't exists when I did USB for my dissertation at uni...)
Please let me know how I can order this cable and I will do so :)
