Author Topic: Sticky buckling spring  (Read 3597 times)
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« on: Sun, 01 June 2014, 22:01:11 »
The m key on my model m has been acting up recently. It's really stiff, and has a habit of sticking as it's coming back up, sometimes stopping entirely at the bottom.
Offline 1391406
Re: Sticky buckling spring
« Reply #1 on: Sun, 01 June 2014, 22:02:46 »
Have you tried re-seating it?
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #2 on: Sun, 01 June 2014, 22:22:50 »
quite a few times
Offline 1391406
« Reply #3 on: Sun, 01 June 2014, 22:30:31 »
I'd try swapping it with another key to see if it's the keycap or the barrel.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #4 on: Sun, 01 June 2014, 22:33:52 »
tried that also.
Offline BlueBär
« Reply #5 on: Mon, 02 June 2014, 04:02:44 »
tried that also.
And the result was...? I assume it wasn't the keycap? Check if the barrel looks broken. Might be a defect hammer/spring, too.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #7 on: Mon, 02 June 2014, 06:44:48 »
It still clicks, when I swap it with another, it's still pretty sticky
Offline BlueBär
« Reply #8 on: Mon, 02 June 2014, 06:54:22 »
OK so it's not the keycap. If it's the spring/hammer you can replace those, but it requires some work. A broken barrel would be worse, if at all fixable.
Offline 1391406
« Reply #9 on: Mon, 02 June 2014, 07:33:20 »
Look at the barrel and spring under good lighting and see if you can identify any inconsistencies compared to other barrels and springs. If the problem is close to the pivot plate, you might not be able to see it.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #10 on: Mon, 02 June 2014, 15:28:58 »
At this point, I think it might just be the set, because the "t", "i", and "r" are acting up too now.
Offline 1391406
« Reply #11 on: Mon, 02 June 2014, 18:26:49 »
Did you buy a new set recently?
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #12 on: Mon, 02 June 2014, 18:43:28 »
no, I bought it off someone here a little while ago, although I'm getting another m anyway so I'll stick some of caps on and see is that helps
