Author Topic: [GB] The Smallfry Keyboard Kit (Closed for Orders, 97% shipped. SEE LAST POSTS)  (Read 526723 times)
Offline domoaligato
Re: [GB] The Smallfry Keyboard Kit
« Reply #651 on: Fri, 15 August 2014, 11:37:09 »
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #652 on: Fri, 15 August 2014, 13:11:27 »
So. Chemist, how do you mod them?
http://geekhack.org/index.php?topic=51792.msg1171989#msg1171989
Haha, I am embarrassed by how ghetto that video is.  I was having a hell of a time trying to get my phone's camera to focus on what was in my hands.  Oh well....
Offline PandaSPUR
« Reply #653 on: Fri, 15 August 2014, 13:54:14 »
I did the same mod to my switches in preparation for this build ^-^
IM READY.
Home:
Das Keyboard - MX Browns - Vortex Grey Side-Printed PBT Caps
Work:
KBT Pure - iKBC Aluminum Case - MX Reds
Vortex Poker II - Frosty on Lime Acrylic Case - MX Clears
Offline tahuds
« Reply #654 on: Fri, 15 August 2014, 22:57:27 »
mkawa, any updates for us this week?
I have beerology feedback from sales on the arstechnica.com forum going back to 2007 at the link-  http://www.beerology.com/view.cfm?id=3848
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #655 on: Sat, 16 August 2014, 09:39:41 »
wires were crossed on getting the samples to me. i'm going to start the first cuts, because i know the bottom plates can be cut, and then, depending on my cutter's cut schedule, drive down to LA to retrieve samples, measure them out with my cutter, talk to JD and then trigger the whole run if things look good.
if he can make the first cuts this week, i'm going to head down this week. otherwise, i'm going to head down next week. it also depends on the body shop's schedule, as i will need to pick up my car from the shop in norcal when it's done.
« Reply #656 on: Sat, 16 August 2014, 12:30:48 »
Man I want those purple plates so bad! >_< sexy!
Offline Firebolt1914
  • POM Overlord
« Reply #657 on: Sun, 17 August 2014, 13:41:14 »
mkawa, can you confirm that order #1118 is set for both plates being dark blue?
Offline mkawa
« Reply #658 on: Sun, 17 August 2014, 15:31:27 »
confirmed. let me regenerate that column projection..
Offline mkawa
« Reply #659 on: Sun, 17 August 2014, 15:35:19 »
my god, filter views are way too complicated.
Offline henz
  • What?
« Reply #660 on: Mon, 18 August 2014, 15:29:49 »
exsqueeze my noobiness but how do you write numbers and use function keys on it? or are there none? thinking of ordering this for just having something to solder ;D
Offline Ceedog
  • sup.
« Reply #661 on: Mon, 18 August 2014, 15:31:26 »
There is an Fn layer. You hold down the Pn/Fn key and use Q as F1, A as 1, etc. JD posted the layers elsewhere.
GODLIKE SmallFry in progress.
« Reply #662 on: Mon, 18 August 2014, 15:31:38 »
function layers
You can read more here http://geekhack.org/index.php?topic=47133.0
« Last Edit: Mon, 18 August 2014, 15:35:38 by SpAmRaY »
Offline mkawa
« Reply #664 on: Tue, 19 August 2014, 22:02:04 »
good: i have sample cuts
bad: my sample switches are an hour away
gahghaglkrkehgae
Offline Zeal
    • Zeal Generation Inc.
« Reply #665 on: Tue, 19 August 2014, 23:53:13 »
gahghaglkrkehgae
Quick, find an old board to desolder!  :p
Offline mkawa
« Reply #666 on: Wed, 20 August 2014, 14:41:41 »
the samples look _REALLY_ good by the way, and measure out extremely well. i'm going to do a test fit this afternoon and then kick off all the cutting.
« Reply #667 on: Wed, 20 August 2014, 15:37:20 »
teaser pics?
Offline fatchoi
« Reply #668 on: Wed, 20 August 2014, 19:32:54 »
Awesome. ;)
Looking forward
Offline Zeal
« Reply #669 on: Wed, 20 August 2014, 23:02:26 »
Offline mkawa
« Reply #670 on: Thu, 21 August 2014, 00:03:53 »
well, i spent like 3 hours driving today, but i've test fit into the samples and they are per-fecto. going to give the go ahead and work out nesting with the cutter tomorrow.
Offline byker
  • Literally Canada
« Reply #671 on: Thu, 21 August 2014, 00:16:48 »
Sweet! Thanks a lot for all of your work mkawa! I know I am super excited for these!  :p
Offline Greeeg
« Reply #672 on: Thu, 21 August 2014, 00:30:42 »
There has been a lot of delays with this project.
I am greatful for transerancy qnd all your updates mkawa, it's clear that you're working hard.
I think I speak for all when I say, I can't wait to have this on my desk. ^_^
And thank you for all your effort mkawa. :)
  • POM Overlord
« Reply #673 on: Thu, 21 August 2014, 07:40:13 »
teaser pics please  :D
Offline mkawa
« Reply #674 on: Thu, 21 August 2014, 14:12:58 »
the cutter is working on nesting capacity right now.
Offline tahuds
« Reply #675 on: Thu, 21 August 2014, 18:37:46 »
What alloy of titanium are the plates being made of?
Offline Zeal
« Reply #676 on: Thu, 21 August 2014, 19:28:57 »
Any machine pr0n teaser pics allowed? :p
Offline mkawa
« Reply #677 on: Thu, 21 August 2014, 23:04:33 »
CP4 ASTM B265
it is _unalloyed_ titanium, the highest purity available commercially.
Offline mkawa
« Reply #678 on: Thu, 21 August 2014, 23:06:32 »
i have been running around so much that i still have unindexed pictures on my camera from keycon. i want to record another video update. will try to get something together soon
Offline orangeju1ce
« Reply #679 on: Sat, 23 August 2014, 19:48:23 »
Hello!
I'm quite new here.
I tried googling this but I couldn't any information about the notched top plates.
excuse the noob question, but does this mean you don't need to solder the switches to the pcb board? i'm not sure how this works..
I might need some pictures or a video on this.
Offline Ceedog
  • sup.
« Reply #680 on: Sat, 23 August 2014, 19:54:21 »
You need to solder in the switches, but simple tools like tweezers can be used to remove the top of the switch, allowing you to change stems and springs as desired. Bottoms of switches are identical on all types.
Offline Jixr
« Reply #681 on: Mon, 25 August 2014, 09:56:59 »
whats the difference between this GB and the JD40 on the CTRL ALT store?
Offline byker
  • Literally Canada
« Reply #682 on: Mon, 25 August 2014, 09:57:29 »
The plates are titanium and anodized.
Offline daddytime
  • Tell Daddy.
« Reply #683 on: Mon, 25 August 2014, 09:58:19 »
And it's for a good cause
Tell Daddy.
Offline tyvar1
  • Otto is a Rhino!
    • Reddit
« Reply #684 on: Mon, 25 August 2014, 11:08:14 »
CTRL ALT sells a complete built one. So for us who can't build it themselves it's a good option.
I got a question. Is there any chance to use a international JD40? With هنِ?
Offline Jixr
« Reply #685 on: Mon, 25 August 2014, 12:29:06 »
okay, thats what I need to know.
I'm thinking about the board, but the assembly process is a little more than I think I can do myself. And I have no idea how to program a tensy.
Offline Ceedog
  • sup.
« Reply #686 on: Mon, 25 August 2014, 15:12:30 »
You only have to flash the teensy with the firmware someone else already made. Mkawa may even be able to do it for you, but you'd have to ask him.
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #687 on: Mon, 25 August 2014, 15:33:07 »
Looky here:
http://geekhack.org/index.php?topic=51252.0
Offline mkawa
« Reply #688 on: Mon, 25 August 2014, 16:31:52 »
at the current teensy order numbers i can definitely program all of them. no prob
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #689 on: Mon, 25 August 2014, 16:37:16 »
Does the easy avr firmware deal going to support this PCB?  I remember hearing talk about it but don't remember what the final answer was for this version.
Offline Ceedog
  • sup.
« Reply #690 on: Mon, 25 August 2014, 16:38:05 »
Metalliq says it's compatible, but untested.
Offline Melvang
« Reply #691 on: Mon, 25 August 2014, 16:39:52 »
Cool thanks for the quick reply.  I would assume the untreated part is due to none in the wild with the exception of prototypes of mkawas?
Offline Ceedog
  • sup.
« Reply #692 on: Mon, 25 August 2014, 16:41:34 »
There are definitely a few out there now that CTRL[ALT]'s version has shipped, so I'd assume they're running the firmware.
« Reply #693 on: Mon, 25 August 2014, 16:41:58 »
The latest beta version already supports it. :)
Offline PandaSPUR
« Reply #694 on: Mon, 25 August 2014, 17:08:29 »
Anyone have any plans on how they want to add LEDs to this thing?
I really want to but I was just thinking about how annoying soldering 40 tiny resistors on wires will be...........
Home:
Work:
Offline ImAWildDeer
  • All about that click clack
« Reply #695 on: Mon, 25 August 2014, 20:30:40 »
Can I still order one of these?
HHKB | Ergodox Infinity | OG Ergodox | Atreus | Planck | WASD V2  | Whitefox | TX1800 | F62
Offline mkawa
« Reply #696 on: Mon, 25 August 2014, 23:14:44 »
yep!
Offline Ceedog
  • sup.
« Reply #697 on: Mon, 25 August 2014, 23:21:04 »
So kawa, will be getting that video update this week?
Offline mkawa
« Reply #698 on: Mon, 25 August 2014, 23:30:47 »
i am hoping to have enough time tomorrow to bug the cutter to give me the nesting data. i have to do some arithmetic to calculate cost, material bulk, and correlate that with the number of orders with and without notched plate upgrades. once i have those numbers, i will be able to say something substantial to you guys. right now it is actually just "yep, i QCed the sample cut and it was awesome, so we're going to cut.. any.. day.. now.."
:P
what i can say those is that i had an email chat with largefry wherein i gave him the magnitude of the donation that this project will be able to make to the foundation, and he was blown away (as I am every day i realize that we're doing this :D). anyway, long story short, he's going through the final paperwork to get the foundation set up. once that is all submitted, there is the usual wait to incorporate and obtain 510(c)(3) status in the eyes of the IRS.
finally, JD has the ptfe coated sample of the gasket and he thinks it is a large improvement over the original samples, but he's afraid that the coating might be too thin. i've contacted the sorbo guys about this and they are mulling it over. they felt this was the best solution (they are aware both of the charity aspect AND the keyboard design aspect of the project and have been beyond awesome about it), but they do have anything coating option, and from experience i know that even ptfe coating thicknesses can be manipulated by varying parameters of the process (ptfe usually is extremely homophobic, but it's also more or less amorphous -- the big problem is that in order to get it to a nice coating consistency, you have to cause degradation by heating it up such that it releases toxic gases)
Offline Ceedog
  • sup.
« Reply #699 on: Mon, 25 August 2014, 23:33:12 »
Ah, well it looks like you have a lot on your plate then; I was under the impression you were just waiting like the rest of us. Thanks for all your hard work!
