Author Topic: [GB] The Smallfry Keyboard Kit (Closed for Orders, 97% shipped. SEE LAST POSTS)  (Read 526730 times)
Offline abjr
    • abjr.org
Re: [GB] The Smallfry Keyboard Kit
« Reply #700 on: Tue, 26 August 2014, 11:33:38 »
I might be in the minority, but I'm in no rush. I still need to learn to solder first!  :-[
CM QFR | magicforce 68 (Gateron) | magicforce 68 (Outemu) | Acros 6311-K
Offline worldspawn
« Reply #701 on: Wed, 27 August 2014, 08:05:13 »
I really just want one of the PCB's for this, is there any way to get just that?
I can make acrylic laser cut cases/plates PM for info
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #702 on: Wed, 27 August 2014, 08:06:51 »
It seems extra PCBs are only available with the purchase of a whole kit.
Read here:
http://www.geekhackers.org/collections/keyboard-accessories/products/smallfry-kit-extra-pcb-upgrade
Offline worldspawn
« Reply #703 on: Wed, 27 August 2014, 08:33:38 »
Read here:
Sooo, does somebody ordering one want to get an extra PCB and sell it to me?
Offline Yslen
« Reply #704 on: Wed, 27 August 2014, 08:38:15 »
I'm trying to pass on my whole order, but it does include an extra pcb if you just want to buy that part.
Edit: assuming this is deemed okay by mkawa of course
« Reply #705 on: Wed, 27 August 2014, 08:52:11 »
PCB won't be useful without a plate. There are no holes in the PCB for mounting PCB-mount switches, nor for a PCB-mount stabilizer. Switches and stabilizer must be plate mounted.
Offline worldspawn
« Reply #706 on: Wed, 27 August 2014, 08:59:42 »
I have a laser cutter, I can make my own plates.
« Last Edit: Wed, 27 August 2014, 09:28:33 by worldspawn »
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #707 on: Wed, 27 August 2014, 11:33:58 »
i'm going to send the second pcb to the person who buys your kit. of course, what happens to the pcb after that is up to the buyer.
Offline Yslen
« Reply #708 on: Wed, 27 August 2014, 11:40:26 »
Okay, no problem.
Offline Firebolt1914
  • POM Overlord
« Reply #709 on: Thu, 28 August 2014, 11:12:46 »
Can I change my color choice or is it too late?
Offline mkawa
« Reply #710 on: Thu, 28 August 2014, 11:13:21 »
not even close to too late. just fill the form out again
Offline tyvar1
  • Otto is a Rhino!
    • Reddit
« Reply #711 on: Sat, 30 August 2014, 04:32:17 »
Is there anyone who know if there is any special caps sizes on this board?
Offline Ceedog
  • sup.
« Reply #712 on: Sat, 30 August 2014, 08:39:39 »
On the order page, there is an image detailing keycap sizes for the board. I'd advise getting a flexible keycap set like blank or Granite DSAs if you want a full matching set.
GODLIKE SmallFry in progress.
Offline r3nfr0
« Reply #713 on: Sat, 30 August 2014, 08:40:44 »
Cool. I have some blanks and a set of DOLCH double shots.
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #714 on: Sat, 30 August 2014, 09:23:57 »
I apologize if this question has been asked and answered on one of the 40 pages of the three or four JD40/SmallFry keyboard threads, but...
What is the specific deal with soldering the CAPSLOCK LED jumper?
I know the answer is posted somewhere, but now that I have the kit, I cannot find that post anywhere.  I think I just need to jump from one of the outside pads to the positive LED pad, but from which one (and why)?
I apologize if this should have been posted in an ALT40 or a JD40 thread, but this thread seems to be the most active and they are all the same PCB.
Thanks to whomever can answer the question.  This is my next soldering task before I seal the plate over the board with 80 switch connections.  And almost every other kit buyer will have this question.
 - Ron | samwisekoi
Offline strict
  • TKL Zealot
« Reply #715 on: Sat, 30 August 2014, 09:44:36 »
 - Ron | samwisekoi
You're correct, you just need to bridge the two adjacent through-holes with traces leading to them to the LED holes. Here's a picture of how mine looks. I would also recommend using SIP sockets so you can still remove the LED to take apart the switch if needed.
« Last Edit: Sat, 30 August 2014, 09:46:39 by strict »
Offline tyvar1
  • Otto is a Rhino!
    • Reddit
« Reply #716 on: Sat, 30 August 2014, 09:51:44 »
Awesome! I will get Granite!
Offline mkawa
« Reply #717 on: Mon, 01 September 2014, 18:12:21 »
grumble grumble cutter grumble grumble.
the massdrop guys (baudlydamaged, lenkashman) have samples of both a populated titanium plate and an unpopulated notched plate. bug them for pictures! (while i'm in the middle of packing my life up and moving across the country XD)
Offline mkawa
« Reply #718 on: Mon, 01 September 2014, 18:16:26 »
QUESTION!
JD is feeling a bit unsure about the durability of the teflon sorbothane coating (for those who missed it, our initial samples were super sticky and hard to handle). the teflon layer on the sorbothane is somewhat delicate and can be scraped off. the other option is a urethane coating that is thick and tough, but not slippery like teflon and has a rough feel and appearance.
here is what that looks like: http://www.amazon.com/Sorbothane-Hemisphere-Non-Skid-Adhesive-Durometer/dp/B0042UA5WC/ref=sr_1_27?ie=UTF8&qid=1409613163&sr=8-27&keywords=isolate+it
can people weigh in on which kind of coating they'd prefer? i'd go with the more durable coating, but i'm not crazy about the aesthetics. teflon is obviously going to look much smoother than the bumpy urethane bidness
Offline r3nfr0
« Reply #719 on: Mon, 01 September 2014, 18:17:25 »
Durability beats looks every day for me.
Offline mkawa
« Reply #720 on: Mon, 01 September 2014, 18:18:17 »
i can't read that without having an image of my mind of a guy named durability pounding on a guy named looks
Offline Vibex
  • Love y'all
« Reply #721 on: Mon, 01 September 2014, 18:18:47 »
QUESTION!
Durability, not even a question.
Offline Ceedog
  • sup.
« Reply #722 on: Mon, 01 September 2014, 18:26:14 »
Durability. It's a shame that we can't get both, but from Vibex's input on stickyness, I'm happy without any chance of that happening.
Offline Vibex
  • Love y'all
« Reply #723 on: Mon, 01 September 2014, 18:28:20 »
Yeah, I had to completely remove the sticky sorbothane from my JD40. It just became to much of a dust magnet. It also kept getting stuck to my wrist wrest, and caused a bit of the coluor to get pealed away.
Offline jacobolus
« Reply #724 on: Mon, 01 September 2014, 18:42:59 »
I'm not getting one of these, so my opinion probably shouldn’t matter, but I think the durable option looks pretty good.
Offline byker
  • Literally Canada
« Reply #725 on: Mon, 01 September 2014, 18:44:35 »
Durability for me
Offline Zeal
    • Zeal Generation Inc.
« Reply #726 on: Mon, 01 September 2014, 18:46:28 »
Durability for sure.
Offline Greeeg
« Reply #727 on: Mon, 01 September 2014, 20:04:23 »
I'd prefer durability.
  • POM Overlord
« Reply #728 on: Mon, 01 September 2014, 20:17:00 »
Same, I'd prefer durability
Offline Grendel
« Reply #729 on: Mon, 01 September 2014, 20:22:54 »
Another vote for durability.
- I'm game !
Offline Vibex
  • Love y'all
« Reply #730 on: Mon, 01 September 2014, 20:24:21 »
I think this is pretty unanimous at this point. Durability is more important then the aesthetic.
Offline PandaSPUR
« Reply #731 on: Mon, 01 September 2014, 20:27:10 »
Especially the aesthetic wont even last once the teflon starts peeling.
Durability!
Home:
Das Keyboard - MX Browns - Vortex Grey Side-Printed PBT Caps
Work:
KBT Pure - iKBC Aluminum Case - MX Reds
Vortex Poker II - Frosty on Lime Acrylic Case - MX Clears
Offline mkawa
« Reply #732 on: Tue, 02 September 2014, 00:18:21 »
well that was easy
Offline zflamewing
« Reply #733 on: Tue, 02 September 2014, 03:44:44 »
While you kind of want to root for that poor underdog looks I'm squarely in durability's camp!  :p
DK9008 MX Blues | CM QFR MX Blues | CM XT MX Greens
Offline fatchoi
« Reply #734 on: Tue, 02 September 2014, 09:04:47 »
Durability!
Offline Lurch
« Reply #735 on: Tue, 02 September 2014, 09:18:31 »
+1 for durability
Quote from: Flyersfan1
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #736 on: Tue, 02 September 2014, 12:29:45 »
Durability.
  • POM Overlord
« Reply #737 on: Tue, 02 September 2014, 18:12:50 »
Might be a stupid question, but what is the layout with the function layers going to be? Or is it something that I am able to program myself. If that is the case, what would you guys do?
EDIT: Found it in another thread: http://i.imgur.com/FHn851M.png
« Last Edit: Tue, 02 September 2014, 18:42:55 by Firebolt1914 »
Offline PandaSPUR
« Reply #738 on: Tue, 02 September 2014, 20:31:37 »
Search for the original JD40 thread on here somewhere, quite a few people posted their setups. And yea, you can program it however you want.
Home:
Work:
Offline mkawa
« Reply #739 on: Thu, 04 September 2014, 17:36:40 »
waterjet cutting should be in progress now. i've cut off orders where we are, as i slightly overestimated yield per sheet. the numbers look good though for everyone except for the upgrade kits. for those, i need to run more sheets through the laser. now would be a good time to order 60 and 80% notched plates (HINT HINT)
Offline byker
  • Literally Canada
« Reply #740 on: Thu, 04 September 2014, 18:33:20 »
Great news mkawa! Do you have a rough estimate on when the entire package will be hopefully finished? Just wondering if i can expect this in october or earlier/later?
Offline cherpalla
« Reply #741 on: Fri, 05 September 2014, 10:26:35 »
NOT TO BE ANNOYING, but if anyone here hasn't seen the SmallFry artisan cap, check my sig. It's a great addition to the kit and profits go to support GH, Nate's scholarship fund and Share our Strength.
Also, you get some extra goodies with them, too.
c h e r
Offline Ceedog
  • sup.
« Reply #742 on: Fri, 05 September 2014, 10:39:54 »
Very cool. I'll have to get one.
Offline r3nfr0
« Reply #743 on: Sun, 07 September 2014, 13:35:05 »
Link?
« Reply #744 on: Sun, 07 September 2014, 13:46:39 »
Link?
In her sig.
Offline r3nfr0
« Reply #745 on: Sun, 07 September 2014, 13:47:17 »
Ahh... Tapatalk got me!
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #746 on: Sun, 07 September 2014, 14:09:04 »
Friends and Family key was done as a tribute shortly after his death.  I have a couple that was given to me and the wife fro attending KeyCon 2013 in Chicago.  One for me and one for the wife.  I thought I remember there being a good number of extras.  The one problem was they were 1.5u bottom row DCS profile.  So not really compatible with the majority of boards.  Please tell me this cap will have a place on the SmallFry board.
« Reply #747 on: Sun, 07 September 2014, 15:11:01 »
JD40/SmallFry doesn't use any 1.5u keys at all. You could always use it as left shift, if you don't mind a 0.125u gap.
Offline cherpalla
« Reply #748 on: Sun, 07 September 2014, 18:14:59 »
Link?
http://geekhack.org/index.php?topic=57263.msg1455582#msg1455582
c h e r
Offline Hpm
« Reply #749 on: Tue, 09 September 2014, 03:06:02 »
Could You give mehr a hand? What is the difference between 60 and 80% notched plates?
