Author Topic: Are different cherry mx switches priced differently?  (Read 4534 times)
Offline roaming pear
  • THE Roaming Pear
« on: Sun, 08 June 2014, 15:32:47 »
Or are all cherry mx switches the same price?
Would it make sense for one cherry mx switch to be more expensive than another?
Does anyone have any accessories or key caps or other poker 2 related things lying around that they are not using?  I don't mind taking it off your hands if you no longer want it...
Re: Are different cherry mx switches priced differently?
« Reply #1 on: Sun, 08 June 2014, 15:35:59 »
No reason anyone should be anymore or less than another. Used switches should be cheaper than new ones.
If you look at mechanicalkeyboards.com all of the switches they have regular amounts of stock for are priced the same.
The only switch I've seen that is more expensive is the mxlock but you probably aren't concerned with that one anyway.
Offline ideus
  • Björkö.
« Reply #2 on: Sun, 08 June 2014, 15:36:43 »
Green and clear tend to command higher prices. Blacks follow them to be in the middle. Red, blue, and brown are now the lowest in terms of price. It depends on simple supply, and demand. Reds were a specialty some time ago, and by then the boards with them were priced accordingly.
Offline Defect
« Reply #3 on: Sun, 08 June 2014, 15:36:49 »
Only reason MX Clears are more expensive is because they used to be rare, so most commonly you have to buy them new.  Vs Reds/Black/Blues/Browns can be sourced from older boards.  MX Black being the most common.
Offline mouse.the.lucky.dog
« Reply #4 on: Sun, 08 June 2014, 15:46:52 »
Well when the RGB's hit the market they will be priced higher, but that's to be expected.
Offline Pacifist
  • on hiatus
« Reply #5 on: Sun, 08 June 2014, 15:49:19 »
Up until MK started stocking switches, blacks were most common, followed by browns and blues. Reds were slightly less easier to get, and clear and green were hard to find.
Offline ideus
  • Björkö.
« Reply #6 on: Wed, 11 June 2014, 23:08:56 »
We agreed on clears and greens to be the currently most expensive ones.
« Reply #7 on: Thu, 12 June 2014, 00:16:07 »
7bit  buys new switches directly from Cherry in Germany and sells them. He sells each type for the same price, with the exception of MX Lock which costs almost twice as much.
« Reply #8 on: Thu, 12 June 2014, 00:25:23 »
mx locks are much more expensive since they haven't been made in a while. Same with whites.
« Reply #9 on: Thu, 12 June 2014, 11:27:26 »
You can buy plate mount whites here http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=848 same price as the rest.
Offline davkol
  •  Post Editing Timeout
« Reply #10 on: Thu, 12 June 2014, 11:42:39 »
Depends on availability. For example, reds, browns, clears, whites, greens, grays and others have been scarce at different points in time. You'd have to pay premium for them at Massdrop, qtan's store and elsewhere (limited editions like filco with reds, anyone?). Besides, #vintage switches are sometimes worth more than regular/modern ones (e.g. nixdorf blacks).
Other than that, they shouldn't be priced differently... see 7bit's sale thread.
Offline ideus
  • Björkö.
« Reply #11 on: Thu, 12 June 2014, 11:58:22 »
...It depends on simple supply, and demand. ...
