Author Topic: Unicomp Classic Trackball keyboard for Linux  (Read 1399 times)
Offline ds26gte
« on: Mon, 09 June 2014, 18:31:27 »
Is there any experience here with the USB version of the Unicomp Classic Trackball keyboard(s)? Is it plug-n-play with an Ubuntu Linux system, or does it take some doing to get the trackball working? Do the keyboard and trackball use up just one USB port?
--d
Bloody B820R with LK blues. Logitech Marble Mouse unplugged and inside a drawer for emergencies.
Offline ideus
  • Björkö.
Re: Unicomp Classic Trackball keyboard for Linux
« Reply #1 on: Mon, 09 June 2014, 23:00:21 »
The pictures at vendor's site show only one cable and one connector. I suggest you to ask them directly.
Offline blackbox
« Reply #2 on: Tue, 10 June 2014, 00:05:49 »
There must be an usb hub inside it. Thats why it only has one usb connector. As said I suggest you contact them directly.
The LAN table!
Offline davkol
  •  Post Editing Timeout
« Reply #3 on: Tue, 10 June 2014, 04:20:04 »
If it's the same as Endura Pro, you shouldn't run into any trouble.
