Author Topic: Qpad MK-50 spacebar crooked  (Read 4580 times)
Offline addicTix
« on: Fri, 13 June 2014, 17:29:55 »
Hello,
Today, I got my new Keyboard, a QPAD MK-50 with Cherry MX-Blue.
I love this keyboard, but there's one thing which I can't accept.
The Spacebar. It's crooked.
Here's a pic:
http://www.abload.de/image.php?img=20140613_203735azcyw.jpg
What can I do ? I don't want to return it, because it took many days until I'll get a new one :s
It would be the last opportunity for me.
I hope you can help me ! Thanks !
Offline blackbox
Re: Qpad MK-50 spacebar crooked
« Reply #1 on: Fri, 13 June 2014, 17:39:13 »
Tried taking it off and on again? Might be a Stabilizer that not properly seated.
The LAN table!
Offline addicTix
« Reply #2 on: Fri, 13 June 2014, 17:48:35 »
How can I do this without damage the keyboard/the switches/the stabilizer ?
I got a Key Cap Puller but I don't know how to use it on a spacebar
Offline blackbox
The LAN table!
Offline addicTix
« Reply #4 on: Fri, 13 June 2014, 18:17:05 »
For spacebar, just push up on each side with your index fingers.
So, I just need to remove ALT and ALT GR Key and with my 2 index fingers pull up the spacebar ?
Offline blackbox
« Reply #5 on: Fri, 13 June 2014, 18:18:07 »
Yes. Do it gently and it should work.
The LAN table!
Offline addicTix
« Reply #6 on: Fri, 13 June 2014, 18:26:31 »
Okay thanks for the help.
And to replace it, just hook it up and press the spacebar down ?
Offline blackbox
« Reply #7 on: Fri, 13 June 2014, 18:28:04 »
Yup, as you mentioned remember to attach the stabilizer first before pressing it down.
The LAN table!
Offline addicTix
« Reply #8 on: Sat, 14 June 2014, 07:05:27 »
So, I tried to take it off and on again, but it's still crooked.
I think the last opportunity is to return it and get a new one, right  ?
Because, I don't accept this :s
Spacebar is working but it looks crappy
Offline exit
« Reply #9 on: Sat, 14 June 2014, 07:41:36 »
I had a problem with my spacebar when I bought my keyboard (it kept getting jammed), i emailed the shop i bought it from and they sent me a new spacebar to put on.
How I pull the spacebar is putting the puller on one side and pulling the spacebar out with two fingers on the other side. Do it gently. Be careful since the white stabilizers can break easily but you can easily buy new ones or getting it with the spacebar the shop MAY send you.
