Author Topic: Help painting plate  (Read 3970 times)
Offline adventurepoop
  • I make keyboards, I guess.
Help painting plate
« on: Sat, 14 June 2014, 18:37:53 »
I have a plate salvaged from some keyboard or another. It seems to have a layer of tan paint on it, and I want to paint it black. What would be the best way to do this? I figure I would have to sand off the old paint first. Is plasti dip an option? thanks!
Re: Help painting plate
« Reply #1 on: Sat, 14 June 2014, 18:55:21 »
No idea what "plate" refers to in this context, because I mostly work with ancient IBM iron and old-school Alps, but roughing it up a bit with sandpaper and cleaning it well is probably plenty of prep. I swear by Rustoleum paint, but some people love Krylon.
Apply several very thin coats. Save the plasti-coat for things that get a lot of handling.
- D Trump 2026-10-24
« Reply #2 on: Sat, 14 June 2014, 19:05:44 »
In my experience, plastidip doesn't hold up well.
« Reply #3 on: Sat, 14 June 2014, 19:19:56 »
Yeah, I've painted quite a few plates now, and I always use Krylon. I always sand it with 80-grit sandpaper to prep. Just do several thin costs, allowing like 15-20 minutes between coats. Then let it dry for 24-48 hours before mounting any switches or stabilizers.
« Reply #4 on: Sat, 14 June 2014, 20:11:24 »
alright ill give that a try, thanks everyone for help and such
Offline Eszett
« Reply #5 on: Sat, 14 June 2014, 21:12:34 »
Yes, I thought "the plastidip solution" has just pros, no cons. Until I saw this
well, in some point of view this may be a con too, but for my taste of durable keyboard painting this is a huge con :-(
« Last Edit: Sat, 14 June 2014, 21:15:03 by Eszett »
Offline Eszett
« Reply #6 on: Sat, 14 June 2014, 21:15:56 »
(double posting, can be deleted)
« Reply #7 on: Sat, 14 June 2014, 21:17:35 »
That's actually a pro for some.  IME, the issue is if it comes into contact with something a lot, it tends to pill a little and wear off.  Then it gets hard to remove.
