Author Topic: Harvesting keyboards / electric typewriters keycaps for IBM Model M Keyboard  (Read 4645 times)
Offline babuinix
Has topic says, what would be good Keyboards/Electric Typewriters that i could harvest with keys so i could use on my model M.
Im from Europe / Portugal so buying them gest costly cause of shipping fees.
I know model Model M2 is also buclking springs and maybe same keys, how about this ones:
or
For instance this typewritter, could i harvest those keycaps? whats the mechanism beneath?
Could get this for 10/15 bucks for example.
Thx in advance.
i5 3470//GSKILL 8GB RIPJAW X//SEAGATE 1TB//XFX 550W//MSI GTX660 TF OC 2G
Offline BlueBär
Buckling spring keycaps are fairly unique and the only other keycaps that I know of that should fit are the ones from the IBM Wheelwriter, see this topic: http://geekhack.org/index.php?topic=41516.0
However you can get some new caps from Unicomp for a low price.
Offline babuinix
Thx, theres some preety good info there.
Offline babuinix
So i managed to get this IBM typewritter for 10€ with some interesting keycaps.
Harvested some of the keycaps to use on the model m and star dye experementing eventualy.
Before:
After some changes:
Among the noticeble changes with the white enter/caps/shifts/arrows/backspace is the replacement of the G & H that are from the typewritter and are slightly bolder letters, giving it a nice nuance omage to GeekHack :D
X was also replaced cause yeah...
Will try and hunt a Model M2 for the all white Fkeys.
Now what to do with the rest of the Typewritter? what more parts should i harvest? Maybe the springs just in case i need some replacements in the future?
The key next to scroll lock that looks like and antena is the key used to change from speakers to headphones and vice-versa, the tab+/tab- regulates the volume, Esc key is used as windows key, as a gamer using the Pause/Break key  in escape makes perfect sense :D.
« Last Edit: Thu, 03 July 2014, 19:26:51 by babuinix »
Offline jacobolus
If you take apart some Wheelwriters to use the keycaps on Model Ms, would you mind sending me the "Code" keys (I’ll pay a few bucks)? Not right away, but at some point I’d like to try to make a custom layout buckling spring keyboard with split spacebars, and that seems like the perfect size/shape keycap.
(Also, it doesn’t really fit anywhere on a Model M.)
Offline luisbg
What was the 'Code' key for? I feel like I should know this.
Leopold FC660M - Brown mx switches - black case - white blank keys :: ErgoDox - Blue mx switches - classic case - black blank keys
Offline babuinix
Anyone knows if this keycaps are model M compatible?
The Selectric is an altogether different beast.
M2 keys will not interchange properly with standard M keys, although the stems are shaped the same.
Perhaps if you did the entire function row it would look OK.
- D Trump 2026-10-24
