Author Topic: Buckling spring alternative  (Read 11095 times)
Offline muzzymurray
« on: Tue, 17 June 2014, 22:15:09 »
Hi,
I am currently using a HHKB pro2, which, as far as I know, is a linear switch type. I am interested in trying the other extreme, which seems to be model M bucking spring, where a reasonable amount of force is required to actuate the switch. I am a big fan of the 60% layouts so I am really interested in what modern switch type I could use in a 60% keyboard to get a similar effect.
Thanks
Offline FrostyToast
  • Litshoard
Re: Buckling spring alternative
« Reply #1 on: Tue, 17 June 2014, 22:18:36 »
Cherry mx greens as far as I can tell are the closest thing to BS switches if you want a 60%
Quote from: elton5354
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #2 on: Tue, 17 June 2014, 22:19:10 »
Well, the closest mx switch I can think of would be MX greens, though it doesn't come standard on any 60% boards.
edit: sniped
edit 2: corrected by riot, comes on V60s
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #3 on: Tue, 17 June 2014, 22:19:18 »
If what you're interested in is a heavy, clicky switch, you could look for MX Greens. The new V60 has a MX Green variant, and it looks like you may be able to buy it from pexon: http://geekhack.org/index.php?topic=58917.msg1347842#msg1347842
edit: 2 ninjas!
Offline Anonymoose
« Reply #4 on: Tue, 17 June 2014, 22:22:51 »
Leopold Fc660M can also be had in MX Greens.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #5 on: Tue, 17 June 2014, 22:23:41 »
Really? And that is if you want to put up with the funky shift and spacebar
Offline Anonymoose
« Reply #6 on: Tue, 17 June 2014, 22:26:32 »
Spacebar is pretty easy to universalize with some sticky tack and stem harvesting. The shift can be a pain if you don't use a modifier pack of some sort, but the "0" or "+" keys from a numpad set tend to fit alright.
« Reply #7 on: Tue, 17 June 2014, 22:37:02 »
Greens are close, but to me still noticeably lighter than BS.
Offline FrostyToast
  • Litshoard
« Reply #8 on: Tue, 17 June 2014, 22:41:50 »
Still, nothing beats the feeling of BS springs. I suggest picking up a model m if you haven't already.
« Reply #9 on: Tue, 17 June 2014, 23:29:20 »
I recommend beam spring as a good alternaive to buckling spring. It can be had in roughly 60% size.
Sadly, it's not modern :(
It's just the way the spring buckles that makes it so good. It's hard to emulate without a beast of a solenoid.
Offline mougrim
« Reply #10 on: Wed, 18 June 2014, 00:39:14 »
There is NO alternative to buckling spring :)
IBM AT Model F, Vortexgear Race 3, AEKII (Alps Cream Damped), Metoo Zero (modded to Kailh Box Navy)
Offline muzzymurray
« Reply #11 on: Wed, 18 June 2014, 00:57:12 »
Great, thanks so much for all the answers. Might have to check out the V60. I would pick up a model M, but I can't handle the footprint of those massive keyboards.
Offline False_Dmitry_II
« Reply #12 on: Wed, 18 June 2014, 01:08:42 »
I think Matias is closer than any MX to buckling spring. But yeah, Model M's are kinda big, not that I care, as I'm typing on my 1394540.
If M's are too big, then I guess an Aircraft Carrier is out of the question.
« Reply #13 on: Wed, 18 June 2014, 01:09:48 »
Look for an SSK - TKL version of Model M.
Or the Kishaver, if you want a BS 60%.
Offline mougrim
« Reply #14 on: Wed, 18 June 2014, 01:10:08 »
Get two - V60 and a buckle spring keyboard. I love both my AT Model F and Poker II with blues.
Offline Pacifist
  • on hiatus
« Reply #15 on: Wed, 18 June 2014, 01:11:07 »
After trying greens today, I can say that IMO greens are somewhat similar to model M and nowhere similar to model f
Offline mougrim
« Reply #16 on: Wed, 18 June 2014, 01:43:54 »
Yep, Model F switches lighter with more crispy soung, right?
Offline Defect
« Reply #17 on: Wed, 18 June 2014, 06:53:56 »
My two cents: MX green is the closest stock MX switch to BS, but really falls short in comparison.
Greens try to mimic BS within the constraints of MX's linear design.  Creative design, but entirely different and it shows (feels)
« Reply #18 on: Thu, 19 June 2014, 07:54:21 »
They feel lighter, but actually still actuate at the same force.
Offline mougrim
« Reply #19 on: Thu, 19 June 2014, 08:03:14 »
But they still feel lighter than my Unicomp board. Maybe it's all about sound...
Offline Hypersphere
« Reply #20 on: Thu, 19 June 2014, 08:06:07 »
Topre is not linear. There is a tactile bump.
Cherry mx greens are nothing like the sound and feel of either membrane buckling springs (as in IBM Model M boards) or capacitive buckling springs (as in IBM Model F boards), except that they click and are relatively heavy.
If you want a compact board with very definite aural and tactile feedback, take a look at the Matias Mini Tactile Pro. However, this board is designed for the Mac. There is a PC version with silenced Matias switches.
Recently, I have switched, at least temporarily, from the HHKB Pro 2 to an IBM XT, which is a Model F with capacitive buckling springs. The XT has a more metallic and definitive click than any Model M I have tried. However, in order to use the XT with a modern computer, you need a converter, such as Soarer's Converter or a Hagstrom converter box.
Offline Oobly
« Reply #21 on: Thu, 19 June 2014, 09:08:53 »
Hmm.... I believe a Kishsaver with replacement controller would fit the bill... It's a big bill, though.
Or this: http://geekhack.org/index.php?topic=59677.0
I don't think anything other than buckling spring feels or sounds like buckling spring. HHKB Pro is not linear, but rather collapsing rubber dome over conical spring, with capacitive sensing. Any Cherry MX, Alps style or buckling spring board will feel different to the HHKB. Buckling spring is probably the "most different", so it's worth pursuing. Everyone who claims to have an interest in mechanical keyboards should at least try a buckling spring board.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline vivalarevolución
« Reply #22 on: Thu, 19 June 2014, 10:21:50 »
There is no alternative to buckling spring.  It is the end all, be all of keyboards.
Offline quadibloc
  • Layout Fanatic
    • John Savard's Home Page
« Reply #23 on: Thu, 19 June 2014, 17:32:48 »
The MX Green may not be perfect, but if it comes closer than the ones that were available before, then having it as a new choice is a good thing, particularly as there are a couple of tenkeyless designs out there with the MX Green, whereas the tenkeyless version of the Model M is rare and expensive, since new ones are not being made. (One might dream of Unicomp making not only a tenkeyless but also a 60% someday, but it looks like that's only going to be a dream.)
However, from what I hear in this thread is that it really isn't any more tactile than the Cherry MX blue, it just requires more force to push it. If that's the case, compared to the Blue, the Green might be "closer" to the buckling spring, but not in the way that really matters.
Offline Daspartic
  • IBM is love IBM is life
« Reply #24 on: Thu, 19 June 2014, 17:49:21 »
They do?  I've never tested them, but it actually feels like it's around 50g to me.
IBM Displaywriter (82 key) | IBM Model F 4704 (107 key) |  IBM Model F AT x3 | IBM Model F XT | IBM Model F 3104 x2 | IBM 6112884 (Green Tee mount Alps) | Realforce 87u (55g) | IBM Model M 1390131 x2 | IBM Model M (1391401 '88) | Leopold FC500R (MX Browns) | Wang (725-5971) (Salmon Alps) | Acer 6011 (SKCM Blue Alps) | White Fox (65 g Zealios) | XMIT keyboard (Hall Effect)
Offline jacobolus
« Reply #25 on: Sat, 21 June 2014, 02:01:45 »
That’s right. If you want something small, a beam spring board is just the thing.
Offline mougrim
« Reply #26 on: Sat, 21 June 2014, 02:13:45 »
Yep. Also if you want something thin to fit your table  ;D
Offline Oobly
« Reply #27 on: Mon, 23 June 2014, 06:10:31 »
There's always the 122, I hear it feels great to use:
But seriously, this little enigma has me itching:
I really would love to know more about it, but it's a bit like the Loch Ness monster only with better pictures. Apparently ClickClack found it in storage at work attached to a Signmaker machine.
Offline quadibloc
  • Layout Fanatic
« Reply #28 on: Mon, 23 June 2014, 06:27:13 »
I'm pretty sure that what ClickClack found was a rubber dome (or one with Cherry switches, perhaps even more likely for a short-run specialized keyboard), and that picture showing the buckling springs is of a mod some intrepid keyboard enthusiast (who affected an obsession with Zoë des Chanel... or was it Katy Perry?... while a participant here) performed on a Model M.
Ah, there's another thread here, "Mysterious Model M Mini on Reddit", which discusses that keyboard.
« Last Edit: Mon, 23 June 2014, 06:32:56 by quadibloc »
Offline Hypersphere
« Reply #29 on: Fri, 05 September 2014, 08:25:57 »
Hi,
Thanks
The HHKB Pro 2 is a Topre capacitive switch. It is not linear. It has a tactile bump arising from the sudden collapse of a rubber dome under each switch.
Although the Topre switch might seem vastly different from a buckling spring, my favorite keyboards are Topre-switch, such as the HHKB Pro 2 and RF 87u,  and IBM capacitive buckling spring, such as the IBM Model F XT keyboard.
Offline 0100010
  • Not Sure
« Reply #30 on: Fri, 05 September 2014, 08:46:23 »
Ah yes - "The Grail."
From the original thread, that contraption Click Clack made to reach across the storage closet with a long clamp, tape and pencil seemed to indicate it was BS.
That sleek case, 60% layout, windowed caps lock.....
Drool.....
Offline esoomenona
  • Gnillort?
« Reply #31 on: Fri, 05 September 2014, 09:57:08 »
Under each cap, as the rubber dome (oops, cup rubber 8==D) is above the switching mechanism (spring pushed down changes capacitance).
But agreed on the switch types you've claimed favorite. They are mine as well. Though, I don't discriminate against good old fashioned BS as many others do.
Anyway, there is NO MX SWITCH that matches up to BS. You're best bet is to just grab a Model M. If your true desire is a smaller form factor, as many others have showed us, there is modification available to achieve that desire.
Offline JPG
  • Model F is my new passion!
« Reply #32 on: Fri, 05 September 2014, 10:03:47 »
If you want to try the BS switch and manage to find one, I suggest trying the model F over the M. The biggest challenge will be the availability and the layout. The most interesting in this aspect with no modification is probably the AT model F. For you, since you would like a 60% the best would be a Kishsaver (60% model F), but they are VERY rare and the only that were made available recently all have an owner that won't let them go for cheap (none under 200$ for sure).
Still, if you can find a cheap model M or a cheap model F grab one and try it. You will see in an instant if you like it or not probably. Just be sure to take care of your wallet while doing so  :p
Offline Hypersphere
« Reply #33 on: Fri, 05 September 2014, 12:22:08 »
Couldn't agree more about the fact that there is a substantial difference in sound and feel between Model F and Model M buckling spring keyboards. I started out years ago with a full-size IBM Model M and then got an SSK, which became my daily driver for a while. Then I found an IBM Model F XT for $19 on eBay. After connecting it to a Hagstrom converter, it worked just fine, but I decided to refurbish and convert it to USB anyway.
Using Soarer' converter, I remapped the keys on the XT to a hybrid Mac/HHKB layout. The layout is not ideal, but this is compensated by the excellent sound and feel of this keyboard. I also have an IBM Model F AT, which has a more favorable layout, but it is slightly larger than the XT and doesn't feel quite as solid.
I now have an IBM Model F 122 keyboard that I plan to restore and convert. The 122 will have a much more favorable layout than the XT and it is just as solid, although it is anything but compact.
Offline johndavis33
« Reply #34 on: Sat, 06 September 2014, 11:21:26 »
I've typed on MX greens and BS a lot.
Greens are wayyyyy more tactile than MX blues, about clear level of tactility. They're a lot more high pitched in sound. IMO they're closer to buckling spring than Matias switches.
The difference is that in BS switches, the force constantly grows until you reach the actuation, where the force just kinda drops as the spring buckles. For greens, they're linear until you reach the bump, where the force spikes up a lot for a breif period, and then they return to feeling linear for the rest of the press.
When it comes to the math, yes, greens are about as stiff and tactile as buckling springs. But when it comes to how that tactile bump feels, they're entirely different.
I think your best solution is to get a v60 with greens and a model M, just to see how the M feels,
HAVE AND WILL KEEP: HHKB - Printed white | Ducky Banana edition - Whites | Model M13 | Unidentified Goodwill keyboard - Simplified black ALPS
TOO BE SOLD: TG3 BL82 - Clears | Wheelwrite 5 - Buckling Springs typewriter
SOLD: Rosewill RK9000 - Blacks | QFR - Blues | Ducky G2 Pro - Greens |
IT WILL BE MINE: Northgate Omnikey - White ALPS
