Author Topic: Modding Apple M0110  (Read 2578 times)
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
Modding Apple M0110
« on: Fri, 20 June 2014, 23:17:46 »
Offline jacobolus
Re: Modding Apple M0110
« Reply #1 on: Sat, 21 June 2014, 02:34:32 »
Any wire is fine. There’s nothing special about it. Stranded or solid, and whatever gauge, doesn’t really matter. Lowpoly used a ribbon cable to keep things neat and organized, but that’s also not necessary.
One thing you do need is a microcontroller board. The easiest to use for this is probably the Teensy 2.0: https://www.pjrc.com/store/teensy.html
« Last Edit: Sat, 21 June 2014, 02:47:00 by jacobolus »
Offline hydrospell
  • some keyboard thing
    • octobrain
« Reply #2 on: Sat, 21 June 2014, 06:02:44 »
I have done the same mod with lowpoly's guide. Posting here so if you have any questions and post here I can help answer :)
Teensy 2.0 as recommended by jacobolus above is one of the more common microcontrollers we use round here, in conjunction with https://github.com/tmk/tmk_keyboard
⌨ Filco MJ2 MX Blues / M0116 Orange Alps / Homemade 60% MX Reds / M0110
Cherry MX art prints 20/50 still available!
Offline lowpoly
« Reply #3 on: Mon, 23 June 2014, 05:34:42 »
I used 0.8mm copper wire. It came "heavily tinned". If I were to do the mod again, I'd use it for the horizontal wiring too (and cut the diodes shorter). Electrically there's no difference but when handling, the diode legs are soft.
