Author Topic: Copper/Wood QFR project.  (Read 12598 times)
Offline themitch22
« on: Sun, 22 June 2014, 13:29:18 »
I did a few layers of base coat Krylon white paint+primer after sanding it down as well as I could to get the logos and rubber coating off. Then I used Krylon Hammered Copper for the case.
The keys are sanded and going to get a base coat soon, I'm going to use another metalic color on them.
I'm looking into different types of wood veneer like mohagany to laminate on the top of the keycaps so I get a nice texture and feel to the keys for a classic look. I'm not going for steam punk, I'm going more for something comfortable and stands out.
I bought and testing a Handheld Scientific bluetooth adapter but that didn't work with the QFR unfortunately. Now, I plan on wiring a custom Teensy controller for bluetooth so I can use it with my tablet and laptop wirelessly.
This is my first keyboard mod and I'm excited how it will turn out.
Offline franklima260
Re: Copper/Wood QFR project.
« Reply #1 on: Wed, 23 July 2014, 21:34:26 »
Great keyboard Mitch how is it coming :)
|Cooler Master QuickFire TK (CMTK) Blue | Adesso Compact Mechanical Keyboard (ACMK)
Offline HotKillerZzz
  • Ammesia
« Reply #2 on: Fri, 25 July 2014, 22:06:21 »
So you are going to sand your keycaps and paint them?
« Reply #3 on: Sat, 26 July 2014, 02:47:53 »
That's kinda what OP said :p
A month later - any progress?
I think this is going to turn out just a little bit steampunky ;)
Offline themitch22
« Reply #4 on: Sun, 27 July 2014, 16:34:41 »
Yes, progress and failure.
It turned out looking great, problem is the paint wore really quickly from my fingers and throwing it in a bag. I abandoned the whole painting the key thing, the clear coat started sticking to my fingers, I'm guessing I should have sanded more between every coating.
Here's the album of how it turned out:
http://imgur.com/a/KUMzl
I ordered some blank white PBT keycaps and just going to go with standard blank keycaps and a painted case.
« Reply #5 on: Sun, 27 July 2014, 20:20:02 »
You're right - that does look more woody than steampunky - looks good :)
Offline cbot
« Reply #6 on: Wed, 30 July 2014, 21:30:48 »
Very glittery. I love it!
Offline barkinos98
  • Illinois
« Reply #7 on: Mon, 04 August 2014, 15:56:16 »
Love it man, I'm going to soon buy a QFR and make a nice champagne gold colored one off thing  :thumb:
Happy Hacking Professional 2  | Logitech G710+ | Quickfire Rapid MX Clears
« Reply #8 on: Mon, 04 August 2014, 17:03:11 »
Until someone copies it ;)
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #9 on: Mon, 04 August 2014, 17:08:17 »
I've used that hammered copper spraypaint on a NERF gun mod I did for a friend. Turned out awesome, too.
