Author Topic: 0-Stabilizer 60% (aka: Bianca)  (Read 6190 times)
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« on: Tue, 24 June 2014, 09:29:01 »
This time it's Bianca's turn. I wanted to design a stabilizers free 60%, this is what came out...
Raw materials
frosted acrylic is actually pretty nice...
After the sanding session
Paint job!
Long hand-wiring session
Where the hell do I put the controller?!
And here's Bianca, the craziest layout I've done so far, but it actually works pretty well...
I'll post all the CAD files soon if you are interested. (sorry I have to make some modifications first so you don't make my same mistakes).
« Last Edit: Tue, 24 June 2014, 09:42:57 by Matt3o »
Offline epzy
  • HHKB Fiend
  • ded
Re: 0-Stabilizer 60% (aka: Bianca)
« Reply #1 on: Tue, 24 June 2014, 09:30:46 »
Pretty cool. :)
Offline Vibex
  • Love y'all
« Reply #2 on: Tue, 24 June 2014, 09:31:14 »
Said this in the granite thread, this board is beautiful! Absolutely love it. ;D
Offline codyeatworld
« Reply #3 on: Tue, 24 June 2014, 09:32:53 »
You have the coolest keyboards.
I really like this one and your 65%.
Offline adventurepoop
  • I make keyboards, I guess.
« Reply #4 on: Tue, 24 June 2014, 09:33:42 »
The last 2 picture s are broken??
Offline LechnerDE
« Reply #5 on: Tue, 24 June 2014, 09:34:29 »
Pretty cool!
Was the windowed key in the bottom row part of the Granite Set?! Didn't see it in any of the kits.
Offline epzy
  • HHKB Fiend
  • ded
« Reply #6 on: Tue, 24 June 2014, 09:36:05 »
Nope. :/
« Reply #7 on: Tue, 24 June 2014, 09:40:43 »
Could someone do me a solid and rehost the last 2 pics? They say they're removed for me O.o
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #8 on: Tue, 24 June 2014, 09:41:18 »
try to refresh. imgur pretty much su.cks
Pretty cool!
yes it was part of granite (windowed kit)
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #9 on: Tue, 24 June 2014, 09:42:10 »
try here http://imgur.com/a/mDYth
« Reply #10 on: Tue, 24 June 2014, 09:45:29 »
Those worked fine, thanks :) It looks really good, color me jealous!
« Reply #11 on: Tue, 24 June 2014, 09:47:11 »
So uh what are all the bottom row key binds??
Offline Mainian
« Reply #12 on: Tue, 24 June 2014, 15:46:40 »
Wow, don't know why i decided to visit this sub-forum today, but I'm glad I did. That looks amazing.
Really wish I had the time to start getting into this...
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #13 on: Tue, 24 June 2014, 16:11:12 »
Love the idea of not farting around with stabs. Nice board. :D
« Reply #14 on: Tue, 24 June 2014, 16:11:38 »
What do you have mapped on the bottom row matt3o?
Offline Lurch
« Reply #15 on: Tue, 24 June 2014, 16:22:10 »
Love the design! :thumb:
Quote from: Flyersfan1
Offline Pacifist
  • on hiatus
« Reply #16 on: Tue, 24 June 2014, 16:30:37 »
you sure love to direct wire boards :thumb:
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #17 on: Tue, 24 June 2014, 17:08:06 »
and here's with monologends :)
Offline Zekromtor
    • My Setup
« Reply #18 on: Tue, 24 June 2014, 17:35:50 »
Diodes on the rows, I approve.
« Reply #19 on: Tue, 24 June 2014, 18:07:05 »
Wow cool man! It's like ISO ANSI tsangan haha
Offline ideus
  • Björkö.
« Reply #20 on: Tue, 24 June 2014, 20:03:36 »
Cool. And thank you for sharing your hard work.
Offline Jagriff
« Reply #21 on: Tue, 24 June 2014, 20:21:50 »
Amazing! I was thinking about doing something similar, but instead only using 1u, 1.5u, and 2u keys so that it would be compatible with ErgoDox (my main) keysets. Any advice?
« Last Edit: Tue, 24 June 2014, 20:25:45 by Jagriff »
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #22 on: Wed, 25 June 2014, 01:57:34 »
well the goal was to avoid stabilizers altogether, 2u keys are stabilized so I went for 1.75u that admittedly are hard to find.
