Author Topic: IBM M3 numeric keypad  (Read 3106 times)
Offline ed_avis
« on: Mon, 30 June 2014, 04:21:45 »
ebay.com/itm/390862972288
I think this accompanies the M4 space saving keyboard somehow, connecting to the spare socket on that board.  But what cable is needed?
Now I've seen this one on Ebay, I see that the same product is also available on Amazon.  Has anyone used it?
Re: IBM M3 numeric keypad
« Reply #1 on: Mon, 30 June 2014, 12:45:59 »
http://www.ebay.com/itm/390862972288
you need to add the www or it just links you to ebay's homepage
Are you sure that one accompanies the M4 kb? I thought the version without the lid does. Maybe they both do.
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #2 on: Mon, 30 June 2014, 12:51:42 »
Is this buckling spring?
« Reply #3 on: Mon, 30 June 2014, 12:59:43 »
should be buckling rubber sleeve, like the IBM M4 keyboard
There's only three IBM Buckling spring keypads I know of, the one that came with teh M15, there's some japanese one,a dn the IBM screen reader for blind people.
Looks like that one I lined has been on eBay for a while:
http://geekhack.org/index.php?topic=21789.msg412840#msg412840
Offline ed_avis
« Reply #4 on: Tue, 01 July 2014, 04:37:55 »
dorkvader: sorry, the ebay.com link works for me but it may depend on cookies etc, I'll put the www in future.
As you say this is surely the same switches as the M4 - buckling rubber sleeve.  I'm tempted to get one but I would need the cable to plug it into the M4.
Offline RabRhee
« Reply #5 on: Tue, 01 July 2014, 05:07:35 »
Not sure if this info is any use to you, but heres some pictures of my 1396199: I have a few more pics if you want to know something specific. I never used mine, I just bought it for the box and because it was $7 and seemed nice.
69561-0
With keys off.
69563-1
This is a picture of the connections and the cable that came with mine. I have no clue if it is the right cable for connecting to an M4, but I would suspect so as it is IBM branded. PS2 to 8 pin terminal type, both ends match the sockets on the numpad.
-Life is good-          Crafting: |  Keychains |  More.   .Keychains | Crowdsource Key | Budget Keycap Board |
