Author Topic: 5 Row keypad  (Read 2766 times)
Offline roaming pear
  • THE Roaming Pear
5 Row keypad
« on: Wed, 02 July 2014, 10:04:24 »
Is there a 5 Row keypad? I don't think I have come across one?
I was looking for one that would match the Poker II keyboard... but they are always 6 rows...
Does anyone have any accessories or key caps or other poker 2 related things lying around that they are not using?  I don't mind taking it off your hands if you no longer want it...
Re: 5 Row keypad
« Reply #1 on: Wed, 02 July 2014, 10:08:59 »
Offline xavierblak
Re: 5 Row keypad
« Reply #2 on: Wed, 02 July 2014, 10:52:53 »
Re: 5 Row keypad
« Reply #3 on: Wed, 02 July 2014, 11:39:34 »
Re: 5 Row keypad
« Reply #4 on: Wed, 02 July 2014, 11:44:09 »
Offline vivalarevolución
Re: 5 Row keypad
« Reply #5 on: Wed, 02 July 2014, 11:45:37 »
Aren't all keypads five rows?  Or are you looking for five columns.
Re: 5 Row keypad
« Reply #6 on: Wed, 02 July 2014, 11:50:41 »
Who makes this keypad?
It is a GHPad.
But where did you get that case for it?
Some random alps keypad I got from fohat a while back.
  • THE Roaming Pear
Re: 5 Row keypad
« Reply #7 on: Thu, 03 July 2014, 05:31:26 »
I guess the ones I was looking at were 6 rows for some reason...
I was looking for keypads with a thin bezel.
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: 5 Row keypad
« Reply #8 on: Thu, 03 July 2014, 08:55:22 »
Yeah there really isn't such a thing that is readily available. GHpad PCB and have a case 3D printed or some such to match the poker type case is more or less what you will have to do.
There are some 5 row keypad that are older made in 80's or early 90's from Genovation and a few others, but they don't have small case that will match the height of 60%.
Offline jacobolus
Re: 5 Row keypad
« Reply #9 on: Thu, 03 July 2014, 14:38:16 »
Numpad layouts in general are pretty tired and uninspiring. I wonder if any human factors people have tried working on this problem since the 70s. From what I can see of products on the market today, everyone pretty much copied IBM’s ****ty design.
Here’s a simple sketch of something that might be better, while leaving the basics the same:
I’m sure with a more radical redesign, you could do a whole lot better.
Offline poeee
Re: 5 Row keypad
« Reply #10 on: Fri, 04 July 2014, 17:36:13 »
Cool idea, but I would want the enter key on the corner as per usual.
