Author Topic: How do I Get Space Bar Back On?  (Read 2079 times)
Offline noway
« on: Wed, 02 July 2014, 18:49:38 »
Took spacebar off Quickfire Rapid.  How does it go back on?
Re: How do I Get Space Bar Back On?
« Reply #1 on: Wed, 02 July 2014, 18:51:07 »
Do this in reverse.
Offline noway
« Reply #2 on: Wed, 02 July 2014, 18:53:40 »
The plastic inserts keep falling out when I try that.  The inserts don't look symmetrical either.  Does the longer part of the open area of the insert base point to the upper part of the keyboard or the lower part?
« Last Edit: Wed, 02 July 2014, 18:59:33 by noway »
« Reply #3 on: Wed, 02 July 2014, 19:00:05 »
Longer part faces the top of your keyboard. They're not symmetrical. If you can't get the inserts to stay, get some tape or a plastic bag, cut little squares, then put them over the hole before you put the inserts back on.
Offline noway
« Reply #4 on: Wed, 02 July 2014, 19:04:25 »
Got it.  Thanks for the directionality and tip about something sticky.  I used a wee bit of blue tack.  Wheeeew!
« Reply #5 on: Wed, 02 July 2014, 19:06:09 »
Just be careful with that BlueTack. It can harden and it might be a pain to get out later. Paper, tape, and plastic bags all work nice and are easily removable later. But if it works, it works. :D
Offline noway
« Reply #6 on: Wed, 02 July 2014, 19:15:25 »
Kind of ugly compared to some I've seen around here but here's the end result of this project:69697-0
« Last Edit: Wed, 02 July 2014, 19:17:44 by noway »
« Reply #7 on: Wed, 02 July 2014, 19:28:42 »
Nice. I keep feeling like "`~" and "\|" should be the contrast color. I have changed them on my M/Fs
Also, those secondary legends on the F keys seem out of character.
"you've got to cheat like hell"
- D Trump - 2026-09-10 Dallas, Texas
"The pure products of America go crazy"
- William Carlos Williams - "For Elsie" 1942
Offline smknjoe
« Reply #8 on: Wed, 02 July 2014, 19:30:25 »
Nice trackball. Too bad they don't make them anymore...
SSKs for everyone!
Offline noway
« Reply #9 on: Wed, 02 July 2014, 20:03:18 »
Yes you're right.  Made the change.   Also put the black space bar back on for practice and I actually like the looks of it better that way.   Just need the white keys for legibility.
« Last Edit: Wed, 02 July 2014, 20:05:50 by noway »
Offline False_Dmitry_II
« Reply #10 on: Thu, 03 July 2014, 01:56:22 »
It's done that way on standard alternating colors to keep actual enterable characters all one color, and modifiers all the other. It was intentionally about what each does.
