Author Topic: [Help] Question about key cap cleaning  (Read 5792 times)
Offline ravenomega
« on: Mon, 07 July 2014, 06:19:49 »
Hey guys I'm new here. I've read that it is safe to use denture tabs to clean my key caps. Does it matter what Denture Tabs I use on my Ducky ABS key caps? Is there a certain brand i should get or are they all the same?
« Last Edit: Mon, 07 July 2014, 06:25:33 by ravenomega »
Offline jalaj
Re: [Help] Question about key cap cleaning
« Reply #1 on: Mon, 07 July 2014, 07:34:56 »
Probably similar active ingredient. You can use generic brand. Always try first on just a single keycap to be safe.
Offline ravenomega
« Reply #2 on: Mon, 07 July 2014, 07:41:17 »
Thanks for the reply. How long should I leave them in for if I do it this way?
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #3 on: Mon, 07 July 2014, 07:47:52 »
Yeah. Just use a generic brand. Leave them in as long as the directions say... which, iirc, is about until the bubbles stop fizzing.
« Reply #4 on: Mon, 07 July 2014, 15:17:49 »
I used a generic brand.
Warm water.
Let the tablet dissolve (I used 3 tablets for a full set).
Add keycaps and stir for a moment.
Leave it until the blue water turns clear (or brown, depending on how dirty the keycaps are).  That took about 5 minutes for me.
Rinse in fresh water (just in case - maybe my paranoia).
Spread keycaps out on newspaper or tea towels to dry.
« Reply #5 on: Tue, 08 July 2014, 17:45:23 »
I use powdered laundry detergent (plus and oxi-* for more power) in hot water and rinse at least 3 times.
Cheaper and easier, works great.
- D Trump 2026-10-24
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #6 on: Tue, 08 July 2014, 18:35:39 »
My new method has been oxi and coffee machine cleaner (sulfamic hydroxyacetic acid). It froths up like vinegar and baking soda and even takes off mild yellowing in only moments. You need to be careful with this though as it can burn your skin!
Offline ravenomega
« Reply #7 on: Wed, 09 July 2014, 11:13:44 »
Thanks guys! I think I'll try the denture tabs first before trying coffee machine cleaner XD It is interesting to see other ways of cleaning key caps though!
Offline ndakota79
« Reply #8 on: Wed, 09 July 2014, 15:08:20 »
I'm using lens cleaner (ethanol & isopropanol) to wipe my PBTs clean. That doesn't affect them does it?
« Reply #9 on: Wed, 09 July 2014, 15:26:21 »
I've used Stain Away denture cleaner with good results. Better when you mix in a tsp of Oxiclean with it though.
Offline Prelim
« Reply #10 on: Thu, 17 July 2014, 16:48:50 »
what about Dishwashing Liquid like Fairy?
« Last Edit: Thu, 17 July 2014, 16:51:59 by Prelim »
2x GH60 revC - lubed Linjärs 65g / lubed H1s 65g with SPRIT 5mm acrylic plate | Dolch PAC - Cherry housing / Gateron sliders 65g and QMK clips | Raptor K1 G80-1890 stock
Floating on Cherry/GMK caps
« Reply #11 on: Thu, 17 July 2014, 17:04:48 »
Yes, that will work too.
Offline ShawnMeg
« Reply #12 on: Sat, 02 August 2014, 06:07:52 »
I always had good luck with hand soap diluted in water.  I've never tried the denture cleaning tablets.
IBM Model F122 X 2 internal Soarer's || IBM Model M122 internal Soarer's || AEK II SKCM Salmon ALPS external adb_usb converter ||  AEK M0115 SKCM Orange ALPS click mod external adb_usb converter || AEK M0115 SKCM Salmon ALPS external adb_usb converter ||
Offline skcheng
    • Tenafly Dentistry
« Reply #13 on: Sat, 02 August 2014, 11:21:41 »
I have a LARGE ultrasonic bath in my office and the denture cleaning tabs work great.  It's amazing how dirty caps can get.   And I like the fresh scent after the keycap bath.   I just dry on paper towels and paper plates since they're readily available in my office.
For pen and ink marks and DEEP stains, I'll rub with a little piece of Magic Eraser.   You can almost remove shine if you scrub a bit with the stuff.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #14 on: Sat, 02 August 2014, 16:02:49 »
do you keep inside or put under outside in the sun too?
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
