Author Topic: What switches are these ( old typwriter )  (Read 1687 times)
Offline Jixr
« on: Thu, 10 July 2014, 18:21:52 »
found this old typewriter at work and was wondering what kind of switch this thing has.
Feels kinda weird in a good way. smooth but kinda progressive feeling.
 thick dub shot and even trip shot caps on it too.
Xerox 627 Memory-something ( text worn off )
Re: What switches are these ( old typwriter )
« Reply #1 on: Thu, 10 July 2014, 18:38:57 »
oh cool, the keycaps are compatible with honeywell hall effect. do you mink taking a shot of the underside of a tripleshot one?
based on the slider, I'd guess that if it's not a rubber dome, it's some sort of spring over membrane or foam & foil.
I'd say it's likely a xerox memorywriter.
« Last Edit: Thu, 10 July 2014, 18:40:59 by dorkvader »
Offline Jixr
« Reply #2 on: Thu, 10 July 2014, 18:59:50 »
Offline jacobolus
« Reply #3 on: Thu, 10 July 2014, 19:49:45 »
Looks like this one e.g.
http://www.ebay.com/itm/131144973935
Willing to take the whole thing apart and show us what’s inside? I’m curious whether other Memorywriters used hall effect switches; otherwise I can’t see a big reason to use compatible keycap mounts.
« Last Edit: Thu, 10 July 2014, 20:02:31 by jacobolus »
Offline Parak
« Reply #4 on: Thu, 10 July 2014, 20:40:22 »
<dave>Don't turn it on - take it apart!</dave>
« Reply #5 on: Fri, 11 July 2014, 02:30:38 »
The keycaps look like they'll fit over hall effect switches.
The switches in the picture do not look like hall effect to me. I suspect slider over dome or spring over membrane, but it could also be foam&foil.
@jixr: thanks for taking the tripleshot picture for me! It's really rather different from the microswitch tripleshots. I wonder who made the keycaps for this.
