Author Topic: is a rubber dome keyboard of any interest?  (Read 5502 times)
Offline peethagoras
« on: Mon, 14 July 2014, 12:47:27 »
I just got given an IBM Aptiva (machine #2158) which, according to the user manual is a "104-key, 105-key or 109-key rubber dome Rapid Access (TM) keyboard".
Is this a good keyboard or mucho crapolatum?
regards.
Offline JPG
  • Model F is my new passion!
Re: is a rubber dome keyboard of any interest?
« Reply #1 on: Mon, 14 July 2014, 12:48:53 »
There are better rubber domes than others. Don't know for this one. Probably not of much interest but maybe someone will tell you otherwise.
Offline Vanilla
  • 110% Snuggable
« Reply #2 on: Mon, 14 July 2014, 12:52:31 »
Topre's are the best rubber dome generally* speaking.
Offline Defect
« Reply #3 on: Mon, 14 July 2014, 14:11:16 »
Here come the Topre posts.
Rubber dome boards are not bad.  But most are.  Most RD boards were focused on cost reduction and use cheap cap materials, poorly designed sliders, and cheap dome sheets.
There are good RD boards and usually they include higher quality caps, individual domes, (sometimes) slider over dome, etc.
Offline Techno Trousers
  • ʘ_ಠ
« Reply #4 on: Mon, 14 July 2014, 14:48:37 »
Some are okay, but the vast majority are made with the cheapest possible materials, and designed to last just beyond the 1 year mark for warranty purposes (regardless of their MSRP). Typing experience and feedback are not even a consideration for those.
I came of computing age during the 80s. I was fortunate to find a decent quality keyboard with white Alps that lasted about 10 years and through three computers before the switches started failing. Then I went through a very long dark age. I kept buying expensive "gaming" rubber dome boards, hoping that at least one of them would have put some quality into the typing experience, but NOPE! Always mush city, and sooner rather than later the legends would rub off and a key would fail.
Now thanks to finding Geekhack a few years ago, I've gone back to the future with capacitive buckling spring. Rubber dome is forever tainted for me, and honestly I don't even want to try Topre because of my bad past experiences. I know it's just a preconception on my part, but there it is.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #5 on: Mon, 14 July 2014, 17:00:20 »
honestly..............no
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
« Reply #6 on: Tue, 15 July 2014, 00:39:02 »
The IBM rubber domes are plate mounted and pretty great feeling. They have sweet dyesub PBT keycaps too.
A far cry from the buckling spring variant though/
Offline peethagoras
« Reply #7 on: Tue, 15 July 2014, 15:42:36 »
Well thanks for that great FB everybody. If the KB is crap then no loss as its a freeby.
Can perhaps someone enlighten me: what is "capacitive buckling spring"? I seem to remember some keyboards used inductive coupling, and some used capacitive membranes, some even used Hall effect devices, but "buckling spring"?
Excellent forum by the way.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #8 on: Tue, 15 July 2014, 15:43:37 »
This. The rubber dome variant of the Model M is a pretty darn solid keyboard
  • ʘ_ಠ
« Reply #9 on: Tue, 15 July 2014, 19:34:39 »
That is the original buckling spring technology, which supplanted beamspring, and was used in the various incarnations of the IBM Model F. The most famous of these are the original IBM XT 5150 and 5160 keyboard (terrible layout), and the original IBM AT (with the "big ass" enter key). There were also various terminal versions. My favorite of these are the Model F 122 key keyboards. With some work and a little extra cost to build a Soarer converter, or swapping in an Xwhatsit replacement controller, they can be modded to near-ANSI layout and a USB interface. Take a look at fohat.digs' great thread about that layout mod. I think it's one of the best things on Geekhack.
The IBM Model M is membrane buckling spring. It's not bad, but if you think about it, it's really just a cost-saving evolution of the Model F, and after comparing both, those cost reductions really hurt it.
« Last Edit: Tue, 15 July 2014, 19:38:15 by Techno Trousers »
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #10 on: Tue, 15 July 2014, 22:47:36 »
Totally agree here, plus they pop up sometimes on Ebay and worth the purchase.  I know the hardcore IBM enthusiast despises them for some reason but I like them a lot, plus I type faster on an old rubber dome IBM then on any newer keyboards sold today  :thumb: .
Offline ClarusWorks
« Reply #11 on: Wed, 16 July 2014, 08:02:22 »
I think the Unicomp rubber dome boards that are still manufactured now are the same domes as the old 'quiet touch' Model Ms.  I've used one once and it was decent - not a proper Model M, but still a lot better than the 75 cent boards you usually get with a PC.  Of course, I'm not sure how much sense it makes to spend $70+ on a rubber dome keyboard when the rubber Model Ms usually sell for cheap.  Some 90s Keytronic rubber dome boards were also reasonably nice.
When it's all said and done though, rubber domes are the solid state guitar amp of keyboards.  Cheap, functional, and even somewhat nice when you spring for a high-end one like Topre, but at the end of the day, they're still just an imitation of something better.
