Author Topic: Where to get a Cherry G80-18xx?  (Read 4908 times)
Offline TBone
« on: Fri, 18 July 2014, 12:07:51 »
I've been seeing these keyboards around and I love the layout. I'm not really in it for the keycaps, I'm thinking I'm going to put on my GMK Dolch set that comes in, but once I get my paycheck at the end of this month I really want to pick one up.
People who have them, where did you get yours? How much should I expect to pay? Are there USB converters for them?
Re: Where to get a Cherry G80-18xx?
« Reply #1 on: Fri, 18 July 2014, 12:10:04 »
Classifieds and eBay.
I bought a Dolch PAC Case and Leeku 1800 PCB out of the classifieds here. 1800 plate from a GB. And the other components like switches and diodes are from the normal places like Mouser and MK.com.
Offline intelli78
« Reply #2 on: Fri, 18 July 2014, 12:11:32 »
eBay and classifieds. Yes, you can convert to USB. AT --> PS2 adapter plus a PS2 --> USB adapter.
I have an 1800 PCB and case for sale right now, cheap, if you want to build your own. http://geekhack.org/index.php?topic=56924.0
Offline TBone
« Reply #3 on: Fri, 18 July 2014, 12:36:22 »
**** so all I would have to do is solder in my switches on that board? That's exactly what I'm looking for beside the color...how easily available are replacement cases?
Offline davkol
  •  Post Editing Timeout
« Reply #4 on: Fri, 18 July 2014, 13:37:44 »
If you aren't after something as fancy as others have mentioned, used lasered German 1851s are damn cheap in Germany. I'm typing on one right now and kinda like it.
Offline TBone
« Reply #5 on: Fri, 18 July 2014, 13:41:45 »
I need ANSI though. Aren't those ISO?
Offline intelli78
« Reply #6 on: Fri, 18 July 2014, 13:42:19 »
Right. You are looking for a black one?
« Reply #7 on: Fri, 18 July 2014, 13:42:55 »
1) I would have to do is solder in my switches on that board?
2) That's exactly what I'm looking for beside the color...how easily available are replacement cases?
1) You actually wouldn't even need to solder since the 1800s are PCB mounted switches.
2) Typically people buy other 18XX boards to swap cases. I have a Dolch case because someone bought it for the keycap set only.
Offline intelli78
« Reply #8 on: Fri, 18 July 2014, 13:45:34 »
This wouldn't be true if he bought mine, ofc, because I have desoldered the switch bottoms.
But yeah if you buy one that's not been desoldered, you can change the stems without any soldering.
« Reply #9 on: Fri, 18 July 2014, 13:47:31 »
Solder them back in then!  :p
Offline davkol
« Reply #10 on: Fri, 18 July 2014, 13:51:25 »
Yup, they're ISO. ANSI is less common and more expensive AFAIK. Not sure if conversion is possible. I prefer ANSI too and got used to ISO without any trouble though, but then... I rotate this with a typematrix, a matrix acess-is and an ergodox.
Offline TBone
« Reply #11 on: Fri, 18 July 2014, 14:07:21 »
No I'm looking for a project!!  ;D
And yeah I'd prefer black. I think it would go better with Dolch.
Only thing I'm worried about are stabilizers. I'd buy that from you right now if I knew I could get a black (or dark) case and PCB mounted Cherry Stabs.
Offline intelli78
« Reply #12 on: Fri, 18 July 2014, 14:11:24 »
Maybe your project should involve painting the case  ;)
And stabilizers: http://geekhack.org/index.php?topic=60789.0
done.
« Last Edit: Fri, 18 July 2014, 14:13:10 by intelli78 »
« Reply #13 on: Fri, 18 July 2014, 14:46:35 »
ISO to ANSI is difficult, but possible:
http://deskthority.net/workshop-f7/iso-to-ansi-t155.html
Offline TBone
« Reply #14 on: Fri, 18 July 2014, 14:48:31 »
done.
Dang this isn't even looking that expensive!  :D
As far as what I was thinking I mean. Any of my friends freak out over spending like more than $30 on a keyboard  :))
Do you know how easy it is to paint that case? And I feel like I should complete this job with a plate...you know if it's still possible to pick one up anywhere? How big was the GB?
Offline intelli78
« Reply #15 on: Fri, 18 July 2014, 14:57:10 »
I haven't painted a case before, but there is a whole sub forum dedicated to QFR mods, and case painting/plastidipping/etc info can be found there: http://geekhack.org/index.php?board=152.0
As for plates, I know calavera sold some last month but I think he's out. I don't think it would take too long to find one if you put an ad up.
Offline bazh
« Reply #16 on: Sat, 19 July 2014, 06:51:51 »
Advance mode: Where to get a leeku 1800
Damn I want a leeku and a 1813HFU...
HHKB Pro2 white
Newbie again
Offline TBone
« Reply #17 on: Sat, 19 July 2014, 09:53:57 »
Pardon my ignorance, but what is a Leeku 1800? Is that a custom PCB for G80-1800's?
Offline bazh
« Reply #18 on: Sat, 19 July 2014, 09:59:16 »
Yes it is :p
HHKB Pro2 white
Newbie again
