Author Topic: [GB] Stainless Steel Phantom Plates - ANSI 125, 150, 7BIT [CLOSED]  (Read 65063 times)
Offline TBone
Re: [GB] Stainless Steel Phantom Plates - ANSI 125, 150, 7BIT [SHIPPED]
« Reply #200 on: Sun, 09 November 2014, 15:46:25 »
Picture of final product - 62g ergo clear, TEX case from MechanicalKeyboards.
Thanks again to strict for this group buy.   ;D
The TEX case works with Phantom well?
Offline FreeCopy
« Reply #201 on: Sun, 09 November 2014, 16:56:30 »
Looks like it. Which is good to see because I plan on using one of these cases as well.
Nice board echo0!
Keyboards
Poker II | Leopold fc500r | Bolt Modded M 1391401 x2 08NOV90 - 19NOV90 | FK-2001 White Alps Clones | Filco MJ2 104Bolt Modded SSK 1391472 27JUL87 | Winkeyless B.87 TKL | MiniVan GateReds 62g
Offline echo0
« Reply #202 on: Sun, 09 November 2014, 18:23:02 »
Nice board echo0!
It was a tight fit into TEX case.  When I put the keyboard (plate and pcb with switches soldered) into the bottom case, the plate wobbled a bit when I touched it.  But once the screws are in place to close the case with top cover, everything seemed fine.
In order to make use the mini usb connector come with the TEX case, I used a 5-pin connector header (digi-key part number A100099-ND) and mini usb plug to make a custom adapter cable with 5 thin wires.  Soldering thin wire onto the 5-pin connector header and mini usb plug was not easy for me.
Offline ThreadKiller
« Reply #203 on: Sun, 09 November 2014, 23:55:38 »
Finished my 7bit build sans case this weekend.
MX grey switches
Offline Arcoril
« Reply #204 on: Wed, 12 November 2014, 02:58:41 »
Got my ANSI 125 plates in today and they're great! I had planned on priming and painting them, but the bare finish is so nice that I'm thinking of using a bit of metal polish to take off some of the minor surface scuffs and using the plates as-is.
Huge thanks to strict for being such a bro and putting this group buy together! Hope that there's a re-run of the uTKL plates in the future too!
Offline LechnerDE
« Reply #205 on: Thu, 13 November 2014, 12:19:44 »
Got my plates today:
Thank you very much for running this GB Strict  :thumb:
Now I have 4 TKL plates from you. I guess this is enough - maybe if you do fullsize plates next time, I'll order more ;)
Offline awhitedev
« Reply #206 on: Fri, 14 November 2014, 07:20:41 »
Are there any extras? I'd like to buy one if so. PM me please :)
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #207 on: Sat, 15 November 2014, 15:45:26 »
forgot to mention i got one of these fine plates in this week
great quality, lines up correctly, good job yet again strict these are a real treat to own
Offline Jersern
  • Australian Keyboard Modding and Repair Service
« Reply #208 on: Sun, 16 November 2014, 01:42:39 »
Still looking for an ANSI 125 plate! Someone sell me one please! I'll love you forever!  ;)  :-*
Offline TheMoonUnderWater
« Reply #209 on: Tue, 18 November 2014, 16:04:07 »
Both of mine arrived today. Great quality, thanks Strict!
Offline strict
  • TKL Zealot
« Reply #210 on: Tue, 25 November 2014, 09:26:05 »
Glad to see that so far that all the plates are arriving safely and that everyone seems to be happy with what they got. I'm happy to have been able to put this together but really you guys deserve a lot of the credit as well. It wouldn't have been possible without you guys so I just want to say thank you for your participation and patience!
In case you haven't seen it, there are some extras and some F2 plates up for grabs in my classifieds thread. If you want one you should probably act quick as they are selling fast!
Offline LoganMcW
« Reply #211 on: Mon, 15 December 2014, 19:50:52 »
Is this group still open? I'm wanting to start a new project to build my own mechanical keyboard specifically a Phantom! Right now i have rounded up most of my parts and currently waiting to order! But although i have found most of the parts i still need to get a Mounting plate
for the Phantom! specifically ANSI 150... That is why i was wondering IS THE GROUP OPEN??? Thanks - <3 Logan.W
Offline strict
  • TKL Zealot
« Reply #212 on: Mon, 15 December 2014, 20:16:08 »
Sorry, orders for this group buy are closed. However, If you're looking for an ANSI 150 plate you are in luck, I have a few leftover plates for sale in my classifieds thread.
