Author Topic: [GB] Stainless Steel Phantom Plates - ANSI 125, 150, 7BIT [CLOSED]  (Read 65066 times)
Offline telnet
Re: [GB] Stainless Steel Phantom Plates - ANSI 125, 150, 7BIT
« Reply #50 on: Mon, 11 August 2014, 11:59:32 »
We need a few more buyers to get this GB rolling.
I really want to get my 7bit plate.
QFR Frosty Flake | 7bit Phantom
Offline Blackehart
« Reply #51 on: Mon, 11 August 2014, 13:10:55 »
I apologize if i missed it but are these plates switch moddable?
Offline strict
  • TKL Zealot
« Reply #52 on: Mon, 11 August 2014, 13:45:44 »
Yep, all plates allow for easy switch top removal :thumb:
Offline Blackehart
« Reply #53 on: Mon, 11 August 2014, 14:58:34 »
One last thing...
 Please note that these plates will not fit on stock keyboards like Filco's, Ducky's, KUL's, etc.
However, the plates will fit into many popular TKL cases from Filco, Ducky, CoolerMaster, and others.
I is konfoozed.
I'm looking to get a tkl on the cheap to practice and learn soldering/desoldering, but you have filco and ducky on both the yes and the no sections...
Could I perhaps pester you for a working model? Like say, does shine 2 work?
Also, in for 1!
« Reply #54 on: Mon, 11 August 2014, 15:15:54 »
One last thing...
I is konfoozed.
Also, in for 1!
See this image...
(Photo credit: danielucf)
That green thing on the right, just above the arrow cluster, is the controller. These plates don't have the cutout for that controller, so you can't use these Phantom plates with a Filco PCB or QFR PCB.
However, you CAN use the Phantom PCB with this plate in a Filco TKL or QFR case.
« Last Edit: Mon, 11 August 2014, 15:18:41 by jdcarpe »
Offline Blackehart
« Reply #55 on: Mon, 11 August 2014, 18:41:22 »
snipped for brevity
AH! so I still require a phantom pcb, ok.
Thanks for the help!
Offline strict
  • TKL Zealot
« Reply #56 on: Sat, 16 August 2014, 22:19:06 »
30 plates ordered currently so we're getting very close to reaching MOQ! My hope is to be able to close the order form tomorrow evening so get your orders submitted now.
Offline aicrono
    • A Touching Experience
« Reply #57 on: Sun, 17 August 2014, 10:49:20 »
In the event that the MOQ is not met today, do you plan on extending the dead line?
Offline strict
  • TKL Zealot
« Reply #58 on: Sun, 17 August 2014, 11:17:58 »
I don't mind extending the deadline for another couple days or a week. 6 plates is still a ways to go and too many for me to absorb.
Offline aicrono
« Reply #59 on: Sun, 17 August 2014, 12:17:21 »
Lets hope those last minute buyers show. :)
« Reply #60 on: Sun, 17 August 2014, 12:37:23 »
the 7bit plate could make a good lubing station.
Offline telnet
« Reply #61 on: Sun, 17 August 2014, 23:25:54 »
Please extend the deadline.  I really want to build a 7bit board and this is my only source to get a plate.
Offline strict
  • TKL Zealot
« Reply #62 on: Tue, 19 August 2014, 07:33:03 »
Extending the deadline just until Aug 31. If we cant get 6 more plate orders by that point then I'm going to have to close this out :(
Offline nathairtras
« Reply #63 on: Tue, 19 August 2014, 14:48:10 »
I shouldn't be spending money right now, but sorely tempted to get a 7bit plate even though I don't have a phantom PCB.  Will have to sleep on it.
CM QFR Green
Offline AKmalamute
  • HHKB Scrub
« Reply #64 on: Tue, 19 August 2014, 16:57:36 »
A further thought: MK carries the boards, and will for the foreseeable future. So, get the plate during this GB, and in a month or two when your finances level out, get the board for $32 (free CONUS shipping!) and they carry switches too, or use your existing stock, or whatever. You won't need to get it all at once, and really the only time sensitive part is this plate.
I'm in for a 7-bit plate, myself so yes, I'm in here trying to drum up interest so the GB doesn't go flat on me.
HHKB-lite2, Dvorak user
Offline nathairtras
« Reply #65 on: Tue, 19 August 2014, 17:32:39 »
...you convinced me.  ;D
CM QFR Green
Offline telnet
« Reply #66 on: Tue, 19 August 2014, 19:18:26 »
That's pretty much the same reason why I picked up two plates.  I'm only going to build one for now.
Getting two plates also means the overall shipping per plate is cheaper, especially since it's $25 for international shipping.
Offline strict
  • TKL Zealot
« Reply #67 on: Fri, 22 August 2014, 15:28:15 »
I informed the metal shop to expect an order here in the next few weeks so that they can get some fresh stainless in for us.  :thumb:
We are close enough now that even if we don't make MOQ that I will cover however many are needed to place the order and then try to sell them in the classifieds. Though if its up to me I will probably just get all ANSI 125 ...
Offline telnet
« Reply #68 on: Fri, 22 August 2014, 15:55:26 »
I don't think you will have a hard time selling them.  It's so hard to find a phantom plate.
Offline AKmalamute
  • HHKB Scrub
« Reply #69 on: Fri, 22 August 2014, 16:51:02 »
That's your cue, everybody! Dogpile onto this GB and buy the excellent ANSI150 or exotic 7-bit, before the market gets flooded with mediocrity!
Although, how mediocre is a fully reprogrammable keyboard with keyswitches entirely of your choosing, really?
Offline aicrono
« Reply #70 on: Fri, 22 August 2014, 20:20:29 »
Excellent news! I was getting worried there for a little bit as I had already bought and received the rest of my Phantom build and all I had left was the plate.
Now I need to decide if I want to build it with the ANSI125 or 7bit plate...
Offline retrochick
  • goodbye my wallet
« Reply #71 on: Sat, 23 August 2014, 19:09:59 »
This is sweet. Just to double check the ANSI 125 will work with this, correct?
« Reply #72 on: Sat, 23 August 2014, 19:52:11 »
Yes, either of these plates will. That's exactly the PCB they are designed for. :)
Offline retrochick
  • goodbye my wallet
« Reply #73 on: Sun, 24 August 2014, 11:51:36 »
Awesome. Thank you kind sir!
Offline retrochick
  • goodbye my wallet
« Reply #74 on: Sun, 24 August 2014, 11:58:00 »
Just put in an order for 2 plates, hopefully that will put us closer to the MOQ  :cool:
Offline tchuyev
« Reply #75 on: Mon, 25 August 2014, 08:46:05 »
Hi, any chance for an ISO layout with 1.25x wide modifiers?
I would order a couple of them if available.
Thanks.
« Last Edit: Mon, 25 August 2014, 09:37:54 by tchuyev »
Offline strict
  • TKL Zealot
« Reply #76 on: Mon, 25 August 2014, 09:38:36 »
Thanks.
Sorry, only offering the three plates in the OP
Offline telnet
« Reply #77 on: Wed, 27 August 2014, 16:12:27 »
Now that we're at 36 we're going to get our plates right?   :thumb:
Offline TheMoonUnderWater
« Reply #78 on: Wed, 27 August 2014, 16:48:28 »
Order placed. Tempted to get a second... How do I go about that, pm?
Offline strict
  • TKL Zealot
« Reply #79 on: Wed, 27 August 2014, 17:00:39 »
Yep  :cool:
If you want to make changes to your order just shoot me a PM and I will take care of it  :thumb:
Offline orangeju1ce
« Reply #80 on: Wed, 27 August 2014, 20:32:30 »
Hello!
I hope i'm not too late for the group buy. School just started and it's been busy..
Offline aicrono
« Reply #81 on: Thu, 28 August 2014, 00:19:50 »
Hello!
You are just in time. The last day to order is August 31st so you still have a couple of days. Get in while you can if you haven't already :)
Offline orangeju1ce
« Reply #82 on: Thu, 28 August 2014, 00:49:29 »
Hello!
This is my first group buy on GH. I don't expect I'll be immediately working on a phantom keyboard for a while, but what is the usual time frame for things like this? I want to finish this keyboard by March 2015 since that's when my gf's bday is.
Also, what kind of cases are you guys using for the phantom pcb?  I am ordering the 7BIT layout but i'm not sure where to search for top plates for this design.
I also have another questions about diodes-- http://www.digikey.com/product-detail/en/1N4148/1N4148FS-ND/458603 the Phantom PCB says they use  the 1N4148 diodes, but on the website they offer the 1N4148FS-ND and the regular one. What is the difference between these two? Does one function different from the other? Is one like the generic of the other kind of diode? I want to know for future reference in buying diodes.
Thanks for reading!
Offline chzel
« Reply #83 on: Thu, 28 August 2014, 08:07:10 »
The diodes you mention (1N4148FS-ND) are made by Fairchild Semiconductors (FS) ensuring good performance,
but,since diodes in keyboards are used to sth like 0.0000001% of their capacity, feel free to get the generic ones. Just test them for duds!
Offline AKmalamute
  • HHKB Scrub
« Reply #84 on: Thu, 28 August 2014, 13:27:53 »
Also getting the 7-bit! No idea!
 Right now I'm using an ANSI150 layout with no case -- just laying the bare PCB on my lap. Works fine. But if I get a case of some form I'll let everybody know where I got it.
There was a page with some code MOZ put together that would create .dxf files for plates ... I think he had a generic case that assumed you were using plates as created by that software ... but the case assumed the plate went all the way out to the edge of the case and would like flush with every other layer. Not sure how much jury rigging would be needed to make such an acrylic case accept a steel plate of the correct proportions.
« Reply #85 on: Thu, 28 August 2014, 17:26:37 »
Yep  :cool:
Cool. Pm sent, thanks.
Offline mdf
« Reply #86 on: Fri, 29 August 2014, 16:55:10 »
Just hit up the form!
Thanks for coordinating this, can't wait, will be my first build.
Offline echo0
« Reply #87 on: Sun, 31 August 2014, 09:58:18 »
PM sent - adding one more plate to the order.
Thanks...   :D
Offline strict
  • TKL Zealot
« Reply #88 on: Sun, 31 August 2014, 10:41:05 »
Thanks...   :D
Got you taken care of  :thumb:
Since we're over MOQ I'm planning to close the order form in a few hours. I will probably start sending invoices either tomorrow or at some point this coming week. Then, once I hear back from the metal shop that our stainless steel is ready, I will submit the order.
Offline AKmalamute
  • HHKB Scrub
« Reply #89 on: Thu, 04 September 2014, 01:16:34 »
Looking forward to the invoice.
That I haven't received yet.
Everything OK?
Offline strict
  • TKL Zealot
« Reply #90 on: Thu, 04 September 2014, 07:02:45 »
Everything OK?
Invoices have not been sent out yet, hoping to get to that either tonight or tomorrow
Offline telnet
« Reply #91 on: Thu, 04 September 2014, 11:53:44 »
Everything OK?
Thanks for the update.  I was worried the invoice might have hit one of my spam filters.
Offline exfiltrate
« Reply #92 on: Thu, 04 September 2014, 17:28:54 »
Any chance I can still get in on this?
Offline strict
  • TKL Zealot
« Reply #93 on: Thu, 04 September 2014, 17:47:59 »
Shoot me a PM with what plates you want, your paypal email, and your full shipping address. I plan on sending out invoices tonight so you *just* made it in time  ;)
Offline exfiltrate
« Reply #94 on: Thu, 04 September 2014, 18:15:59 »
Thank you :)
Pm'd
Offline strict
  • TKL Zealot
Re: [GB] Stainless Steel Phantom Plates - ANSI 125, 150, 7BIT [INVOICING]
« Reply #95 on: Thu, 04 September 2014, 19:23:38 »
All invoices have been sent. If you see any problems with your invoice please get in contact with me BEFORE you pay it and I will correct it as quickly as possible.
Offline FreeCopy
« Reply #96 on: Thu, 04 September 2014, 19:44:13 »
Received. Looked good. Paid.
Thank you.
Keyboards
Poker II | Leopold fc500r | Bolt Modded M 1391401 x2 08NOV90 - 19NOV90 | FK-2001 White Alps Clones | Filco MJ2 104Bolt Modded SSK 1391472 27JUL87 | Winkeyless B.87 TKL | MiniVan GateReds 62g
Offline aicrono
« Reply #97 on: Thu, 04 September 2014, 20:02:38 »
Invoiced received and paid for  :thumb:
Now we play the waiting game...
Offline echo0
« Reply #98 on: Thu, 04 September 2014, 20:05:22 »
Invoice received and paid.  Thanks...   :cool:
Offline nathairtras
« Reply #99 on: Thu, 04 September 2014, 21:45:43 »
Paid.  Now I just need a case that will fit this with all possible switches...  and the money to buy it.  :))
CM QFR Green
