Author Topic: Help with my Model M; Lights light up, then turn off, nothing works.  (Read 4344 times)
Offline starfscker
Hello, I have a Model M from 1990.
When I plug it in, either through a USB adapter or a PS/2 port, the Caps and Scroll Lock lights turn on, then after a second the Num Lock light turns on, then they all turn off together, and nothing works.
Anyone have a clue what this means?
Offline absyrd
  • CPT HYPE PADAWAN
What USB adapter do you use? I have M's that do the same unless I use the ol' "blue cube" adapter to USB.
Offline starfscker
It does it when just using PS/2. It's a crappy 6 dollar green PS/2 to USB adapter.
Offline noway
Have you tried it on a different computer(s)?
Offline FrostyToast
  • Litshoard
Have you tried using the keyboard in the BIOS?
It might be a long shot, but when I plugged in my model m into my computer directly via ps/2 it did that exact thing and it worked in the BIOS only.
Quote from: elton5354
That might be the problem.
mkawa was selling these at one stage.  I used one to connect a Model M to a Mac - worked perfectly!
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
even the purple one gave me some issues, but the zioteck works flawless on all my stuff
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline starfscker
Yes, I've tried it on different computers, one with a PS/2 port and one without using usb. I've also tried it with usb on the one with the PS/2 port. It does not function in bios.
I've ordered the blue cube from Amazon, its reviews say it works flawlessly with the Model M. We'll see if that helps at all, but I don't think that's the problem. I've inspected the internals and I do not see any blow capacitors or flaky wiring, it all looks immaculate.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
A lot of people have issues with passive adapters.  Also keep in mind that PS/2 is not plug and play.  The computer has to be powered down when you plug it in.  Cord length seems to be the biggest variable here on whether a passive adapter works or not from what I have seen.
Offline starfscker
HOLY SHOE IT WORKS! :D
I'm so happy. I spent all that time taking apart the keyboard and painting it pretty colors and it didn't work and now it DOES. I'm using the Blue Cube mentioned in the second post. I was skeptical, but y'all were right. Thank you so much. I love you all. Happy typing.
yay yay yay yay
The quick brown fox jumped over the lazy dog. The quick brown fox jumped over the lazy dog. The quick brown fox jumped over the lazy dog. The quick brown fox said GeekHack was awesome.
:D
« Last Edit: Thu, 24 July 2014, 20:59:49 by starfscker »
Re: Help with my Model M; Lights light up, then turn off, nothing works.
« Reply #10 on: Thu, 24 July 2014, 21:13:33 »
Excellent news!  Congratulations :)
And on a side note i love the yellow keycaps ;D
