Author Topic: Keyboard Talk of the Day (KTOD) - Does keyboard height affect you?  (Read 3409 times)
Offline dante
I'm a bit of a keyboard height/profile snob - I wanted to see if I am forever alone!
So...
Does keyboard height effect you?
« Last Edit: Tue, 22 July 2014, 12:18:59 by dante »
Re: Keyboard Talk of the Day (KTOD) - Does keyboard height effect you?
« Reply #1 on: Tue, 22 July 2014, 12:16:48 »
Not in the least bit. I've literally never considered it when typing.
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
Re: Keyboard Talk of the Day (KTOD) - Does keyboard height affect you?
« Reply #2 on: Tue, 22 July 2014, 12:40:09 »
Since I don't rest my wrists on my desk, no.
Offline davkol
  •  Post Editing Timeout
« Reply #3 on: Tue, 22 July 2014, 12:48:38 »
Yes, it does. In fact, awfully lot. Unfortunately, I can't afford an adjustable keyboard tray (like the Ergotron ones on an arm) currently.
Why? I have a properly planned standing setup, but it isn't adjustable and I've found out I'm very sensitive to tray height and angle. I prefer the keyboard lower and with a slight negative slope, but pointing devices a bit higher (so that I can rest my wrist on a mousepad without bending the wrist). It's nearly impossible to configure though, especially when I rotate more keyboards of different heights and angles.
Offline maatmouse
« Reply #4 on: Tue, 22 July 2014, 13:11:11 »
I cannot have my keyboard with the legs standing up. Its uncomfortable. I prefer the feet flat down.
« Reply #5 on: Tue, 22 July 2014, 15:32:54 »
I was just imagining a custom KB with the lowest possible front height (for cherry MX). The switches would be just about resting on the desk, and it'd have a minimal slope to account for the PCB (which would end shorter so that the lowest row of switches is showing) PCB spacebar would have to be plate mount. It'd be awesome.
That said, I've never really needed one for myself. I just thought it'd be cool to design.
« Reply #6 on: Tue, 22 July 2014, 17:13:25 »
I haven't really noticed.  I went from an Apple aluminium keyboard (about the lowest you can get) to a Ducky Shine about two years ago.
I don't recall any problems adjusting to the different height.
« Reply #7 on: Tue, 22 July 2014, 17:32:32 »
not at all
Offline remdell
« Reply #8 on: Tue, 22 July 2014, 19:15:40 »
I had real problems with keyboard height when I had unorthodoxed finger positioning (I didn't used my pinkies nor my right ring finger).  Before using mechanical keyboards, I always used low-profile laptop-like keys.  When I needed to reach for a key, I would slide my fingers gently across the surface of the keys and feel for the key I'm looking for.  You can imagine how this would be a big problem when using mechanical keyboards because sliding my fingers on most standard-profile mechanical keyboards would mean I'd be hitting the edges of the keys and accidentally pressing those keys.  This was my exact problem.  I had to use heavier keys to reduce the typos caused by my bad typing habits.
I practiced for a year adding my right ring finger into my typing.  I was able to type significantly better on lighter keys, but I still wasn't able to type well on keyboards with odd layouts or really high profiles (Realforce 104UG Hi-Pro).  I've been practicing using all my fingers for a little more than a week now, and already I see less typos.  Utilizing all my fingers when typing also has made every keyboard I type on feel better.  For example, Topre keyboards just feel way better now.  It feels like I'm getting a longer and spread-out massage on my fingers because all my fingers typing away as opposed to just a select few.
Rukia PC | RF87U Digilog | Norbaforce MKII Palm Desert | Zenith ZKB-2R | Datadesk MAC-101
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #9 on: Tue, 22 July 2014, 19:56:30 »
unfortunately i'm a disabled vet................angle is better for me :D
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline Lastpilot
  • Power stance
« Reply #10 on: Tue, 22 July 2014, 21:56:41 »
Even though I really like low profile cases, I don't have a problem using ones with higher height. I mean you can always make your chair higher or your desk lower. I think the angle of the board matters more.
Offline osi
« Reply #11 on: Tue, 22 July 2014, 22:49:40 »
My most comfortable position is so that my hands 'fall' on top of my keyboard and my elbows are ~90 degrees give or take. Luckily my chair raises plenty to accommodate my board on top of the desk instead of the keyboard tray.
« Reply #12 on: Tue, 22 July 2014, 23:39:11 »
Yes! Have to have low profile cases!
Offline blackbox
« Reply #13 on: Tue, 22 July 2014, 23:59:25 »
For me Angle is ,uch more important than the height of the keyboard itself.
The LAN table!
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #14 on: Wed, 23 July 2014, 10:55:02 »
Yes. I hate really thick (tall) keyboard and steep angle. Anything with same height and angle of plastic Poker case and with Cherry profile keycap is perfect.
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
« Reply #15 on: Wed, 23 July 2014, 10:57:04 »
I think this height would affect me a bit...  ;D
Offline osi
« Reply #16 on: Wed, 23 July 2014, 11:35:58 »
Ahh height as in angled/overall.
Up until recently -- legs were always extended. Lately I've been finding the flat position to be more comfortable.
Putting DSA caps on 10 key was odd at first. The keypad was begging to be flat and I obliged--feels very natural to me atleast
Offline Demetrium
« Reply #17 on: Wed, 23 July 2014, 15:00:21 »
Opposite here!
On another note I have a tendency to rest the base of my left palm on the bottom-left corner of the keyboard. I do this constantly on my DasKeyboard at work.
When I first got a CMStorm Trigger at home this really plagued me cause there was now a row of macro keys on the left. Everything for my left hand was shifted over and it took me quite a long time to adjust (I have crap hands).
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
« Reply #18 on: Wed, 23 July 2014, 15:10:33 »
The height of the caps I don't care about one way or the other, but I do like the board at an angle. On the case that does not have little feet to angle the board for me, I stick something under it to give it the right angle. Luckily what I'm using has some nice rubberized plastic on it so it doesn't cause it to side around, and you can't see it all at when looking at the setup. If anything it anchors it more, and makes it look like it is floating.
Offline Acknown3
  • Not a keyboard addict
« Reply #19 on: Wed, 23 July 2014, 15:17:36 »
I need to keep my keyboard as flat as possible, since having the feet up makes me bend my wrist slightly upward and it feels uncomfortable.
I keep my wrist elevated while typing and on a wrist rest while gaming, but I should probably break that habit.
FC660C gray dyesub, gummyrot clack
FC660M cherry reds, Triumph Adler, blue aluminum case
Filco TKL cherry reds, white side-printed PBT
IBM Model F XT
Offline sakai4eva
« Reply #20 on: Wed, 23 July 2014, 23:17:02 »
Not really. I like them either very tall or very flat. That's why I hate OEM profiles.
Offline Oobly
« Reply #21 on: Fri, 25 July 2014, 03:37:58 »
Yup, my chair can only be raised so far, my desk height isn't adjustable and I need to rest my palms when I'm not typing. With a low board I can rest my palms on the desk, with almost all mechanicals I need a raised palm rest and with some, my chair doesn't go high enough to allow the best elbow angle and I get fatigued.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
