Author Topic: Info for this ALPS number pad?  (Read 3406 times)
Offline poeee
« on: Fri, 25 July 2014, 00:40:01 »
Offline blackbox
Re: Info for this ALPS number pad?
« Reply #1 on: Fri, 25 July 2014, 01:12:53 »
Seems like an alps skcm white clone switch with doubleshot abs keycaps.
The LAN table!
Offline poeee
« Reply #2 on: Fri, 25 July 2014, 01:17:03 »
Surely it's worth the AU$20 with free postage?  I have been after a num pad...
« Reply #3 on: Fri, 25 July 2014, 01:31:15 »
LOL I didn't even realise this was eBay Australia - so many links to eBay US :))
At least this is USB numpad - most of the mechanical ones are PS/2.  Or AT.
Offline poeee
« Reply #4 on: Fri, 25 July 2014, 01:41:44 »
We can't let the majority have it easy all the time...
« Reply #5 on: Fri, 25 July 2014, 03:19:09 »
This was posted about a long time ago in greatfinds.
I believe when people received them, they were usually not doubleshot.
I've used those switches before, and I don't like them, but your mileage may vary.
Offline poeee
« Reply #6 on: Fri, 25 July 2014, 04:16:38 »
Had a more thorough search than I did before.  I think you're refering to this thread.  http://geekhack.org/index.php?topic=16092.0
« Reply #7 on: Fri, 25 July 2014, 08:21:42 »
indeed it is!
brings back memories.
« Reply #8 on: Fri, 25 July 2014, 08:27:07 »
For $18 shipped, this might make a great case with USB cable for a 4x5 GHPad.
Offline davkol
  •  Post Editing Timeout
« Reply #9 on: Fri, 25 July 2014, 10:27:42 »
I knew I've seen this before... Well, too bad the 20key ones aren't up for sale anymore. Two of them + some Matias switches = cheap 40% ergo keyboard.
Offline blackbox
« Reply #10 on: Fri, 25 July 2014, 11:13:07 »
Hm, might need an controller..and a case, plate, and a everything else except switches.
The LAN table!
Offline xavierblak
« Reply #11 on: Fri, 25 July 2014, 11:14:51 »
I have this keypad or atleast something that looks like it hard to say when it's just a random ebay seller.
I'm no alps expert but it seemed to come with a alps clone with a clicky feel, similar in weight to an MX blue. My board came with lasered keycaps which look pretty cheap in person. They look the same as the ones pictured. The typing feel isn't too bad as the pad actually has a plate so it gives it a little weight.
Over all it's probably worth the 20 the price.
« Reply #12 on: Fri, 25 July 2014, 11:15:18 »
You'd definitely have to wire up the matrices to a new controller. You wouldn't be able to plug two numpads into your PC and have them act as separate halves of a keyboard.
Offline blackbox
« Reply #13 on: Fri, 25 July 2014, 11:19:40 »
Thanks for thaking my unserious answer so seriously(kinda) :)
The LAN table!
Offline davkol
« Reply #14 on: Fri, 25 July 2014, 11:31:31 »
Actually, not even that. There's only some udev magic needed. The only issue might be key blocking/rollover.
« Reply #15 on: Sat, 26 July 2014, 03:06:04 »
indeed it is!
In that other thread it notes that the numpad is not compatible with Macs.
Is this really the case?
Offline Doyniish
  • Good you
    • Power Hour Playlists
« Reply #16 on: Sat, 26 July 2014, 10:53:44 »
indeed it is!
Interesting, I saw this as well. I would love to have one at work to compliment my Poker. If someone could try it out on a mac that would be great!
