Author Topic: Need help with picking parts  (Read 1907 times)
Offline WannaBeOCer
« on: Tue, 29 July 2014, 23:14:30 »
I saw a video yesterday where a Phantom keyboard was put together. When ever I tried to do research all the useful links brought me to this forum. Before I dive right in, I wanted to know what options I have beside the Phantom PCB and where I can order them from. I am planning on building a 87 key keyboard. Also if you do recommend a PCB can you also link to a compatible aluminium housing + plate. I am also looking for a board that has firmware support because I am not familiar to programming.
I saw a few different PCBs but could not find where to order them. Seems like the only two I see that are 87 boards is the MX-1800 and Phantom.
Thank you
Offline loud_asian
Re: Need help with picking parts
« Reply #1 on: Wed, 30 July 2014, 00:06:02 »
http://geekhack.org/index.php?topic=50580.0
I think this will interest you. Its multiple pcbs with different layouts for each pcb. Groupbuy also has acrylic and metal cases for sale.
Offline WannaBeOCer
« Reply #2 on: Wed, 30 July 2014, 00:29:25 »
Fantastic! I was looking for a PCB that would allow me to mount the switches directly on the PCB. Also do you have any clue where I can get MX Clears with diodes inside? Or can I put my own diodes inside MX Cherries?
« Reply #3 on: Wed, 30 July 2014, 01:49:59 »
easiest way is to desolder them from a G80-8200 or g80-8113, but be careful! many have browns. Also all USB ones have jumpers instead of diodes: very annoying.
You can order clears with diodes as a normal part number but I recommend just soldering diodes to the bottom. opening all the switches is a pain!
of course if you are going for ergo clears it's not so bad. Keep in mind you can't do backlit with in-switch diodes, so it's up to you.
You can put your own diodes in there though if you want: they accept a standard size 1n4148 through hole diode.
