Author Topic: [Help] Noppoo Choc Mini 84 USB (Brown Switches) Spacebar  (Read 2743 times)
Offline nnug23
« on: Sat, 02 August 2014, 14:57:21 »
Hi first time posting on here
I recently got the Noppoo choc mini and the spacebar seems to be very loose
Video
I have taken the spacebar off here are some pics I took of what it looks like
http://imgur.com/a/bXvZD
I have been searching on how to fix it but to no avail i found this forum from various links can anyone help it's driving me nuts
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
Re: [Help] Noppoo Choc Mini 84 USB (Brown Switches) Spacebar
« Reply #1 on: Sat, 02 August 2014, 15:12:09 »
Does it still not work when you put the space bar back on?
From the photos, everything looks OK — the space bar seems to have just come off at one end and needs putting back on again.
Admittedly, it's a faff putting those back together, which is one reason I prefer Cherry stabilisers. The ends of the wire go into the plastic inserts at each end of the keycap, and you just swing it down and press the keycap back onto the switch.
Bore Awards
Offline nnug23
« Reply #2 on: Sat, 02 August 2014, 15:28:41 »
thank you so much!! yes its very fiddly :D
  • RIP
    • Boring twaddle
« Reply #3 on: Sat, 02 August 2014, 15:32:42 »
Good practice for when you inevitably get into keycap replacement …
Bore Awards
Offline Defect
« Reply #4 on: Sun, 03 August 2014, 08:12:03 »
FYI a $3 tube of silicone grease makes the choc mini (and costar stabilizers everywhere) endlessly better.  And you'd only be using 1/10 of that tube.
  • RIP
    • Boring twaddle
« Reply #5 on: Sun, 03 August 2014, 08:14:04 »
You mean it gets rid of the clang? It can only be "endlessly" better if it also makes it easy to get keycaps on and off.
Bore Awards
Offline Defect
« Reply #6 on: Sun, 03 August 2014, 10:28:02 »
Choc mini spacebar's are pretty rattley.  Rattly?
