Author Topic: What the heck is this switch?  (Read 3378 times)
« on: Tue, 05 August 2014, 19:53:24 »
I did my due diligence, but couldn't find anything that resembled this on the DT wiki, mousefan's site, and so on.  The closest is the TaiHao Aruz Anyone have a clue what it is?  Sorry I don't have a better picture, it's not my keyboard.
Re: What the heck is this switch?
« Reply #1 on: Tue, 05 August 2014, 22:17:30 »
it appears to be a slider / spring over membrane type design, but it might be a rubber dome over membrane.
« Reply #2 on: Tue, 05 August 2014, 22:21:13 »
That's what I was thinking.  Thanks for the confirmation.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #3 on: Tue, 05 August 2014, 22:26:02 »
still looks like it will take an alps cap? is that a steel plate??
here's a shot of my "aruz"
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #4 on: Tue, 05 August 2014, 22:36:04 »
what does someone suppose the plastic stem inside is for?
anybody able to put a manufacturer or name on it?
good eye nubbs.........
« Last Edit: Tue, 05 August 2014, 22:40:35 by terrpn »
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #5 on: Wed, 06 August 2014, 13:30:40 »
I think this is the Alps mount analogue of a MY switch. Looks like a Chicony? I came across one such in a fleamarket and it was equally as pleasant as MY.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #6 on: Wed, 06 August 2014, 14:03:23 »
interesting...............never knew that :eek:
so definitely a RD then i reckon.................
Offline paicrai
  • mindblank
« Reply #7 on: Wed, 06 August 2014, 14:37:45 »
probably a lightswitch :P
THE FEMINIST ILLUMINATI
« Reply #8 on: Wed, 06 August 2014, 15:16:51 »
I think he meant it was like MY, meaning spring(s) of some sort over membrane and not rubber dome.
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #9 on: Wed, 06 August 2014, 17:59:41 »
The style of the case is very similar to my Oriental Tech OK-100M (which is indeed progressive rate spring over membrane) but it's not the same. There were quite a few keyboards in that style.
The keycaps appear to be Tai-Hao Alps mount double-shots, identical to mine — the keyboard should be documented on the wiki and then promptly harvested for its very nice keycaps.
It looks like the slider guide shafts are moulded into a plastic plate.
Is there not a label of any kind on the back? You might also find clues from what's written on the membranes.
Bore Awards
« Reply #10 on: Wed, 06 August 2014, 19:33:52 »
It's this keyboard.  I did all the research I could on it, including an FCC ID lookup, but there's not a lot of details on it.  The caps looked pad printed to me, not doubleshots.  I just hadn't seen that switch before and was trying to figure it out.
  • RIP
    • Boring twaddle
« Reply #11 on: Thu, 07 August 2014, 02:27:13 »
Compare with these keycaps:
http://deskthority.net/wiki/Oriental_Tech_OK-100_series
They're identical. They will be a nice set of doubleshots, presumably Alps mount.
You can see them here on a Dell AT102W with some of the original laser-etched keycaps for comparison:
http://deskthority.net/wiki/File:Laser_etching_vs_double-shot_%28detail%29.jpg
Bore Awards
