Author Topic: laser etched PBT keycaps.  (Read 2968 times)
Offline henz
  • What?
« on: Mon, 11 August 2014, 04:47:02 »
Ducky has a set of laser etched pbt keycaps with gold legends,
Do you guys have any experiece with these caps?
Im thinking of ordering them for temporary use.
And then sell them, So i would want the wear and tear to be minimal
Offline phoenix1234
Re: laser etched PBT keycaps.
« Reply #1 on: Mon, 11 August 2014, 04:52:37 »
The Ducky set that you mention could be the thin PBT, OEM profile.
Indeed, if could be last for very long before the wearing can appear.
Anyway, you should consider this thick PBT set instead.
http://geekhack.org/index.php?topic=59780.0
I like linear switches
Offline henz
  • What?
« Reply #2 on: Mon, 11 August 2014, 05:07:19 »
Problem is that i need a ISO kit :)
Offline Oobly
« Reply #3 on: Mon, 11 August 2014, 06:42:06 »
Laser etched PBT will last a good long while before wear starts to show, so I think they'll do what you want.
If the set you're referring to is the 111 key set like this: https://www.teraset.net/product_details.php?p=9332#.U-iriWOEyHs
then it's thick PBT. Very nice keycaps.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline henz
  • What?
« Reply #4 on: Mon, 11 August 2014, 07:05:10 »
Cool, then ill order them, thanks.
