Author Topic: WKL Question  (Read 3039 times)
Offline Blackehart
WKL Question
« on: Tue, 12 August 2014, 16:03:05 »
So why is it called winkeyless?
Ive seen a 1x or regular windows key sized key between the ctrl and alt keys on a WKL setup.
Can that key be set to the windows key?
Whats the point of having that key? Is it functional?
I could see functionality of a MENULESS setup... *shrug*
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: WKL Question
« Reply #1 on: Tue, 12 August 2014, 16:17:17 »
Winkeyless is used to describe 101 keyboards made before 1995. These don't have Windows or menu key. Others with a 1.5 1 1.5 7 1.5 1 1.5 bottom row are typically customs and the 1 units keys can be assigned to anything the user wish. There are older keyboards with that too... but they often had some special function assigned to them such as on the Cherry G80-1600.
« Last Edit: Tue, 12 August 2014, 16:20:00 by IvanIvanovich »
Offline Blackehart
Re: WKL Question
« Reply #2 on: Tue, 12 August 2014, 17:11:41 »
So IN THEORY, I COULD program a WKL to have a winkey but not a menu key?
Offline absyrd
  • CPT HYPE PADAWAN
Re: WKL Question
« Reply #3 on: Tue, 12 August 2014, 17:26:32 »
Fully programmable board is fully programmable. :p
Re: WKL Question
« Reply #4 on: Tue, 12 August 2014, 17:38:47 »
Right well if you are talking about customs like KMAC, LZ, etc... those are programmable so you can do whatever you want. For stock boards like vintage G80-1000 or something, you can use some kind of remapping utility like sharpkeys but you have to decide what other key to sacrifice on the reassignment since you can't physically add any extra keys to that. For example when I am using old winkeyless Cherry board I may reassign caps lock to Windows since I find Windows key very indispensable on Windows 8.1 while the caps lock key is essentially useless to me. If I want to get context menu I just use the mouse and right click.
Offline Blackehart
Re: WKL Question
« Reply #5 on: Wed, 13 August 2014, 10:51:02 »
EXCELLENT!
I thought that winkey meant not having it in the programming aside from not having it on the keys.
Offline Quardah
    • DeliTech
Re: WKL Question
« Reply #6 on: Wed, 13 August 2014, 13:55:02 »
Lol these are my favorite threads.
Some Question
IvanIvanovich 3 lines super-complete detailed answers
/thread
See my blog here : https://delitech.live
Poker II - Brown MX
Ducky One II TKL - Silver MX
TEX Shinobi - Clear MX
