Author Topic: Help with repair of Model F foot  (Read 1942 times)
Offline ShawnMeg
« on: Tue, 12 August 2014, 21:09:59 »
I was hoping some of the experts here on the forum can give me some suggestions on the best way to fix this.  I'm not much of a repair person.  The plastic foot is broken.
Thanks.
« Last Edit: Sun, 21 December 2014, 19:27:17 by ShawnMeg »
IBM Model F122 X 2 internal Soarer's || IBM Model M122 internal Soarer's || AEK II SKCM Salmon ALPS external adb_usb converter ||  AEK M0115 SKCM Orange ALPS click mod external adb_usb converter || AEK M0115 SKCM Salmon ALPS external adb_usb converter ||
Offline E TwentyNine
    • Some of My Keyboards
Re: Help with repair of Model F foot
« Reply #1 on: Tue, 12 August 2014, 21:24:50 »
Before you do anything you're going to need to pull the back off and remove the foot from the case.  It comes out easy.
I think a good two-part liquid epoxy - gorilla has some that come in a dual syringe, don't get the fast-setting stuff - would do the trick nicely.
I have no direct experience doing that with this particular part but have used it on M cases (which are not the same type of material) with success.
Also think I saw someone selling these or the maybe AT foot on shapeways.
Offline Muh Fugen
« Reply #2 on: Wed, 13 August 2014, 18:29:43 »
If you can find someone who has the appropriate tools, ultrasonic welding would probably be your best bet.
Offline ShawnMeg
« Reply #3 on: Wed, 13 August 2014, 19:17:25 »
Thanks.  I saw the webpage with the 3D printing of the foot.  I'll see if there is anyone closeby who can do ultrasonic welding.
« Reply #4 on: Wed, 13 August 2014, 19:19:41 »
I would try a good quality epoxy first. It can be very strong.
Funny to see that break. Usually it is the "ears" that break off.
- Oliver Willis 2026-08-01
Offline Parak
« Reply #5 on: Wed, 13 August 2014, 19:44:09 »
A recent delivery of a 'few' Model Fs resulted in 5 with broken handles on the feet, and only three of them were recovered. So, I'm in a similar boat. Sigh.
« Reply #6 on: Wed, 13 August 2014, 20:00:05 »
I successfully filed the broken stubs flat and sanded the circles to a pretty nice finish.
That gave me a pair of "tab-less" feet (they still work fine if you simply push them with your finger) and it can't happen again!
Offline Parak
« Reply #7 on: Wed, 13 August 2014, 20:51:38 »
Most excellent idea sir - I'll do that, thanks :D
« Reply #8 on: Wed, 13 August 2014, 21:26:31 »
I think this would be a better look than stock, the tabs seem useless.
