Author Topic: Using TEX TKL aluminum case with KUL ES-87?  (Read 3787 times)
Offline swornxin
    • Nailed Down Custom Pins
« on: Fri, 15 August 2014, 12:04:29 »
As asked in thread title, will the TEX TKL aluminum case fit correctly on the KUL ES-87?  Has anyone tried it before?
I've posted this question a few different places, and I haven't gotten an answer yet.  I emailed MechanicalKeyboards.com, because they carry both of the items, but they have told me that checking would mean they'd have to open up the keyboard and thus void the warranty, which they aren't will to do.
Thanks in advance!
Octagon - 62g Cherry tactile greys
Phantom - 65g Cherry tactile greys
FC660M - Cherry blues
KC60 - Gateron browns
Re: Using TEX TKL aluminum case with KUL ES-87?
« Reply #1 on: Fri, 15 August 2014, 13:32:35 »
afaik it won't since KUL doesn't have filco mounting holes
I'll get back to you on this
Offline swornxin
« Reply #2 on: Fri, 15 August 2014, 15:39:27 »
Thank you.  I appreciate it.  Even MKB.com couldn't tell me as much as you already have.  Haha.
Offline Lastpilot
  • Power stance
« Reply #3 on: Fri, 15 August 2014, 15:47:49 »
Unfortunately, looks like they have different mounting holes.
KUL:
Filco:
Phantom:
Offline MJ45
  • HHKB Pro
« Reply #4 on: Fri, 15 August 2014, 16:12:16 »
I thought those cases hold the plate between the top & bottom of the case, not needing standoffs in the lower section? The pcb is suspended by the plate only like the Vortex cases they sold before, the mounting holes aren't used. As long as the plate is the same dimensions as a Filco it might work.
Offline Lastpilot
  • Power stance
« Reply #5 on: Fri, 15 August 2014, 16:15:51 »
I can't prove this with numbers, but just looking at the PCB's it looks like the KUL has more width.
« Reply #6 on: Fri, 15 August 2014, 16:30:09 »
the KUL is certainly bigger than a filco, yes
and if the pictures are accurate, that would make the PCB/plate bigger as well.
