Author Topic: Best Retrobrite Recipe  (Read 8988 times)
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« on: Mon, 18 August 2014, 10:34:04 »
74914-0
So I just got this keyboard not to long ago, though it appears as though it hasn't been cleaned in it's 20+ years of use. With all the different combinations, what Retrobrite recipe have you seen the most success with?
Re: Best Retrobrite Recipe
« Reply #1 on: Mon, 18 August 2014, 21:23:46 »
I use straight hydrogen peroxide with the percentage contingent upon how long I want it to take/how yellow it is and what I have available.  From what I've seen, you won't run into blooming issues with straight H2O2, but can with the additives.  Some people don't feel it gets as white without the Oxy and whatnot, but I prefer a less white with no blooming to whiter with a chance of bloom.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #2 on: Mon, 18 August 2014, 22:00:14 »
Yeah, from what people have said I might just go with h2o2 with a little oxy
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #3 on: Mon, 18 August 2014, 22:06:20 »
Would the 35% stuff work?
« Reply #4 on: Mon, 18 August 2014, 22:13:00 »
Are you talking the stuff you get at a beauty supply store?  I'd go with the highest you can get, like this 40 Developer.  You can either get a cream and brush it on or do the liquid.
« Reply #5 on: Mon, 18 August 2014, 22:13:28 »
I did 40 volume peroxide from Sally's. Volume not %
5 hours of sun.
Good luck!
Offline hwood34
  • underwater squad
  • #1 CL stan
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #8 on: Mon, 18 August 2014, 22:25:20 »
http://www.sallybeauty.com/Clairol-Professional-pure-white-creme-developer-40-Volume/SBS-320828,default,pd.html#start=9
So this would work also?
I did the clear version (liquid) but needed a lot to cover my case. Was like $2.50 a bottle though in store.
http://www.sallybeauty.com/on/demandware.store/Sites-SA-Site/default/mProduct-Show?pid=SLNCAR67&start=10&q=Peroxide%2040
Alright, I'll just go for the 32oz since it's only like $5 and if it isn't enough to cover the case I'll just flip it upside down with some spacers or something. Thanks!
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #9 on: Mon, 18 August 2014, 22:25:41 »
I was wondering on this as well.  I got some AEK II parts that need this done.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #10 on: Mon, 18 August 2014, 22:52:55 »
i guess everybody has what works best for the..........
i just get oxy clean from walmart- 1 heaping scoop (included) to 1 gallon of water, 2 cups of hydrogen peroxide and at least 4 hours of good sunlight
keycaps can be a little more stubborn
i really have not not ran into any blooming yet, but i will watch better after reading nubbs comments
some people put a mirror under to get better uv
i also asked maybe someone one can cover at next KEYCON
« Last Edit: Mon, 18 August 2014, 22:55:15 by terrpn »
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline engicoder
« Reply #11 on: Mon, 18 August 2014, 23:15:35 »
I mixed about 1 teaspoon oxy clean with about 1.5 gallons of H2O2 and still had some bloom.
Offline whiskytango
  • Don't touch the trim
« Reply #12 on: Mon, 18 August 2014, 23:18:37 »
i used this method more or less: http://deskthority.net/workshop-f7/retrobright-madness-t667.html
I bought a small fluorescent blacklight at walmart and built a little retr0brighting cabinet out of a cardboard box which I lined with aluminum foil for reflecting.
I have experienced bloom, although it appears to be sometimes random and depends on the plastic. I have had some keys bloom while others in the same batch did not. I have found that WYSE thick DS caps, for instance, are more prone to bloom than thin ones.
On a separate occasion I also experienced bloom when I used too much oxy. I have had a lot of good results too though. I suggest not leaving them in too long at a time without checking them.
My standard recipe was 1/4 teaspoon of oxy to 500ml of 40 vol developer from beauty supply store. Mix the oxy with just enough warm water to dissolve it fully. I think dissolving the oxy fully prior to adding it to the developer is key. Any undissolved granules of oxy I think can concentrate in one place and casue bloom. This is only my own theory. Not sure about the science part.
« Last Edit: Mon, 18 August 2014, 23:20:29 by whiskytango »
