Author Topic: Name this board...  (Read 5134 times)
Offline o2dazone
Name this board...
« on: Wed, 10 June 2009, 21:28:41 »
It's got the shape of a Realforce (without the top area or the arrows, etc), but the comments mention MX (Cherry?) and it's got a Filco keycap. Anyone know?
from KbdMania.net
Horribly translated page
Offline huha
Name this board...
« Reply #1 on: Wed, 10 June 2009, 21:44:00 »
It looks like a standard controller, so most likely no capacitive matrix scanning going on there. I'd suspect MX switches then.
edit: Okay. You can clearly see the PCB was cut off, and the switches are of the plate-mounted variety (no jumper wires there). The strain relief looks suspiciously Filco-ish, so I suspect it's a filco with most of the stuff cut off.
-huha
« Last Edit: Wed, 10 June 2009, 21:49:00 by huha »
Unicomp Endurapro 105 (blank keycaps, BS) // Cherry G80-3000LSCDE-2 (blues, modded to green MX) // Cherry G80-3000LAMDE-0 (blacks, 2x) // Cherry G80-11900LTMDE-0 (blacks, 2x) // Compaq G80-11801 (browns) // Epson Q203A (Fujitsu Peerless) // IBM Model M2 (BS) // Boscom AS400 Terminal Emulator (OEM\'d Unicomp, BS, 2x) // Dell AT102DW (black Alps) // Mechanical Touch (chinese BS) Acer 6312-KW (Acer mechanics on membrane) // Cherry G84-4100 (ML) // Cherry G80-1000HAD (NKRO, blacks)
Offline majestouch
  • * Commercial Vendor
    • http:///elitekeyboards.com
Name this board...
« Reply #2 on: Wed, 10 June 2009, 21:51:36 »
My best guess is that it is a very HIGHLY modded FILCO FKB104xxxx or FKBN104xxxx due to the position of the cable coming in.
Offline watduzhkstand4
Name this board...
« Reply #3 on: Wed, 10 June 2009, 22:38:51 »
that board looks sick. I thought it was a Filco at first or a Topre.
KEYBOARDS
Cherry Blue *Filco Tenkeyless w/ blank keys* w/ red ESC key thanks to Megarat
Cherry Red Noppoo Choc Mini
IBM Model M 1391401 12/15/88
Siig Minitouch w/ White Alps
SOLD
HHKB Pro 2 white w/ blank keys red ESC key and blank WASD keys
HHKB L-2
Cherry Brown Compaq mx11800
Dell AT101W
Cherry Red Leopold 104-key Otaku FC500RR/ABN
Offline wheel83
Name this board...
« Reply #4 on: Wed, 10 June 2009, 22:41:42 »
they dont eff around in japan thats for sure.  that kbdmania.net is a ****house of quality mods lol
I <3 BS
Offline chimera15
Name this board...
« Reply #5 on: Wed, 10 June 2009, 22:57:15 »
Yeah, beautiful board.  Dreamboard for a lot of us here I would expect.  They figured out the color coded, no printed key number keys as well that's lost on hhk's.  You can actually figure out what number you're pressing if you need to for passwords, but still look cool. lol  I wish it was more muted colors, but still really great layout.
Alps boards:
white real complicated: 1x modified siiig minitouch kb1903,  hhkb light2 english steampunk hack, wireless siig minitouch hack
white with rubber damper(cream)+clicky springs: 2x modified siig minitouch kb1903 1x modified siig minitouch kb1948
white fake simplified:   1x white smk-85, 1x Steampunk compact board hack
white real simplified: 1x unitek k-258
low profile: 1x mint m1242 in box
black: ultra mini wrist keyboard hack
blue: Japanese hhk2 lite hack, 1x siig minitouch pcb/doubleshot dc-2014 caps. kb1903, 1x modified kb1948 Siig minitouch
rainbow test boards:  mck-84sx
Offline huha
Name this board...
« Reply #6 on: Wed, 10 June 2009, 23:34:52 »
Quote from: wheel83;95357
Korea.
-huha
Offline lowpoly
Name this board...
« Reply #7 on: Thu, 11 June 2009, 12:08:42 »
Good work on the case as well.
Offline o2dazone
Name this board...
« Reply #8 on: Thu, 11 June 2009, 12:31:39 »
On the right hand side you can see a very very light line there where they took the "cheek" of the board and glued it. Could be just the photo but yeah, impressive. I love the jumper lines on the circuit board, so neat and clean...
Offline itlnstln
Name this board...
« Reply #9 on: Thu, 11 June 2009, 12:45:36 »
I wouldn't mind getting a tenkeyless Filco, but what I realized is there is no numpad function at all unlike the IBM minis.  It's a shame, because I really need the numpad at work.
Offline majestouch
Name this board...
« Reply #10 on: Thu, 11 June 2009, 12:52:09 »
Quote from: itlnstln;95487
Autohotkey? Someone sent me a script to do just that a couple weeks ago.
Offline itlnstln
Name this board...
« Reply #11 on: Thu, 11 June 2009, 13:28:17 »
Quote from: majestouch;95490
That would require work.  For that, I would just rather have the full-blown numpad.
Offline sixty
    • http://deskthority.net
Name this board...
« Reply #12 on: Thu, 11 June 2009, 13:32:59 »
The controller used on this board is the LIMKB (Less is more Keyboard Controller) which was developed by the guys over at OTD and is pretty popular for all Korean Keyboard mods.
That controller also offers various custom features including macros and custom modifier/fn keys. So this board here might aswell have a virtual numpad!
If required I can ask a Korean friend later what exactly the post says, even though there doesn't seem to be much info in it.
Offline huha
Name this board...
« Reply #13 on: Thu, 11 June 2009, 15:02:39 »
The keyboard uses a LIMKB. Should be a quite decent controller, I'm currently only lacking the oscillator to try it out, which should arrive in a few days.
-huha
Offline talis
Name this board...
« Reply #14 on: Thu, 11 June 2009, 15:08:18 »
Quote from: huha;95533
-huha
What Microcontroller does it use? Looks like a PIC16F or PIC18 series.
« Last Edit: Thu, 11 June 2009, 15:10:22 by talis »
Offline bsvP585hUO2Y6
Re: Name this board...
« Reply #15 on: Thu, 11 June 2009, 15:22:15 »
talis writes:
It's an atmega32.  Here's a proper picture of it:
http://www.kbdmania.net/xe/582395
regards,
andreas
« Last Edit: Thu, 11 June 2009, 15:24:24 by bsvP585hUO2Y6 »
Offline talis
Name this board...
« Reply #16 on: Thu, 11 June 2009, 15:30:44 »
Ah thanks, much easier to see in that picture.  The blob in the others sort of looked like the Microchip M logo.
Offline IBI
Name this board...
« Reply #17 on: Thu, 11 June 2009, 15:33:57 »
Quote from: ripster;95485
Where'd Majestouch go?  Just tell Filco to build one willya?  The market needs a good quality mini board with a good arrow layout.
Preferably after they start building the European versions.
On the other hand it does mean there's no poxy hardware programmed FN key that can't be used for anything and takes up prime real estate. I'd just go for an autohotkey script, just making a numpad won't take much work, especially if you only need the numbers and not the numlock off functions.
Owned: Raptor-Gaming K1 (linear MX)(Broken), IBM Model M UK, Dell AT102W, Left-handed keyboard with Type 1 Simplified Alps.
