Author Topic: tablets compatible with end-game KB's mentioned here?  (Read 3646 times)
Offline paobit
« on: Tue, 26 August 2014, 02:59:23 »
Hey guys I just started school and was thinking of buying a laptop. Then I realized I spent alot of money on some "end-game" KB's such as a duck, gon, etc. and I actually wanna show these off  :p. Then I realized buying a laptop would be too bulky and weird since I want to use these KB's. Do you guys have any experience on finding any tablets good for college use but can also be compatible with these keyboards?
I was thinking somewhere along the performance line of a surface pro 3 where it is made to be almost like a work laptop.
hehe basically a laptop without a built in keyboard.
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: tablets compatible with end-game KB's mentioned here?
« Reply #1 on: Tue, 26 August 2014, 11:36:50 »
As far as I understand, any tablet that has a fullsize USB A plug should accommodate a keyboard out of the box. Others have a micro AB OTG plug where you will need an adapter or USB hub with OTG plug to use keyboards. Some other models have neither of those, some may have some proprietary adapter that will allow it, but not necessarily.
« Reply #2 on: Tue, 26 August 2014, 12:09:24 »
fancy keyboards are just regular keyboards on the inside
« Reply #3 on: Tue, 26 August 2014, 12:11:54 »
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #4 on: Tue, 26 August 2014, 12:30:15 »
The, the only real problems you might run into are plugging in things that require drivers, which the tablet won't accept
Offline taylordcraig
« Reply #5 on: Tue, 26 August 2014, 12:31:40 »
Can't tell if sarcasm:
statement is right and wrong for a plethora of reasons.
edit: also regular could mean anything.
« Reply #6 on: Tue, 26 August 2014, 12:50:43 »
I forgot about drivers
I dunno
It's a keyboard by keyboard basis
I'm sure data exists on this somewhere
Offline Smasher816
  • HHKB Master
« Reply #7 on: Tue, 26 August 2014, 13:00:08 »
Also keep in mind that some keyboards draw more than others. Ex: plugging a HHKB into your phone via a usb otg cable might not work. I'v heard some people get around it with a (powered) usb hub, but that seems kind of against the whole portability point.
Offline esoomenona
  • Gnillort?
« Reply #8 on: Tue, 26 August 2014, 13:03:35 »
Any tablet that does USB OTG should run a keyboard just fine.
I connected a backlit keyboard with a mousepad to my phone, turned the backlighting up all the way, and it worked just fine.
edit: picture: http://i.imgur.com/kYRjlTm.jpg
« Last Edit: Tue, 26 August 2014, 13:07:44 by esoomenona »
« Reply #9 on: Tue, 26 August 2014, 13:25:03 »
I dunno
Most keyboards use the standard USB HID drivers which you can get for android (though most devices with a USB OTG port should just have them) as well as windows RT devices. If you have a fancy keyboard with macro keys that needs a driver to assign them, that functionality might work, also USB NKRO might not work.
Other than that, the KBs should be the same.
Not all USB OTG ports can deliver full power. When the galaxy S3 was released they did tests and were impressed it could power a USB hub & multiple devices as well as spin up a portable HDD
Offline urbancamo
« Reply #10 on: Tue, 26 August 2014, 13:25:12 »
Anyone tried a Filco Bluetooth or Matias Bluetooth keyboard with tablets? Are there any linux options for tablets? I'd consider that as a goer!
« Reply #11 on: Tue, 26 August 2014, 14:50:36 »
matt3o has a minila, maybe he could comment
Offline paobit
« Reply #12 on: Tue, 26 August 2014, 19:26:37 »
hmm maybe a laptop would be less complicated
« Reply #13 on: Tue, 26 August 2014, 19:38:57 »
dockable tablets like asus t100 and suchlike are generally pretty compatible. something to think about if you don't need the performance a laptop offers.
otherwise I'd just go with a business-class laptop and use it for the next 6 years or so.
Offline paobit
« Reply #14 on: Tue, 26 August 2014, 19:51:15 »
Will probably look into it more  :thumb:
Offline GL1TCH3D
« Reply #15 on: Tue, 26 August 2014, 22:45:18 »
I have the asus TF201 with the dock and I plug my Poker 2 in it
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #16 on: Tue, 26 August 2014, 22:56:32 »
You should buy a kbt pro from a reputable user here on gh.  It has bluetooth and will sync with 3 devices (not at once).  Also, it's pretty solid.
Offline WakeMeIPlan
  • Micro Baby, Micro.
    • United Kingdom Box plots
« Reply #17 on: Wed, 27 August 2014, 12:35:09 »
I have a Nexus 7 and I just connect my pure into it with an OTG cable.
Offline Oobly
« Reply #18 on: Wed, 27 August 2014, 13:27:27 »
Any tablet with a full size USB port or OTG accessory will work. 99% of mechanical keyboards don't require specific drivers. They just work as a standard USB HID. If a board does use drivers it's usually to support extra features and the basic functions should still work without.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline paobit
« Reply #19 on: Fri, 29 August 2014, 10:45:04 »
I got a surface pro 3 and my poker 2 works like a charm! BTW this is an awesome tablet that runs like a full blown laptop/desktop. It runs windows 8.1 pro...not RT. Would definitely recommend this to anyone who is even slightly interested
Offline Jixr
« Reply #20 on: Tue, 02 September 2014, 12:02:59 »
with an ipad, you'll need the lightning to usb ( camera connection kit )
And note it IS power limited, so basically backlit and programmable keyboards won't work.
Though you can plug the keyboard into a power hub ( unpowered ) and then plug that into the ipad and it will work just fine.
( the ipad limits power output based on the number of ports that it has access to as a power saving feature )
