Author Topic: QFR's out of stock everywhere?  (Read 7632 times)
Offline PrisonSex
« on: Fri, 29 August 2014, 14:32:11 »
I can't find one anywhere that isn't on back order. Anyone know where I can find one?
Re: QFR's out of stock everywhere?
« Reply #1 on: Fri, 29 August 2014, 14:47:39 »
I think they have been discontinued. They show up here in the classifieds sometimes.
Offline exitfire401
  • The Force is Re/\l
« Reply #2 on: Fri, 29 August 2014, 15:00:53 »
This. I got lucky and found one with reds on amazon.
Offline PrisonSex
« Reply #3 on: Fri, 29 August 2014, 15:19:43 »
Damn. Now what? Im looking for a tenkeyless with mx browns/clears but if qfrs are gone, what do?
Offline exitfire401
« Reply #4 on: Fri, 29 August 2014, 15:26:08 »
WASD v2/code? A little bit more expensive, but still a very decent board.
Offline PrisonSex
« Reply #5 on: Fri, 29 August 2014, 15:31:26 »
Im looking in the under $100 range
Offline osi
« Reply #6 on: Fri, 29 August 2014, 15:36:45 »
Rosewill cherry MX boards from newegg will be in your price range
Offline dgneo
  • Supervillain
« Last Edit: Fri, 29 August 2014, 15:40:52 by dgneo »
Offline Carter
  • CM Storm Rep
  • * Commercial Vendor
« Reply #8 on: Fri, 29 August 2014, 15:49:17 »
They havent been discontinued but certainly reduced in QTY/Availability due to the switch shortage. The switches were pushed towards newer items.
« Reply #9 on: Fri, 29 August 2014, 15:58:02 »
^^ Good to know, I thought CM was just moving on to newer boards!!
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #10 on: Fri, 29 August 2014, 16:50:41 »
Kailh Revolution
Offline Carter
  • CM Storm Rep
« Reply #11 on: Fri, 29 August 2014, 16:54:54 »
Kailh Revolution
Kailh is a life saver. They have taken a lot of the pressure off cherry. Outside of brown, we are pretty flush on Cherry switches now
« Reply #12 on: Fri, 29 August 2014, 17:03:08 »
KUL ES-87 gets a mention
It's the best out-of-the-box keyboard there is.
Offline Grim Fandango
« Reply #13 on: Fri, 29 August 2014, 17:08:21 »
It is a little surprising they have been discontinued given their popularity. I thought this was the one CM would be selling for a while.
« Reply #14 on: Fri, 29 August 2014, 17:13:44 »
Go up a few posts, Carter confirmed they are just short on MX switches, not discontinued.
Offline PrisonSex
« Reply #15 on: Fri, 29 August 2014, 18:13:51 »
Managed to snag one off ebay for $75, its mx blues but I can live with that rather than having to settle for a linear switch.
« Reply #16 on: Fri, 29 August 2014, 18:14:08 »
Ah, thanks for pointing that out. Makes a lot more sense.
Offline Novus
  • Mondai nothing~
« Reply #17 on: Fri, 29 August 2014, 18:15:58 »
LOL
I wasn't expecting that from you Grim
Offline PrisonSex
« Reply #18 on: Fri, 29 August 2014, 18:19:56 »
How easy/hard would it be for someone with basic soldering skills to replace the alphanumeric switches on a qfr with mx clears?
« Reply #19 on: Fri, 29 August 2014, 18:57:53 »
Honestly it would have just been cheaper to buy the KUL with clears to start with.
Offline PrisonSex
« Reply #20 on: Fri, 29 August 2014, 19:00:23 »
This is more long term curiosity than me seriously about to invest in switches
« Reply #21 on: Sat, 30 August 2014, 04:19:30 »
LOL
Usually I try to read before I speak. But every once in a while I just blurt something out.
Offline johndavis33
« Reply #22 on: Sun, 31 August 2014, 14:43:05 »
It's got ABS keycaps out of the box. Other than the ready availability of clears, I don't really know why people are going crazy for them.
What's so good about them? For me, my favorite out of the box keyboard would be a ducky with either there dye subs or engraved PBT keys.
HAVE AND WILL KEEP: HHKB - Printed white | Ducky Banana edition - Whites | Model M13 | Unidentified Goodwill keyboard - Simplified black ALPS
TOO BE SOLD: TG3 BL82 - Clears | Wheelwrite 5 - Buckling Springs typewriter
SOLD: Rosewill RK9000 - Blacks | QFR - Blues | Ducky G2 Pro - Greens |
IT WILL BE MINE: Northgate Omnikey - White ALPS
Offline Novus
  • Mondai nothing~
« Reply #23 on: Sun, 31 August 2014, 15:10:14 »
Leopold 750R.
Own a piece of that royality today.
Offline Arcoril
« Reply #24 on: Mon, 01 September 2014, 03:31:27 »
I absolutely love the QFRs and I hope that CM keeps making them indefinitely. It's a no-frills solidly built board with a great price point. I've converted a ton of people to the world of mechanical boards by pointing them at the QFR and the Rosewill RK-9000s. As an added bonus, you can swap in a Frosty Flake replacement controller and get a completely reprogrammable board.
Offline Arcoril
« Reply #25 on: Mon, 01 September 2014, 03:47:26 »
It's all relative, but I find switch swaps to be trivially easy. Get a good chisel tip to maximize the contact area and turn your iron up to 650 degrees or so. Once the solder is molten, use a solder sucker (a wick works too, but isn't as convenient imo) and repeat. Once the solder's been removed, I pinch in the two tabs on the top of the switch and apply pressure to the plastic peg below. If you got all the solder, the switch pops right out. If you notice that there's a bit of solder left in the through hole and it's preventing removal, don't just fumble around with the iron to try and melt the remaining solder since you'll run the risk of lifting the pad if you apply too much heat. Instead, just apply flux to the area (optional, but I've found that it makes things easier for me), re-solder the switch, and then try sucking/wicking out the solder again. It goes really quickly once you've gotten into a rhythm.
Installing the new switches is super fast. Just snap the new ones in and then solder the two pins on the bottom.
Offline speedygonz
« Reply #26 on: Mon, 01 September 2014, 05:38:14 »
Offline barkinos98
  • Illinois
« Reply #27 on: Tue, 02 September 2014, 23:19:04 »
Check frozencpu.  :thumb:
I ordered a blue version because i had too much btc on my hands and no one wanted to sell it for btc, so i went a bit creative and ordered a keyboard from a modding company. :D
Its a great board though, no regrets.
Happy Hacking Professional 2  | Logitech G710+ | Quickfire Rapid MX Clears
Offline PadawanGeek
« Reply #28 on: Wed, 03 September 2014, 01:14:52 »
Is CM going to restock the QFR or is it EOL, being replaced by the QFR-I?
« Reply #29 on: Wed, 03 September 2014, 07:05:15 »
The QFRs in ISO layouts disappeared from stores in Europe this spring right when Rapid-I was introduced but then they came back in the summer and there is now plenty in stock everywhere over here.
I think it is just the same thing happening in the US.
As the CM rep said above, there is a switch shortage and the switches they get go to new models first.
« Last Edit: Wed, 03 September 2014, 07:08:23 by Findecanor »
