Author Topic: IBM Model F-122 lot of 3 in Canada  (Read 3896 times)
- D Trump 2026-10-24
Offline E TwentyNine
    • Some of My Keyboards
Re: IBM Model F-122 lot of 3 in Canada
« Reply #1 on: Thu, 04 September 2014, 08:54:26 »
Someone just bought a fleet at a great price.
Offline JPG
  • Model F is my new passion!
« Reply #2 on: Thu, 04 September 2014, 09:03:28 »
They don't look to be in a great shape, but with some good elbow grease it's a nice opportunity to get a good deal!
Who got them? Is it you E TwentyNine?
« Reply #3 on: Thu, 04 September 2014, 09:22:56 »
Nope.
Offline 1391406
« Reply #4 on: Thu, 04 September 2014, 11:38:49 »
If only the space bars weren't missing on two of them.
« Reply #5 on: Thu, 04 September 2014, 11:41:33 »
Yeah, that sucks. Good thing you can mod them to accept a Model M spacebar.
FYI, it wasn't me, either.
« Reply #6 on: Thu, 04 September 2014, 11:55:37 »
if it was one of you guys i want one of these
« Reply #7 on: Thu, 04 September 2014, 12:25:46 »
I'm a really big fan of the blue sublegends on the keycaps. Nice and faded too. Pity it's missing the one.
Offline 1391406
« Reply #8 on: Thu, 04 September 2014, 13:16:58 »
Not easily, unfortunately.
« Reply #9 on: Thu, 04 September 2014, 13:22:16 »
It really isn't very hard, and then you have a lot of flexibility.
Offline 1391406
« Reply #10 on: Thu, 04 September 2014, 13:32:45 »
Are you referring to Kishy's method or modifying the brackets to accommodate the stabilizer from an M?
« Reply #11 on: Thu, 04 September 2014, 15:57:05 »
I don't know what Kishy's method is. I have made brackets to accommodate the larger Model M wires by bending sheet metal strips and gluing them down in place of the plastic tabs.
Wcass has a wonderful and elegant technique for sleeving the thin wires with thicker end pieces.
« Reply #12 on: Thu, 04 September 2014, 16:38:06 »
I have a few spacebar wires from wcass and it's excellent.
Offline 1391406
« Reply #13 on: Thu, 04 September 2014, 19:41:35 »
I must have been thinking of Wcass, not Kishy. Wcass's method is elegant, though somewhat involved.
As for the brackets, I'm not crazy about the thought of breaking them if they're perfectly intact, though I wonder if it might be possible to sand down the underside in order to provide the proper headroom.
« Reply #14 on: Thu, 04 September 2014, 19:53:10 »
You can try it. The Model M wire is MUCH thicker.
This stopped being an issue for me, because on the last few that I have modded I got rid of the stock tabs altogether and used barrel inserts for everything but the spacebar, and made tabs for Model M gear on those.
« Reply #15 on: Thu, 04 September 2014, 20:09:48 »
If you get the correct wire size for the F and bend it to the correct dimensions, you can melt the tabs on the M spacebar with a lighter to make the holes smaller, no further mods necessary.
Though wcass's tube sleeve trick is a nice neat approach.
