Author Topic: Ducky Thick PBT White Keycaps(blank) are ugly  (Read 7976 times)
Offline maculol
« on: Fri, 05 September 2014, 09:47:09 »
Hello
Just recieved Ducky Thick PBT White Keycaps(blank) from http://overclockers.co.uk/
On the top of them (i.e. where you put your fingers), there are clear marks of the cross where you fit them to your switch. (EDIT: Like either a 0.1mm'ish plateau / valley, barely able to feel it, yet it makes an ugly shadow.)
Is that normal? Looks very bad compared to my stock filco, is that the standard of pbt?
Thanks in advance
« Last Edit: Fri, 05 September 2014, 10:09:19 by maculol »
Offline spookymikal
Re: Ducky Thick PBT White Keycaps(blank) are ugly
« Reply #1 on: Fri, 05 September 2014, 10:24:00 »
I don't suppose you have a camera of high enough quality to show some pictures of what you're talking about do you?
I'm considering getting ducky blanks in black and really hope they don't have this problem.
Offline Rewind
  • Street Fighter
  • Drive slow, homie
« Reply #2 on: Fri, 05 September 2014, 10:34:37 »
I have a few sets of ducky pbt blanks and never ran into this problem. Are you sure they are actual ducky caps?
Offline cherpalla
« Reply #3 on: Fri, 05 September 2014, 13:53:01 »
Sounds like fakes. Mine don't have that issue (I have 4 sets).
c h e r
Offline pbtforever
« Reply #4 on: Fri, 05 September 2014, 14:27:53 »
Yes
Offline Hyde
  • White Tofu Extraordinaire
« Reply #5 on: Fri, 05 September 2014, 20:37:12 »
Typically more common on longer keys such as Shift or Spacebar.  Poker II's thick PBT has them and some of the imsto PBT has them too.
I suspect it's from the shrinkage from what PBT cools down.  It's not unheard of just not sure how common it actually is.
Offline devalli
    • DevAlliant
« Reply #6 on: Sat, 06 September 2014, 09:59:32 »
I have the same issue with my Ducky THICK PBT (green w/ whites) laser engraved I got from massdrop on my Filco.
Notice the uneven surface of the white keycaps (sorry for the low quality pic).
Keycap 8 seems to be dented, and keycap J seems to have slight bump. The green keycaps that came with this set doesn't have this issue though.
« Last Edit: Sat, 06 September 2014, 10:35:19 by devalli »
Filco MJ2 Metallic Blue | Poker II | KUL w/ GMK Dolch
Offline ryhanson
« Reply #7 on: Sat, 06 September 2014, 10:12:38 »
I have the Gray/Blue etched Ducky PBT's and this is only noticeable on the spacebar. I also noticed it on the stock PBT spacebar of my Poker II as well. I've never seen this happen on ABS caps though.
Offline aicrono
    • A Touching Experience
« Reply #8 on: Sat, 06 September 2014, 10:16:28 »
It also happens on ABS keys. These are some (terrible) pictures of a stock Rosewill set. They are fairly used and it wasn't just the key I took pictures of that had the issue.
Offline maculol
« Reply #9 on: Sat, 06 September 2014, 13:07:16 »
EDIT: The defects are probably visible on 90% of the keycaps, yet the spacebar is quite nice actually.
Some pictures, not the best lightning nor post-processing(wide gamut screen keeps deleting its colour profile)
Old stock ABS filcos
New thick white ducky
Now for the defects:
« Last Edit: Sat, 06 September 2014, 13:09:00 by maculol »
Offline Lastpilot
  • Power stance
« Reply #10 on: Sat, 06 September 2014, 13:08:51 »
Oh man, thanks for pointing these out, I was about to go hunting for think white PBT blanks.
Offline ynrozturk
« Reply #11 on: Sat, 06 September 2014, 16:20:56 »
Well you don't see that often. Thanks for the heads up.
IBM Model F | IMB Model M | Poker II MX Brown | Poker II MX Clear | Filco TKL MX Brown | Bastardized Razer Blackwidow TE MX Blue | Logitech G602 |  Cyborg R.A.T. 7 | | Logitech MX518 | Icemat  | Artisan Hien
Offline oscillik
    • music podcasts
« Reply #12 on: Sat, 06 September 2014, 16:22:41 »
I bought my first set of PBT keycaps for Cherry MX - Leopold thick 1.5mm PBT, and they're great
also, my previous experience with PBT keycaps is with the legendary HHKB. I have two
either I've been very lucky with PBT keycaps coming out perfectly, or those Ducky keycaps are godawful.
Keymacs A620N-Rev.A with Alps SKCM Salmon switches
Offline strict
  • TKL Zealot
« Reply #13 on: Sat, 06 September 2014, 16:54:31 »
Wow, that's disappointing. Even my el-cheapo blank white PBTs from BangGood don't look anything like that. Thank you for sharing, I know to avoid Ducky PBT now!
Offline tbc
« Reply #14 on: Sat, 06 September 2014, 17:37:12 »
care to show some non photoshopped pics?
Offline oscillik
    • music podcasts
« Reply #15 on: Sat, 06 September 2014, 17:46:50 »
whose are supposedly the shooped pics?
Offline ryhanson
« Reply #16 on: Sat, 06 September 2014, 17:47:15 »
Wow those really are bad. Even the little bit that I have noticed on the spacebars aren't nearly that bad at all. I'm sorry man.
Offline ynrozturk
« Reply #17 on: Sat, 06 September 2014, 18:39:53 »
Good to hear about the Leopold caps - mine should be arriving soon.
Offline tbc
« Reply #18 on: Sat, 06 September 2014, 18:55:31 »
maculol
he said he PPed them.
