Author Topic: Phantom case with 101 keys?  (Read 8703 times)
Offline nathairtras
« on: Fri, 05 September 2014, 15:44:53 »
Buying one of the 7bit SS plates from http://geekhack.org/index.php?topic=60816.0, but I want to try a non-TKL layout on it.  (ALL the keys.)  Closest compatible I have found is the CM Storm TK, however it lacks the cut-out for the three FN row switches on the right side.  Anything else I have come across has a TKL layout, with the five spots above the arrow keys (where a controller would go on many TKL keyboards) blocked.
Do any cases like this exist?
CM QFR Green
Re: Phantom case with 101 keys?
« Reply #1 on: Fri, 05 September 2014, 15:46:57 »
You could always cut the appropriate places in a QFR top. I have done one like that, but I still need to paint it.
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #2 on: Fri, 05 September 2014, 16:04:39 »
Plum 96 maybe?
Offline nathairtras
« Reply #3 on: Fri, 05 September 2014, 16:13:26 »
Yeah, I'm leaning that direction, just not sure how clean I can get the lines.  Still, I have a QFR I kind of want to put into a different case, so maybe that would make sense.  Use the QFR case with cuts for the Phantom.
Plum 96 maybe?
This looked promising, but the non-typical shape of the PCB makes me leery.
CM QFR Green
