Author Topic: Help: Find 02D keymapper software  (Read 3176 times)
Offline Jixr
« on: Sat, 06 September 2014, 17:34:07 »
Edit: I'm looking for someone who has an earlier version of 02d_keymapper software
The current version 1.5.3333 has a bug, and I heard the older versions worked, but I can't find a download link online.
If anyone can help me find the link or can email me the app, let me know!
« Last Edit: Sat, 06 September 2014, 22:17:07 by Jixr »
Re: Help: Find 02D keymapper software
« Reply #1 on: Sun, 07 September 2014, 00:47:44 »
I have 1 or 2 of the old versions. let me up them somewhere.
You can also find them on kbdlab.kr
edit: I notice that 1.5.333 is the current version on duck0113's site. Easy way out not happeninbg. I'll actually up mine somewhere now :P
edit: I have the following (note some are for the RGB mod)
1.3.240 (this one was on duck0113's site I think)
1.3.244
1.4.288
1.4.306RGB
edit: attached one of them to this post. Let me know if you need another version.
« Last Edit: Sun, 07 September 2014, 00:52:17 by dorkvader »
Offline Jixr
« Reply #2 on: Sun, 07 September 2014, 10:09:08 »
The version you uploaded dosnet work either, I can't seem to program anything to be arrow keys.
I have a duck mini v1.5 that i'm trying to program, and half the keys I'm trying to program don't act like they are supposed to via the mapping software ( capslock always on and forever repeating, can't assign a key to be a Fn key, lots of other issues )
« Last Edit: Sun, 07 September 2014, 10:45:21 by Jixr »
« Reply #3 on: Sun, 07 September 2014, 12:33:23 »
I think you may be having trouble with the KB itself.
I will give that firmware another shot just to make sure, but I have a lightsaver.
edit: it says its for duck mini 1.7, not sure how old a version you'd need for duck mini 1.5
« Last Edit: Sun, 07 September 2014, 12:52:16 by dorkvader »
Offline Jixr
« Reply #4 on: Sun, 07 September 2014, 12:49:24 »
ah, well yeah. I just bought the pcb, and it was new, but it seems that a thingy ( don't know what its called, little black box that each switch has on the back of the board ) wasn't soldered properly, so I had to solder in a hard wire around it to make the Fn key ( short right shift layout ) work, so I got that.
And basically I got it all figured out except that when the Caps lock is on, the LED blinks, and when its off, it blinks. ( when using the duck mini v1.X custom layout )
when using the duck mini v1.7 layout, the led works as it should, but the caps lock key won't release, it constantly thinks its being held down.
« Reply #5 on: Sun, 07 September 2014, 12:53:39 »
if the diodes were soldered backwards, then you will have other problems.
Offline Jixr
« Reply #6 on: Sun, 07 September 2014, 13:39:35 »
hm.... I don't really know enough about electrical componets to tell if its backwards or not on the caps lock,
But basically, when I use the custom firmware, it works, when i use the preset firmware, it does not work.
so I don't think its a hardware issue, could just be a "featrue" with the blinking caps lock light.
« Reply #7 on: Sun, 07 September 2014, 13:46:57 »
There should be a "line" on the diode closer to one side. Line should be closer to the square pad on PCB.
or just take a picture. Does sound like it's a firmware thing though.
So the blinking light is most likely a feature. it lets you know what "layer" you're on. I forget how to turn it off but I find it useful. On the lightsaver the blinky light is the top right corner.
Offline Jixr
« Reply #8 on: Mon, 08 September 2014, 22:42:20 »
fixed the blinking light thing, had to make a "C/M" key in the function layer, then type in a command to turn off the blinky caps, lock, now it just works like a normal caps lock led, either on or off.
Perfect!
