Author Topic: Unicomp Released a HHKB Layout 105 Key Keyboard  (Read 2165 times)
Offline Hyde
  • White Tofu Extraordinaire
« on: Wed, 10 September 2014, 16:27:10 »
http://pckeyboard.com/page/product/40PSA
Sorta....... so now if you can hack off the edges then you can have buckling spring in HHKB layout.
:P
Offline paicrai
  • mindblank
Re: Unicomp Released a HHKB Layout 105 Key Keyboard
« Reply #1 on: Wed, 10 September 2014, 16:27:53 »
hhkb
THE FEMINIST ILLUMINATI
Offline Rewind
  • Street Fighter
  • Drive slow, homie
« Reply #2 on: Wed, 10 September 2014, 17:02:08 »
Would this work on Windows?
Offline 0100010
  • Not Sure
« Reply #3 on: Wed, 10 September 2014, 17:44:27 »
So it is their 'spacesaver' chassis with a Unix like layout.
Not bad.  Says it is USB hard coded for Sun / Unix.
Offline hcry4
  • HHKB Hoarder
« Reply #4 on: Wed, 10 September 2014, 17:45:38 »
Sun Type 3 Unix layout. That's a very interesting keyboard.
« Reply #5 on: Wed, 10 September 2014, 20:56:10 »
:P
You could do this before. The only difference is the extra barrel is populated with a spring instead of a peg insert for stabilization and the controller is programmed differently.
Offline Oobly
« Reply #6 on: Thu, 11 September 2014, 01:17:07 »
Well, these keycaps are interesting.
You could already convert any model M and some Model F boards to HHKB layout (since the barrels and membrane / PCB have support these key positions), just with bottom row mods spaced out more. With these keycaps you can even have the correct legends on them, though. That's quite nice.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
