Author Topic: QFR Internals  (Read 2527 times)
Offline synerr
QFR Internals
« on: Thu, 11 September 2014, 11:24:31 »
Spent the past half an hour searching but turned up nothing useful.
Does anyone have any high res close up images of QFR (most interested in tkl and full sized) internals?  Especially the circuit board and areas around the controller.
ta
Press any key to continue, any other key to quit.
Offline infiniti
  • I <3 KB
  • Bob was here
Re: QFR Internals
« Reply #1 on: Fri, 12 September 2014, 07:44:06 »
You're in luck!  :cool:
I took these when I modded my bro-in-law's QFR.
If you right-click and open in new tab/window you can see the full resolution (about 4,000 px wide).
76904-0
76906-1
76908-2
Offline synerr
Re: QFR Internals
« Reply #2 on: Fri, 12 September 2014, 08:37:22 »
Dude, I love you!!!!!  Am I correct in concluding that the controller is on a breakout board?
Offline infiniti
  • I <3 KB
  • Bob was here
Re: QFR Internals
« Reply #3 on: Fri, 12 September 2014, 09:26:39 »
Yup, the controller is on a breakout board that plugs into the black sockets.
Re: QFR Internals
« Reply #4 on: Fri, 12 September 2014, 09:27:39 »
And bpiphany's Frosty Flake is a drop-in replacement for it! :cool:
Offline synerr
Re: QFR Internals
« Reply #5 on: Fri, 12 September 2014, 11:04:46 »
Thanks ... all the info I needed!!  Seems like I can use a Filco too .... pricier option though :(
Offline Grendel
Re: QFR Internals
« Reply #6 on: Fri, 12 September 2014, 12:52:02 »
QFR/S:
Rosewill RK-9000, very similar to a QF XT:
You can get replacement controllers for all these boards from bpiphany :) See this for an example.
- I'm game !
Offline Arcoril
Re: QFR Internals
« Reply #7 on: Sat, 13 September 2014, 02:02:19 »
+1 on the bpiphany replacement controllers. I use them on each of my Costar boards and I love 'em. All the programmability of the Phantom at Newegg prices!
