Author Topic: Desktop Boom Mic Suggestions  (Read 2356 times)
Offline funxion
« on: Sat, 13 September 2014, 23:43:20 »
Hey guys,
Haven't posted here in a while, but I figured someone here would have a good answer. I'm in the market for a desktop boom mic, but I really don't want to spend any more than I have to. The quality doesn't need to be studio quality, but I also don't want a bad mic.
It would be a huge help and if it's on Amazon, I'd be even happier!
Crush80
Filco MJ2 TKL
Offline katushkin
  • Too Keycool for School
  • Just the guy
Re: Desktop Boom Mic Suggestions
« Reply #1 on: Sat, 13 September 2014, 23:52:48 »
I really like my Blue Yeti. Comes with a desk mount and can be boom mounted as well *I think*
« Reply #3 on: Mon, 15 September 2014, 16:26:26 »
I'm a big fan of audio-technica, so I'd go with them.
If you need a boom, you can make a cheap one out of a lamp. Check ikeahacks for more info.
Offline HebrewHammer
« Reply #4 on: Wed, 17 September 2014, 18:13:23 »
http://www.amazon.com/Audio-Technica-AT2020USB-Cardioid-Condenser-Microphone/dp/B001AS6OYC/ref=sr_1_1?s=electronics&ie=UTF8&qid=1410676510&sr=1-1&keywords=audio+technica+mic
seems to get rave reviews
I've used the AT2020 for a little while now and it's great, very good at getting rid of the clickity clack from my keyboard. AT2020's can be found on ebay a lot cheaper usually (although used).
AT2020+ is also available if you need to do monitoring through the mic, but it costs quite a bit more. They can also be found on sale from time to time.
If you don't NEED a boom mic I would check out the samson go mic or the modmic. The Samson C01u is also recommended a lot.
Friends Don't Let Friends Get Friends Haircuts...
Offline cherpalla
« Reply #5 on: Wed, 17 September 2014, 19:13:53 »
I like my Blue Snowball, but I only use it for like podcast stuff and Twitch, so it probably depends on what you are using for. I would get an XLR to USB converter and a regular microphone for anything else.
c h e r
