Author Topic: [IC] TX87 - New Korean TKL Custom Keyboard  (Read 210420 times)
Offline yuiop
« on: Tue, 16 September 2014, 12:15:53 »
There's a new custom keyboard being developed in Korea @ kbdlab (what new?)
It's at the prototyping stage.  I'll try to post the actual photos as they become available.
I spoke with one of the developers and it sounds like they are willing to make it available to GHers as long as there's enough interest ;)
It will be affordable, relatively speaking :-X
I don't have the exact pricing but I was told to expect around 200USD including the PCB.  But that's before shipping and other fees etc.
Some bullet points....
- KMAC2/Orion like structure.  Top/Plate/Bottom, bottom is angled
- Top : anodized aluminum with many color options available
- Plate : stainless steel (heavier) or anodized aluminum
- Bottom : CNC'd Polycarbonate.  It's designed to allow the LED light through
- There's a 2mm stainless steel plate mounted on the bottom to add weight
- PCB : programmable of course. supports Winkey/Winkeyless/ISO/etc.
- Supports in-switch LEDs & RGB LED underneath the PCB (like this)
So if you're interested, show your interest in this thread :thumb:
Does the plate allow switch top removal?
Yes, you can remove switch tops without desoldering.
yuiop, is this a87 or b87 compatible?
or in other words, is the usb header on the right (between F12 and PrtScn) or on the left (between Esc and F1)?
This is A87 compatible housing.
I'm new to the custom korean keyboard scene. Would full assembly (e.g. switch/led soldering) services be offered as part of this possible GB?
Assembly will be offered.
Any chance the maker can do Alps?
MX only :(
I don't know the exact angle but I think these will be flatter than the Orion/Lightsaver which is 11 degree slanted.  I'll ask.
This keyboard is 7.5 degrees tilted.
In comparison, KMAC2 is 7 degrees.  Orion/Lightsaver/Eagle/Viper are 11 degrees.
If you prefer to use it at a higher angle, you can just use taller bumpons in the back.
I don't think assembly service will be offered as part of GB.
how about the resistors? are they presodered like Duck's pcb?
Resistors and Diodes are all pre-soldered.
There will be spots for 22 surface mounted RGB LEDs.  They will likely come pre-soldered as well.
Prototypes
« Last Edit: Sun, 07 December 2014, 13:11:21 by yuiop »
Re: [IC] TX87 - New Korean TKL Custom Keyboard
« Reply #1 on: Tue, 16 September 2014, 12:17:13 »
If the price really is $200 I'm sure you'll have tonnes of interest in this.
Offline yuiop
« Reply #2 on: Tue, 16 September 2014, 12:20:03 »
That's what I told him as well.
Offline Zeal
    • Zeal Generation Inc.
« Reply #3 on: Tue, 16 September 2014, 12:20:22 »
Interesting, I wonder how a SS bottom plate would look like with a PC bottom layer with the bottom mounted LEDs.
Offline yicaoyimu
« Reply #4 on: Tue, 16 September 2014, 12:27:56 »
I'm interested.
« Reply #5 on: Tue, 16 September 2014, 12:29:10 »
Would buy.
Offline MythicalWagyu
  • Poor Impulse Control
« Reply #6 on: Tue, 16 September 2014, 12:32:38 »
$200 for a Korean custom? Sign me up!
KEYBOARDS >>
MICE >>
COMPUTER >>
Offline cphead
« Reply #7 on: Tue, 16 September 2014, 12:33:50 »
This looks awesome. And that ridiculous price point?! (::::
« Last Edit: Tue, 16 September 2014, 12:35:35 by cphead »
Offline Lastpilot
  • Power stance
« Reply #8 on: Tue, 16 September 2014, 12:34:09 »
Very interested, especially if it's less than $300 with shipping. Although I would definitely want to see a prototype before deciding. I am trying to imagine how the polycarbonate housing would show things like screws, screw holes and how even LED diffusion can be.
Offline Battou62
« Reply #9 on: Tue, 16 September 2014, 12:43:52 »
I really wish we could move away from the angled bottoms. They just make the keyboard unnecessarily heavy(cost more to ship, but feels great), and having adjustable feet seems like a muck better option.
Offline rainb1ood
  • so pretty so plastic
« Reply #10 on: Tue, 16 September 2014, 12:49:41 »
Looking forward to acquire my first korean custom keyboard
Offline Fnzzy
« Reply #11 on: Tue, 16 September 2014, 12:53:35 »
Man, I was waiting for another TKL with a natural angle since I dislike feet but I really don't like the look of this one. Too many edges and angles. But I'm sure for $200 a lot of people will have fun with this!
Offline LechnerDE
« Reply #12 on: Tue, 16 September 2014, 12:53:56 »
Would definitely buy this if it is in the ~200$ price range plus shipping.
Offline yuiop
« Reply #13 on: Tue, 16 September 2014, 13:00:12 »
I personally think there's more pros than cons with angled housing.  Also those feet are rarely 'adjustable' unless you get another set with different height.
Offline yuiop
« Reply #14 on: Tue, 16 September 2014, 13:01:25 »
I'm not sure.  I'll ask.
Edited: Yes, you can remove switch tops without desoldering.
« Last Edit: Tue, 16 September 2014, 13:06:51 by yuiop »
« Reply #15 on: Tue, 16 September 2014, 13:06:59 »
Going by the pics.. It does allow switch top removal.
Offline cphead
« Reply #16 on: Tue, 16 September 2014, 13:22:37 »
ABOUT TIME this became a thing -_-
Offline Data
« Reply #17 on: Tue, 16 September 2014, 13:38:12 »
Nice.  Interested.
Offline Battou62
« Reply #18 on: Tue, 16 September 2014, 13:49:02 »
My Kmac has feet that have removable "washer" layers for adjustability. I am glad you think there are more pros with angled bottoms, please list them here for us. I would much rather have to buy separate feet, or be able to remove them all together instead of being forced into having an angled board.
« Reply #19 on: Tue, 16 September 2014, 13:55:37 »
Biggest pro in my mind is : Angled boards look a thousand times nicer.
Offline strict
  • TKL Zealot
« Reply #20 on: Tue, 16 September 2014, 14:08:40 »
+1
That permanent angle is enough to keep me from buying into this regardless of price. I actually got into the mechanical keyboard hobby because I was given a Dell rubber dome keyboard at work that had a permanent angle and I hated it so much I started researching for a quality replacement.
Offline yuiop
« Reply #21 on: Tue, 16 September 2014, 14:13:26 »
First of all, I'm not trying to convince anyone to like angled keyboard.  If you don't like it, that's fine.  Then this keyboard is not for you.
I personally don't care about having adjustable feet.  I'd much rather have the extras weight and stability of angled keyboards.  If I need to raise it up a little, I'd use taller bumpons in the back.  Problem solved.  I have KMAC2 and KMAC 1.2.  Both have same the PCB, same mx clear stems, same spring weight etc.   Only difference is KMAC2 is angled and weighs about twice as much.   To ME, KMAC2 feels and types much better.
Offline ComradeSniper
  • HHKB Pro
« Reply #22 on: Tue, 16 September 2014, 14:26:11 »
At that price I'm definitely interested, but I'd want to see some pics of the real thing first.
Offline cphead
« Reply #23 on: Tue, 16 September 2014, 14:55:34 »
IMO KMAC2 angle is perfect, not too much and not too little. Do we know what kind of angle this board will have?
Offline yuiop
« Reply #24 on: Tue, 16 September 2014, 15:18:13 »
Offline Patchwrks
« Reply #25 on: Tue, 16 September 2014, 15:38:30 »
Absolutely interested
(´・ω・`)denko-chan~~~내 스레드
Offline bazemk1979
« Reply #26 on: Tue, 16 September 2014, 15:47:57 »
interested, price is good and is expected since bottom is going to be plastic or whatever u call it. If it looks good im in, but not 100% sure since I like all aluminum boards.
Offline Sent
  • Simplistic Serenity
  • ¯\_(ツ)_/¯
« Reply #27 on: Tue, 16 September 2014, 16:00:44 »
Not normally a fan of TKL but for that price, I'm probably in.
« Reply #28 on: Tue, 16 September 2014, 16:40:43 »
200 with PCB is pretty good, I might try and get in on this one
Offline feizor
« Reply #29 on: Tue, 16 September 2014, 17:15:13 »
Offline kitsun8
  • In need of some cash
« Reply #30 on: Tue, 16 September 2014, 18:12:12 »
+1 for me
Offline Vintage
« Reply #31 on: Tue, 16 September 2014, 18:21:19 »
 :eek:
As someone who recently bought a Duck Eagle..... This makes me a bit sad
CM QFR w/ MX Reds  | Logitech G900
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #32 on: Tue, 16 September 2014, 18:46:58 »
A new Korean TKL, put me down for one.  I can't ignore a new keyboard being designed and made in South Korea  :thumb: .
Just let us know when this Group Buy will start and you'll get half of Geekhack rolling in for this.
Offline Den441
« Reply #33 on: Tue, 16 September 2014, 19:19:48 »
I have been wanting a b.87 winkeyless.kr board with the rgb underlighting like OP mentioned for awhile now. However, I have no idea how I would get one as I don't know any Korean proxies that deal with this sort of thing.
If the RGBs look as good on this board, I am definitely in. How do the leds shine through? Is there going to be a clear acrylic center layer?
Anyway, It is great that this is being made available to us here. Can't wait to see more pics!
Custom Wrist Rests, Artisan Keycaps, and more - http://battlestation.io
Sales Thread - https://geekhack.org/index.php?topic=74835.0
Offline Synjin
« Reply #34 on: Tue, 16 September 2014, 20:31:18 »
I would totally purchase this board 100% for that price point. Besides, I have no tkl boards anyways so I don't mind owning my first Korean TKL
Offline captvizcenzo
« Reply #35 on: Tue, 16 September 2014, 20:55:44 »
I'm totally in for $200 :D
Offline exitfire401
  • The Force is Re/\l
« Reply #36 on: Tue, 16 September 2014, 21:03:40 »
I believe the bottom layer is CNC'd acrylic. Just going by what he says in the OP. Guessing what we see in the renderings is a separate metal piece which is added for weight in the center of the acrylic bottom.
Offline Synjin
« Reply #37 on: Tue, 16 September 2014, 21:28:17 »
:eek:
Don't be sad, I ordered the Duck eagle and viper together and I'm still not unhappy about my purchase =)
Offline Cottonsox
« Reply #38 on: Tue, 16 September 2014, 21:31:11 »
My Wallet!! Interested in this.
Offline shawn24
« Reply #39 on: Tue, 16 September 2014, 23:49:06 »
I'm in
Offline inoxify
« Reply #40 on: Tue, 16 September 2014, 23:56:58 »
I would be interested in this.
Offline hoggy
  • * Ergonomics Moderator
« Reply #41 on: Wed, 17 September 2014, 00:40:44 »
I'm in!
Offline LechnerDE
« Reply #42 on: Wed, 17 September 2014, 00:49:58 »
Will there be other color options for the top cover?
Together with the white bottom part a light blue / cyan cover would look nice :)
Offline feizor
« Reply #43 on: Wed, 17 September 2014, 02:48:02 »
Cnc'ed polycarbonate. Like the middle layer of gon boards. This probably why the price is cheaper than full ALU boards. Makes for night lighting effects too.
Offline feizor
« Reply #44 on: Wed, 17 September 2014, 02:48:32 »
OP mentioned there's different color options for the top plate.
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #45 on: Wed, 17 September 2014, 02:50:15 »
sure, why not
Offline Den441
« Reply #46 on: Wed, 17 September 2014, 03:09:53 »
Awesome, sounds like it will difuse the leds nicely then. I'm definitely in.
Offline justnits
« Reply #47 on: Wed, 17 September 2014, 05:14:39 »
Ducky DK9008 Shine 2 Gateron Red w/ Korean 55g gold lubed spring & custom LED | Ergodox with Aluminium top plate | IBM Model M SSK | GHPad | GON's Nerd TKL | Filco Majestouch 2 TKL MX Blue
[Sold]Keycool 87 PBT White Cherry MX Blue | [Sold]ikbc F-104 Cherry MX Brown
Offline tuantruong
« Reply #48 on: Wed, 17 September 2014, 07:07:41 »
I'm in! Oh my, duck 75% and this, my wallet is gonna kill me.  :p
« Last Edit: Wed, 17 September 2014, 07:12:59 by tuantruong »
Offline gotofbi
« Reply #49 on: Wed, 17 September 2014, 07:59:50 »
