Author Topic: [IC] TX87 - New Korean TKL Custom Keyboard  (Read 210440 times)
Offline kin25
    • TXKeyboards
Re: [IC] TX87 - New Korean TKL Custom Keyboard
« Reply #300 on: Wed, 17 December 2014, 09:12:39 »
If you choose Alu Bottom, You should pay a little more.
and couldn't use RGB backlight.
Alu Bottom color will be only black.
Sorry for not many choices. :(
WOOOOOOOOOOOO ;D ;D :eek: :p :thumb: :cool:
My toilet overflowed!!!!
I will definitely not mind paying extra for an aluminum bottom as the total price is already so low!
Will the aluminum top and bottom connect seamlessly? As in connect with no bumps etc?
The polycarbonate layer connects to the aluminum top with a lip/bump/edge popping out and I don't really like that.
I basically need a KMAC :DDD
As you can see the pictures, top and bottom size are different.
someone like and dislike this shape.
i made this shape for RGB LED spreading.
I see, thank you very much kin for explaining about the different size. I'm guessing since aluminum bottoms won't give out light LED spreading (obviously), you're going to think and design up another bottom design? If so, take your time :) I look back at it and I don't really mind the different size, I'm just glad an aluminum bottom is becoming available for us!
Seems like the PCB is still a bit delayed, nothing you or us can do to change it but wait.
Thank you again kin!
thank you.
i like a heavy alu bottom. so i will make alu bottom.
i made 3 kind of bottoms(alu, clear PC and black PC) 2nd proto.
but... i can't be satisfied alu bottom. so i didn't take a picture.
if pcb will be ready. i will make some alu bottom proto.
my english is very poor.
Offline geogga
  • gosh dang GH and their GBs
« Reply #301 on: Wed, 17 December 2014, 09:25:52 »
thank you.
When you are satisfied kin, go ahead and show it! Don't rush it if it's not ready to your likings.
Don't worry about your English! It is good enough where we can relatively understand it.
Offline Data
« Reply #302 on: Wed, 17 December 2014, 09:53:58 »
Black PC bottom with a silver/brushed metallic top might look pretty cool.
Black PC bottom is more expensive 1.5times. So I have no plan to make Black PC bottom. Sorry  :(
This is the bottom I'm referring to:
Are you saying that won't be an option?  Just trying to confirm.
I think that Alu Bottom is better than Black PC Bottom at the same price.
How about Alu Bottom?
I did not realize the photo was just a prototype.  Thank you for clarifying.
Yes, Aluminum would be preferable if it's the same price as the PC would have been.  But don't go out of your way on my account.
Offline frostylove
« Reply #303 on: Fri, 19 December 2014, 10:25:27 »
Amazing design with very attractive price, definitely I'm in!
Suhr Custom Standard Carve Top
Manson DL-1 Matt Bellamy Signature
Marshall JVM410H + 1960A
Lovepedal Kanji Enternity
Offline MidnightXZ
« Reply #304 on: Fri, 19 December 2014, 12:50:57 »
Love it! Definitely in, will totally pick up this beauty when it's ready. :D
Home: Filco Majestouch 2 TKL (MX Brown) + Leopold FC210TP + Logi G502//MJ2 needs a Pegasus Hoof controller
OTG with laptop: Poker II (MX Brown) + Logi Anywhere MX//soon, waits for Massdrop
Rotation: Filco Majestouch 2 (MX Brown, Kitten Paw Controller) | CM Quickfire Rapid (MX Red, Frosty Flake v2 Controller)
Others: CM Storm Quickfire Rapid (MX Red)
Old boards: CM Storm Quickfire XT (MX Brown) [gave away] | CM Storm Trigger (MX Red) [sold]
Offline TBone
« Reply #305 on: Sat, 20 December 2014, 21:53:58 »
Still so excited for this! Quick question though, would this case be compatible with a phantom pcb and phantom compatible stainless steel plate? I have the two and would prefer to use them if it could keep the price down.
Offline kin25
    • TXKeyboards
« Reply #306 on: Sun, 21 December 2014, 01:51:53 »
sorry. this is not compatible with phantom.
it's compatible with A87 pcb... and TX87 plate.
Offline radio_killah
  • Chinchillin'
« Reply #307 on: Sun, 21 December 2014, 09:16:56 »
Is this compatible with GONs nerd PCB? His is a87.
Offline kin25
    • TXKeyboards
« Reply #308 on: Sun, 21 December 2014, 12:00:28 »
maybe compatible... if usb connector is solded on upside.
  • Chinchillin'
« Reply #309 on: Sun, 21 December 2014, 12:28:52 »
Which way does the connector need to be in order to fit in this case?
Offline kin25
    • TXKeyboards
« Reply #310 on: Sun, 21 December 2014, 12:50:03 »
You can't use nerd pcb, if usb connector is solded on the downside. like this picture
« Last Edit: Sun, 21 December 2014, 12:51:52 by kin25 »
  • Chinchillin'
« Reply #311 on: Sun, 21 December 2014, 13:09:39 »
Thanks checking so quickly!
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #312 on: Sun, 21 December 2014, 19:49:18 »
On the upside GON has the option to solder the connector soldered on the top side therefore it should be compatible making this case look that much sexier to me.....
GON NerD TKL DTA Edition
Offline kin25
    • TXKeyboards
« Reply #313 on: Sun, 21 December 2014, 20:17:25 »
thanks for the answer.
for using Nerd backlight led... you have to use pc plate.
Offline Dreamre
    • kbdlife
« Reply #314 on: Wed, 24 December 2014, 10:15:25 »
You guys can use the KMAC2 (GON NerD) PCB though no?
Offline kin25
    • TXKeyboards
« Reply #315 on: Fri, 26 December 2014, 03:06:22 »
Here are some pics...
85153-0
85155-1
Offline Rodgaroon
  • Size matters, just ask my wife.
« Reply #316 on: Mon, 05 January 2015, 10:40:44 »
Whats the good word? how is the PCB development coming along?
G6v2 (MX Black) | Poker II (MX Brown) | Compact SQ (MX Clears 62g)
Offline munch
« Reply #317 on: Wed, 07 January 2015, 01:03:36 »
very tempted. is cable exit only on the right side though? or what is the notch above the end of the F-row?
I don't really understand how all these things work but do I have to buy a controller for it? and controller is what decides NKRO over USB and such right?
impressive work, though, I must say.
Offline loud_asian
« Reply #318 on: Wed, 07 January 2015, 01:28:37 »
Looks like the mini usb port is where the notch is on the F-Row. I think controller will already be soldered onto the board, as most Korean customs have this feature.
Offline frostylove
« Reply #319 on: Wed, 07 January 2015, 11:44:56 »
When will this GB released? I can wait anymore :))
Offline Sygaldry
  • Edema Ruh
« Reply #320 on: Wed, 07 January 2015, 11:49:05 »
I think it happens once the PCB design is finalized and the Alu bottom prototype is done!
null
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #321 on: Thu, 08 January 2015, 20:34:42 »
wait, i'm confused. Is this for just a case? or a complete deal? (minus caps and switches of course)
Offline Sygaldry
  • Edema Ruh
« Reply #322 on: Thu, 08 January 2015, 20:46:45 »
I think you can choose what you want: Full kit (Case+Plate+PCB), Case+Plate, Case, or Plate.
Someone correct me if I'm wrong.
null
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #323 on: Thu, 08 January 2015, 21:58:37 »
that would make sense, at first i thought it was just the case
Offline captvizcenzo
« Reply #324 on: Fri, 16 January 2015, 02:37:55 »
How close are we to the GB? ;D
Offline meow a cat
  • Resistance is futile.
« Reply #325 on: Fri, 16 January 2015, 17:14:03 »
I would be interested in one of these, if funds permit. All the group buys lately are hitting me hard though.  :))
Boards:
Offline Sygaldry
  • Edema Ruh
« Reply #326 on: Tue, 20 January 2015, 10:28:12 »
My plans exactly. I believe I will be using the NerD TKL PCB with this (though I'm wondering if the plate will need to be modded to use it (like using a NerD PCB housing with the KMAC plate and housing)
null
Offline kin25
    • TXKeyboards
« Reply #327 on: Wed, 21 January 2015, 07:52:39 »
Nerd looks like a87(right side usb connecter). so you may use Nerd PCB on tx87. but you must use longer usb mini jack.
Offline Ngt
« Reply #328 on: Wed, 21 January 2015, 07:57:45 »
I wonder if it is possible to buy only the case to put the PCB etc. of another keyboard into it. Pretty much like if you want to change the case of an existing board.
Offline kin25
    • TXKeyboards
« Reply #329 on: Wed, 21 January 2015, 08:07:54 »
You must need Housing and Plate to use other PCB.
Offline foxer
  • Formerly wadeu
« Reply #330 on: Wed, 21 January 2015, 08:45:11 »
Looks incredible.
Unbowed, Unbent, Unbroken.
Offline Ngt
« Reply #331 on: Wed, 21 January 2015, 12:06:45 »
Meaning that I would have to desolder everything to put everything on the new plate etc.?
Offline kin25
    • TXKeyboards
« Reply #332 on: Wed, 21 January 2015, 12:24:49 »
right. you need to assemble the other parts
Offline Ngt
« Reply #333 on: Wed, 21 January 2015, 14:32:17 »
Alright I'm not gonna highjack the thread with more unrelated questions. I'll ask them elsewhere .
Offline ninjadoc
« Reply #334 on: Fri, 23 January 2015, 14:32:15 »
interested
Offline Kira
  • <3 <3 <3 <3
« Reply #335 on: Sat, 24 January 2015, 00:27:55 »
Count me in!
Offline korrelate
  • iubeo stultum esse libenter
« Reply #336 on: Sat, 24 January 2015, 10:08:47 »
As long as the plates can be painted / anodized (black, preferably) I'm interested.
Can anyone comment on the quality of the components/manufacture of the PCB. I kind of feel like I got a little f***ed on my TrikX (don't get me wrong - it's my daily driver but after all of the hullabaloo about the soldering and chatter, etc. I'd like to know that if I'm going to drop cash on this it isn't just some hobbyist clusterf***k).
Have a Beautiful Day,
K
Topre REALFORCE
Offline cseng
« Reply #337 on: Sun, 25 January 2015, 14:42:14 »
and for that price... jeez hell yes!
Offline monotagary
  • Keycaps > Rent
« Reply #338 on: Tue, 27 January 2015, 11:44:22 »
I'm definitely in on this. I've been looking into KMACs and Orions lately and this looks perfect for my next project.
Offline geogga
« Reply #339 on: Fri, 30 January 2015, 20:40:12 »
I just bought DanG's Duck poker :( please I don't know what to do  :confused:
  • Chinchillin'
« Reply #340 on: Fri, 30 January 2015, 21:13:32 »
Elton just said that a new Duck TKL is in the works after the Octagon finishes. Hopefully these 2 don't compete.
Orion V2
Offline monotagary
  • Keycaps > Rent
« Reply #341 on: Fri, 30 January 2015, 22:07:44 »
Orion V2
I don't think I could handle that pressure. :confused:
Offline Sygaldry
  • Edema Ruh
« Reply #342 on: Fri, 30 January 2015, 22:09:11 »
Orion V2
Well the two boards are in two completely different price ranges...
I expect the Duck to come out to nearly 400 shipped if not more. This one is looking to be about 300 after shipping and fees.
null
Offline animated
  • uhhhhhhhhhhhhhhhh
« Reply #343 on: Fri, 30 January 2015, 22:19:42 »
very interested  :D
Das Browns, Filco Reds, Filco Blues, Leopold FC750R Reds, B.87 and B.Pad Gateron Blacks 65G Korean Springs, Varmillo VA87MR Gateron Blacks w/ Aluminum Case
Offline Dee1
« Reply #344 on: Sat, 31 January 2015, 01:20:21 »
Orion V2
My wallet would die if that happened.   :))
Offline ceflame
« Reply #345 on: Sat, 31 January 2015, 01:51:56 »
Orion V2
Didn't he say it would be half the cost of Orion V1 because of the acrylic/pc bottom?
Offline Sygaldry
  • Edema Ruh
« Reply #346 on: Sat, 31 January 2015, 01:57:33 »
Orion V2
Ah... if that's the case then disregard what I posted.
But this TX 87 has an ALU bottom for just ~50 more  ;D
null
Offline kin25
    • TXKeyboards
« Reply #347 on: Sat, 31 January 2015, 03:00:46 »
ALU bottom is more expensive than PC.
Sorry for late pcb.
tx87alps GB will start first.
Offline pasph
« Reply #348 on: Sat, 31 January 2015, 16:35:03 »
You said Alps?
With iso support?
Offline monotagary
  • Keycaps > Rent
« Reply #349 on: Sat, 31 January 2015, 18:18:53 »
I thought this was going to be MX. Will it support MX or just Alps?
