Author Topic: .  (Read 6694 times)
Offline esoomenona
  • Gnillort?
« on: Tue, 23 September 2014, 20:23:47 »
« Last Edit: Tue, 25 August 2015, 11:03:38 by esoomenona »
Offline Sent
  • Simplistic Serenity
  • ¯\_(ツ)_/¯
Re: Model M Dress-up with Moose!
« Reply #1 on: Tue, 23 September 2014, 20:37:59 »
They're all nice but I prefer the first option then the second if I had to choose.  I'm boring, though, and like clean and simple stuff, generally.  Those pad printed RGB caps are purdy.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #2 on: Tue, 23 September 2014, 21:17:05 »
great collection, but IMOP you need more BS boards to pan out your collection- simpler looks classier to me
i do agree with sent that the rgb in addition is purdy............
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline esoomenona
  • Gnillort?
« Reply #3 on: Tue, 23 September 2014, 22:10:05 »
« Last Edit: Tue, 25 August 2015, 11:03:47 by esoomenona »
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #4 on: Tue, 23 September 2014, 22:53:30 »
I'm not sure exactly what you mean about more BS boards. Care to explain?
I suppose he means Buckling Spring (switch mechanism) used in all Model-Ms  8) .  You just need to buy more Model M's and Model F's (why not) before you can stand proud here on Geekhack as a true IBM aficionado.
« Last Edit: Tue, 23 September 2014, 22:55:37 by Elrick »
« Reply #5 on: Wed, 24 September 2014, 02:06:02 »
I like the last picture best :)
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #6 on: Wed, 24 September 2014, 06:49:23 »
I have this board, the Kentucky board mentioned, the Model M the RGB caps above came from, the M13 the black caps came from, another SSK, and a F XT. I think I have more buckling spring boards than any other switch I own....
I think he means it is too busy with all the novelties on one board.
However, you have so many BS clacks, you'd need a hell of a lot of M's to make each board look "simple".
If I had to pick, I'd do just the OG tri in the first pic with only the silver checkkeys.
Or the Salute in the "esc" spot and leave the RWB where they are and get rid of everything else.
« Last Edit: Wed, 24 September 2014, 06:51:10 by absyrd »
« Reply #7 on: Wed, 24 September 2014, 07:35:00 »
I've never been a fan of RGB sets but I *love* those Kentucky Wildcats modifiers. That last picture is my favorite.
Offline esoomenona
  • Gnillort?
« Reply #8 on: Wed, 24 September 2014, 08:18:18 »
« Last Edit: Tue, 25 August 2015, 11:04:01 by esoomenona »
« Reply #9 on: Wed, 24 September 2014, 08:29:00 »
For some reason, I've always liked putting on novelty caps in the following order:
- Escape
- Print Screen/Scroll/Pause cluster
- F9-F12
- F5-F8
- F1-F4
This order just looks really nice to me. However, the YUCK is cracking me up so keep those as is. I think you should swap the ClickClacks to the F9-F12 cluster and keep the YUCK where it is. Put the F1-F4 caps from the M13 back into the F1-F4 cluster. Also, feel free to put other words. I really like "Cutey", "Cute", or "Nuke".
« Reply #10 on: Wed, 24 September 2014, 08:39:35 »
I really like the one with the RGB mods.  Is the blue a different shade than is usual?
Offline esoomenona
  • Gnillort?
« Reply #11 on: Wed, 24 September 2014, 08:45:45 »
« Last Edit: Tue, 25 August 2015, 11:04:11 by esoomenona »
Offline skcheng
    • Tenafly Dentistry
« Reply #12 on: Wed, 24 September 2014, 09:12:55 »
Can you take a shot with the stock keys??    Love the Clacks!!    Didn't even know that some of those were out there?
Offline esoomenona
  • Gnillort?
« Reply #13 on: Wed, 24 September 2014, 09:31:15 »
« Last Edit: Tue, 25 August 2015, 11:04:19 by esoomenona »
Offline JPG
  • Model F is my new passion!
« Reply #14 on: Wed, 24 September 2014, 09:38:51 »
I like the blue mods better. I think it would look even better with blue on white alphas. Still, in the end, just choose the one you prefer since it's you that will use it everyday!
And whatever you choose, using a SSK is already a very good decision in itself!
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #15 on: Wed, 24 September 2014, 15:51:07 »
That's kind of what I was thinking he meant, but I wanted to let him explain himself instead of assuming his meaning.
I can agree with him and Sent. I'm actually quite partial to the first setup as well. It is simple and clean. But I also love everything else I have posted, and they can only go well with each other (aside from the CCs, of course) as they're all pad printed, and other BS caps are not. I contemplated taking some of the CCs off, but I won't do that. This is their home. They only belong here. I don't like having them and keeping them stored until I decide to use them. If they're not there, then what's the purpose of having them?
I know you so well. I figured that would be your sentiment. Personally, I know some people would go with the entire KENTUCKY F row, but I just can't do that. What do you think about F5-F8? Would I be better off just moving the CCs there, and putting F1-F4 black caps on? I also never truly planned to use the blue Esc, so maybe I can drop the OG or the Salute there.
right...............too busy :eek:
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
« Reply #16 on: Wed, 24 September 2014, 16:11:36 »
I think the board would look awesome with just the og on esc.
